Updated on 2026-09-10 GMT+08:00
Overview
As Internet develops, data storage scenarios become increasingly diverse. Limited storage classes cannot meet diverse storage and cost management requirements. OBS provides the Deep Archive, Standard, Infrequent Access, and Archive storage classes for you to choose from. For more information about billing for different storage classes, see Storage Space.
Storage Classes
OBS supports the following storage classes:
  • Scenarios: The Standard storage class features low latency and high throughput. It is therefore good for storing frequently (multiple times a month) accessed files or small files (less than 1 MB). Its application scenarios include big data analytics, mobile apps, hot videos, and social apps.
  • Redundancy: The Standard storage class provides two redundancy options. Multi-AZ storage means data is stored in multiple AZs, which enables more reliability. Single-AZ storage means data is stored in a single AZ, which is more cost-effective.
  • Specifications: The minimum billable object size is 64 KB. There are no requirements for the minimum storage duration.
    Objects smaller than 64 KB are billed as 64 KB.
    • Minimum eligible size: It refers to the minimum object size that is eligible for billing. For example, a 32 KB Standard object will be billed as if it were 64 KB.
    • Minimum storage duration: During the minimum storage duration, if an object's storage class remains unchanged, you are billed for its actual storage duration. However, if the storage class is changed or the object is deleted, the minimum storage duration applies. For Infrequent Access objects, the minimum storage duration is 30 days. If you delete the object or change its storage class before it has been stored for 30 days, you must still pay for the full 30 days. If the object is stored for more than 30 days, you are billed for the actual number of days stored.
  • Data restoration: N/A
    Objects in the Archive or Deep Archive storage class must be restored before you can access them. The access includes reading or downloading the objects, modifying their ACLs, or accessing them with a URL. For more information, see Restoring Archive or Deep Archive Objects.
  • Scenarios: The Infrequent Access storage class is for storing data that is infrequently (less than 12 times a year) accessed, but when needed, the access has to be fast. It can be used for file synchronization, file sharing, enterprise backups, and many other scenarios.
  • Redundancy: The Infrequent Access storage class provides two redundancy options. Multi-AZ storage means data is stored in multiple AZs, which enables more reliability. Single-AZ storage means data is stored in a single AZ, which is more cost-effective.
  • Specifications: The minimum billable object size is 64 KB. The minimum storage duration is 30 days.
    Objects smaller than 64 KB are billed as 64 KB. Objects stored for fewer than 30 days are billed for a full 30 days.
  • Data restoration: The system automatically restores data, which generates data restoration costs.
    • Objects in the Infrequent Access or Archive or Deep Archive storage class must be restored before you can access them. The access includes reading or downloading the objects, modifying their ACLs, or accessing them with a URL. For more information, see Restoring Archive or Deep Archive Objects.
  • Scenarios: The Archive storage class is ideal for storing data that is rarely (once a year) accessed. Its application scenarios include data archiving and long-term backups. This storage class is secure, durable, and inexpensive, so it is often used to replace tape libraries. To reduce costs, restoring data may take minutes or even hours.
  • Redundancy: The Archive storage class only supports single-AZ redundancy. Data is stored in a single AZ, which is more cost-effective.
  • Specifications: The minimum billable object size is 64 KB. The minimum storage duration is 90 days.
    Objects smaller than 64 KB are billed as 64 KB. Objects stored for fewer than 90 days are billed for a full 90 days.
    • The minimum billable object size refers to the minimum object size that is eligible for billing. For example, a 32 KB Standard object will be billed as if it were 64 KB.
    • The minimum storage duration refers to the least time that is eligible for billing. This means that objects will be billed for the minimum storage duration even if they are not stored for that long. For example, if an Archive object is deleted after being stored in OBS for 80 days, it will be billed for the storage of 90 days.
  • Data restoration: Archive objects can be accessed only after being restored. The Archive storage class supports standard and expedited restoration. The standard restoration takes 3 to 5 hours, and the expedited restoration takes 1 to 5 minutes. You can enable Direct Reading to access Archive objects without restoring them first. Direct reading is billable, so only enable it if necessary.
  • Scenarios: The Deep Archive storage class is suitable for storing data that is hardly ever accessed (once every few years on average). This storage class costs less than the Archive storage class, but takes longer (usually several hours) to restore data.
    Data stored in the Deep Archive storage class is not transferred across borders.
  • Redundancy: The Deep Archive storage class only supports single-AZ redundancy. Data is stored in a single AZ, which is more cost-effective.
  • Specifications: The minimum billable object size is 64 KB. The minimum storage duration is 180 days.
    • The minimum storage duration refers to the least time that is eligible for billing. This means that objects will be billed for the minimum storage duration even if they are not stored for that long. For example, if a Deep Archive object is deleted after being stored in OBS for 170 days, it will be billed for the storage of 180 days.
  • Data restoration: Deep Archive objects can be accessed only after being restored. The Deep Archive storage class supports standard and expedited restoration. The standard restoration takes 5 to 12 hours, and the expedited restoration takes 3 to 5 hours.
Comparison of Storage Classes
Item
Standard
Infrequent Access
Archive
Deep Archive
Feature
Top-notch performance, high reliability and availability
Reliable, inexpensive storage with real-time access
Long-term storage for archived data at a low cost
Long-term storage for Deep Archive data, with a lower unit price than Archive storage
Use cases
Cloud applications, data sharing, content sharing, and hot data storage
Web disk applications, enterprise backups, active archive, and data monitoring
Storage of archives, medical imaging data, and videos, as well as replacement of tape libraries
Archive data that is barely accessed
Data access frequency
Multiple times a month on average
Less than 12 times a year on average
Once a year on average
Once every few years on average
Designed durability (single-AZ)
99.999999999% (11 nines)
Designed durability (multi-AZ)
99.9999999999% (12 nines)
Not supported
Not supported
Designed availability (single-AZ)
99.99%
99%
99%
99%
Designed availability (multi-AZ)
99.995%
99.5%
Not supported
Not supported
Minimum billable object size
64 KB
64 KB
64 KB
64 KB
N/A
30 days
90 days
180 days
Data access speed
Real-time access
Real-time access
  • If direct reading is disabled, objects must be restored before they can be accessed. Standard restore: 3 to 5 hours; expedited restore: 1 to 5 minutes
  • If direct reading is enabled, objects can be accessed in real time.
Objects must be restored before you can access them. Standard restore: 5 to 12 hours; expedited restore: 3 to 5 hours
Data restoration charges
N/A
Billed for each GB restored.
Billed for each GB restored. Pricing differs depending on standard or expedited restoration.
Image processing
Supported
Supported
Not supported
Not supported
For details about billing for different storage classes, see Storage Space.
Helpful Links
