Updated on 2026-09-10 GMT+08:00
Key OBS Operations Logged by CTS
Cloud Trace Service (CTS) is a dedicated log audit service within Huawei Cloud security. It keeps track of operations performed on cloud service resources, covering the user identity, IP address, operation details, and returned response information. These operation records let you do security audit, trace issues, and locate resources quickly. They also help you plan and use resources, and identify high-risk or non-compliant operations.
Related Concepts
Working Principles of Auditing OBS Operations
With CTS, you can record operations related to OBS for future query, audit, and backtrack. Figure 1 shows how OBS works with CTS.
Figure 1 Collaboration among OBS, CTS, and LTS
  1. When you perform operations on buckets (such as creating or deleting a bucket), OBS reports management traces to CTS. When you perform operations on objects (such as uploading or deleting an object), OBS reports data traces to CTS.
  2. OBS traces can be stored in CTS for a maximum of seven days. To store traces for more than seven days, you can configure trace transfer to OBS or Log Tank Service (LTS). CTS periodically saves operation records to a user-defined OBS bucket or LTS log stream for long-term storage.
    Configuring trace transfer to OBS or LTS will incur storage fees. For details, see Billing.
  3. (Optional) You can use LTS to search for and analyze traces.
Billing
  • If you do not configure trace transfer to OBS buckets or LTS, the billing involves only CTS. The core functions of CTS are free of charge, covering the entire process of enabling CTS and its basic trace management. You can use the following functions for free:
    • Enabling trackers at no additional cost
    • Real-time and accurate tracking of cloud resource operations
    • Free storage and search of audit traces for seven days, meeting short-term trace query and compliance check needs
  • If you configure trace transfer to OBS, you will be billed for storing trace files in OBS buckets. For details, see OBS billing.
    If you need to use Data Encryption Workshop (DEW) to encrypt trace files stored in buckets, you will also be billed by DEW. For details, see DEW billing.
  • If you configure trace transfer to LTS, you will be billed for the log storage of LTS. For details, see LTS billing.
Important Notes
By default, CTS uses only the management tracker named System, which is automatically created by the system, to record management traces. It does not record data traces. To enable CTS to record data traces, you need to create a data tracker.
OBS Operations That Can Be Recorded by CTS
OBS operations that can be recorded by CTS are classified into management traces and data traces.
After you log in to the CTS console and enable CTS, the system automatically creates a management tracker named System. A management tracker identifies and associates with all your cloud services to record all your management operations.
In OBS, operations on buckets (such as creating or deleting a bucket) are management traces and need to be recorded by a management tracker.
Table 1 lists the OBS management operations that can be logged by CTS.
Table 1 OBS management operations logged by CTS
Tracker Type
Operation Name
Resource Type
Trace Name
Management
Creating a bucket
Bucket
createBucket
Management
Deleting a bucket
Bucket
deleteBucket
Management
Listing buckets
Bucket
listAllMyBuckets
(If you use OBS Console to list buckets, relevant traces will be recorded in CN-Hong Kong or AP-Singapore. For Latin America, traces of listing buckets are recorded as follows: those in LA-Santiago are recorded in LA-Santiago, those in LA-Sao Paulo1, LA-Buenos Aires1, and LA-Lima1 are recorded in LA-Sao Paulo1, and those in LA-Mexico City1 and LA-Mexico City2 are recorded in LA-Mexico City2.)
Management
Obtaining bucket metadata
Bucket
headBucket
Management
Obtaining the bucket location
Bucket
getBucketLocation
Management
Listing objects in a bucket
Bucket
listObjects
Management
Listing initiated multipart uploads in a bucket
Bucket
listMultipartUploads
Management
Obtaining the storage usage of a bucket
Bucket
getBucketStorageInfo
Management
Configuring the CORS rule for a bucket
Bucket
setBucketCors
Management
Obtaining the CORS configuration of a bucket
Bucket
getBucketCors
Management
Deleting the CORS configuration of a bucket
Bucket
deleteBucketCors
Management
Configuring a user-defined domain name for a bucket
Bucket
setBucketCustomdomain
Management
Obtaining the user-defined domain name of a bucket
Bucket
getBucketCustomdomain
Management
Deleting the user-defined domain name of a bucket
Bucket
deleteBucketCustomdomain
Management
Setting the lifecycle for a bucket
Bucket
setBucketLifecycle
Management
Obtaining the lifecycle configuration of a bucket
Bucket
getBucketLifecycle
Management
Deleting the lifecycle configuration of a bucket
Bucket
deleteBucketLifecycle
Management
Configuring cross-region replication for a bucket
Bucket
setBucketReplication
Management
Obtaining the cross-region replication configuration of a bucket
Bucket
getBucketReplication
Management
Deleting the cross-region replication configuration of a bucket
Bucket
deleteBucketReplication
Management
Setting a bucket tag
Bucket
setBucketTagging
Management
Obtaining bucket tags
Bucket
getBucketTagging
Management
Deleting the tag configuration of a bucket
Bucket
deleteBucketTagging
Management
Configuring static website hosting for a bucket
Bucket
setBucketWebsite
Management
Obtaining the static website hosting configuration of a bucket
Bucket
getBucketWebsite
Management
Deleting the static website hosting configuration of a bucket
Bucket
deleteBucketWebsite
Management
Configuring a bucket policy
Bucket
setBucketPolicy
Management
Deleting a bucket policy
Bucket
deleteBucketPolicy
Management
Configuring a bucket ACL
Bucket
setBucketAcl
Management
Obtaining bucket ACL information
Bucket
getBucketAcl
Management
Configuring logging for a bucket
Bucket
setBucketLogging
Management
Obtaining the logging configuration of a bucket
Bucket
getBucketLogging
Management
Configuring event notification for a bucket
Bucket
setBucketNotification
Management
Obtaining the event notification configuration of a bucket
Bucket
getBucketNotification
Management
Configuring a storage quota for a bucket
Bucket
setBucketQuota
Management
Obtaining the storage quota of a bucket
Bucket
getBucketQuota
Management
Configuring the storage class for a bucket
Bucket
setBucketStorageclass
Management
Obtaining the storage class of a bucket
Bucket
getBucketStorageclass
Management
Configuring versioning for a bucket
Bucket
setBucketVersioning
Management
Obtaining the versioning status of a bucket
Bucket
getBucketVersioning
Management
Configuring server-side encryption for a bucket
Bucket
setBucketEncryption
Management
Obtaining the server-side encryption configuration of a bucket
Bucket
getBucketEncryption
Management
Deleting the server-side encryption configuration of a bucket
Bucket
deleteBucketEncryption
Management
Obtaining the Block Public Access configuration of a bucket
Bucket
getBucketPublicAccessBlock
Management
Configuring Block Public Access for a bucket
Bucket
putBucketPublicAccessBlock
Management
Deleting the Block Public Access configuration of a bucket
Bucket
deleteBucketPublicAccessBlock
Management
Obtaining the public access status of a bucket policy
Bucket
getBucketPolicyPublicStatus
Management
Bucket
getBucketPublicStatus
Management
Configuring an inventory for a bucket
Bucket
setBucketInventoryConfiguration
Management
Obtaining the inventory configuration of a bucket
Bucket
getBucketInventoryConfiguration
Management
Deleting the inventory configuration of a bucket
Bucket
deleteBucketInventoryConfiguration
Management
Configuring the Direct Reading policy for a bucket
Bucket
setBucketDirectColdAccess
Management
Obtaining the Direct Reading policy of a bucket
Bucket
getBucketDirectColdAccess
Management
Deleting the Direct Reading policy of a bucket
Bucket
deleteBucketDirectColdAccess
Management
Configuring back-to-source by mirroring rules
Bucket
setBucketBackToSource
Management
Obtaining back-to-source by mirroring rules
Bucket
getBucketBackToSource
Management
Deleting back-to-source by mirroring rules
Bucket
deleteBucketBackToSource
Management
Configuring a default WORM policy for a bucket
Bucket
setBucketObjectLockConfiguration
Management
Obtaining the default WORM policy of a bucket
Bucket
getBucketObjectLockConfiguration
Management
Sending an OPTIONS request to a bucket
Bucket
optionsBucket
Management
Configuring a bucket trigger
Bucket
putTriggerPolicy
Management
Deleting a bucket trigger
Bucket
deleteTriggerPolicy
Management
Creating a workflow template
Bucket
createWorkflowTemplate
Management
Deleting a workflow template
Bucket
deleteWorkflowTemplate
Management
Creating a workflow
Bucket
createWorkflow
Management
Deleting a workflow
Bucket
deleteWorkflow
Management
Updating a workflow
Bucket
updateWorkflow
Management
Creating a workflow directly
Bucket
directCreateWorkflow
Management
Enabling workflow authorization
Bucket
openWorkflowAuthorization
Management
Resuming a failed workflow instance
Bucket
restoreFailedWorkflowExecution
Management
Triggering a workflow using an API
Bucket
asyncAPIStartWorkflow
Management
Creating a public action template
Bucket
createMyActionTemplate
Management
Modifying a submitted public action template
Bucket
updateMyActionTemplate
Management
Deleting a submitted public action template
Bucket
deleteMyActionTemplate
Management
Disabling a submitted public action template
Bucket
forbidMyActionTemplate
Management
Agreeing to the service agreement
Bucket
openWorkflowAgreements
A data tracker records details of user operations on data in OBS buckets. It records data traces reported by OBS, detailing user operations on objects in OBS buckets, including uploads and downloads. You need to create a data tracker to record data traces.
Table 2 lists the OBS data operations that can be logged by CTS.
Table 2 OBS data operations logged by CTS
Tracker Type
Operation Name
Resource Type
Trace Name
Data_Read
Downloading an object
Object
GET.OBJECT
Data_Read
Querying the object ACL
Object
GET.OBJECT.ACL
Data_Read
Obtaining an object through the website
Object
GET.OBJECT.WEBSITE
Data_Read
Accessing an object through the website
Object
HEAD.OBJECT.WEBSITE
Data_Read
Querying the object metadata
Object
HEAD.OBJECT
Data_Read
Listing part data
Object
LIST.OBJECT.UPLOAD
Data_Read
Querying the cross-domain requests for objects
Object
OPTIONS.OBJECT
Data_Write
Deleting an object
Object
DELETE.OBJECT
Data_Write
Canceling a part
Object
DELETE.UPLOAD
Data_Write
Uploading an object using a form
Object
POST.OBJECT
Data_Write
Batch deleting objects
Object
POST.OBJECT.MULTIDELETE
Data_Write
Restoring Archive objects
Object
POST.OBJECT.RESTORE
Data_Write
Completing the multipart upload
Object
POST.UPLOAD.COMPLETE
Data_Write
Initiating a multipart upload
Object
POST.UPLOAD.INIT
Data_Write
Uploading an object using PUT
Object
PUT.OBJECT
Data_Write
Configuring the object ACL
Object
PUT.OBJECT.ACL
Data_Write
Copying an object
Object
PUT.OBJECT.COPY
Data_Write
Configuring the object storage class
Object
PUT.OBJECT.STORAGECLASS
Data_Write
Uploading parts
Object
PUT.PART
Data_Write
Copying parts
Object
PUT.PART.COPY
