Using an SFS File System Through a Dynamic PV
This section describes how to use storage classes to dynamically create PVs and PVCs for data persistence and sharing in workloads.
Automatically Creating an SFS File System Through kubectl
  1. Use kubectl to access the cluster.
  2. Use StorageClass to dynamically create a PVC and PV.
    1. Create the pvc-sfs-auto.yaml file.
      apiVersion: v1
      kind: PersistentVolumeClaim
        namespace: default
        annotations:
          everest.io/crypt-key-id: <your_key_id>      # (Optional) ID of the key for encrypting file systems
          everest.io/crypt-alias: sfs/default         # (Optional) Key name. Mandatory for encrypting volumes.
          everest.io/crypt-domain-id: <your_domain_id>   # (Optional) ID of the tenant to which an encrypted volume belongs. Mandatory for encrypting volumes.
        accessModes:
          - ReadWriteMany             # The value must be ReadWriteMany for SFS.
        resources:
          requests:
            storage: 1Gi             # SFS volume capacity
        storageClassName: csi-nas    # StorageClass is SFS.
      Table 1 Key parameters
      Mandatory
      storage
      Yes
      Requested capacity in the PVC, in Gi.
      For SFS, this field is used only for verification (cannot be empty or 0). Its value is fixed at 1, and any value you set does not take effect for SFS file systems.
      No
      This parameter is mandatory when an SFS system is encrypted. Enter the encryption key ID selected during SFS system creation. You can use a custom key or the default key named sfs/default.
      To obtain a key ID, log in to the DEW console, locate the key to be encrypted, and copy the key ID.
      No
      Key name, which is mandatory when you create an encrypted volume.
      To obtain a key name, log in to the DEW console, locate the key to be encrypted, and copy the key name.
      No
      ID of the tenant to which the encrypted volume belongs. This parameter is mandatory for creating an encrypted volume.
      To obtain a tenant ID, hover the cursor over the username in the upper right corner of the ECS console, choose My Credentials, and copy the account ID.
    2. Run the following command to create a PVC:
      kubectl apply -f pvc-sfs-auto.yaml
  3. Create an application.
    1. Create a file named web-demo.yaml. In this example, the SFS volume is mounted to the /data path.
      apiVersion: apps/v1
      kind: Deployment
        namespace: default
        replicas: 2
        selector:
          matchLabels:
            app: web-demo
        template:
            labels:
              app: web-demo
            containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
              - name: pvc-sfs-volume    # Volume name, which must be the same as the volume name in the volumes field
                mountPath: /data  # Location where the storage volume is mounted
            imagePullSecrets:
              - name: default-secret
            volumes:
              - name: pvc-sfs-volume    # Volume name, which can be customized
                persistentVolumeClaim:
                  claimName: pvc-sfs-auto    # Name of the created PVC
    2. Run the following command to create a workload to which the SFS volume is mounted:
      kubectl apply -f web-demo.yaml
      After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence and Sharing.
  1. View the deployed application and files.
    1. Run the following command to view the created pod:
      kubectl get pod | grep web-demo
      Expected output:
      web-demo-846b489584-mjhm9   1/1     Running   0             46s
      web-demo-846b489584-wvv5s   1/1     Running   0             46s
    2. Run the following commands in sequence to view the files in the /data path of the pods:
      kubectl exec web-demo-846b489584-mjhm9 -- ls /data
      kubectl exec web-demo-846b489584-wvv5s -- ls /data
      If no result is returned for both pods, no file exists in the /data path.
  2. Run the following command to create a file named static in the /data path:
    kubectl exec web-demo-846b489584-mjhm9 --  touch /data/static
  3. Run the following command to check the files in the /data path:
    Expected output:
    static
  4. Verify data persistence.
    1. Run the following command to delete the pod named web-demo-846b489584-mjhm9:
      kubectl delete pod web-demo-846b489584-mjhm9
      Expected output:
      pod "web-demo-846b489584-mjhm9" deleted
      After the deletion, the Deployment controller automatically creates a replica.
    2. Run the following command to view the created pod:
      The expected output is as follows, in which web-demo-846b489584-d4d4j is the newly created pod:
      web-demo-846b489584-d4d4j   1/1     Running   0             110s
      web-demo-846b489584-wvv5s    1/1     Running   0             7m50s
    3. Run the following command to check whether the files in the /data path of the new pod have been modified:
      kubectl exec web-demo-846b489584-d4d4j -- ls /data
      Expected output:
      static
      The static file is retained, indicating that the data in the file system can be stored persistently.
  5. Verify data sharing.
      Expected output:
      web-demo-846b489584-d4d4j   1/1     Running   0             7m
      web-demo-846b489584-wvv5s   1/1     Running   0             13m
    2. Run the following command to create a file named share in the /data path of either pod: In this example, select the pod named web-demo-846b489584-d4d4j.
      kubectl exec web-demo-846b489584-d4d4j --  touch /data/share
      Check the files in the /data path of the pod.
      Expected output:
      share
      static
    3. Check whether the share file exists in the /data path of another pod (web-demo-846b489584-wvv5s) as well to verify data sharing.
      Expected output:
      share
      static
      After you create a file in the /data path of a pod, if the file is also created in the /data path of the other pod, the two pods share the same volume.
Related Operations
You can also perform the operations listed in Table 2.
Table 2 Related operations
Operation
Viewing events
View event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV.
  1. Choose Storage in the navigation pane. In the right pane, click the PVCs or PVs tab.
  2. Click View Events in the Operation column of the target PVC or PV to view events generated within one hour (events are retained for one hour).
Viewing a YAML file
View, copy, or download the YAML file of a PVC or PV.
  2. Click View YAML in the Operation column of the target PVC or PV to view or download the YAML.
