Updated on 2026-09-23 GMT+08:00
Viewing OBS Traces
This section describes how to view or export traces generated in the last seven days on the CTS console and how to view traces that have been transferred to OBS buckets or LTS.
Example CTS Traces
The following uses bucket creation (management trace) and object upload (data trace) as examples to describe the content of trace files stored in CTS, OBS, and LTS. For more examples of CTS traces, see Example Traces.
The trace list only displays OBS management traces (such as bucket creation). To view OBS data traces (such as object upload), you need to create a data tracker, configure the tracker to transfer traces to OBS or LTS, and then view the traces in OBS or LTS. The following shows an example of an OBS bucket creation trace in the trace list.
  • Creating a bucket
      "code": "200",
      "domain_id": "aaaaaaaaaaaaaaaaaa",
      "event_type": "system",
      "project_id": "bbbbbbbbbbbbbbbbbb",
      "read_only": false,
      "resource_name": "test003zcy",
      "resource_type": "bucket",
      "service_type": "OBS",
      "source_ip": "x.x.x.x",
      "trace_id": "cccccccccccccccccccc",
      "trace_name": "createBucket",
      "trace_rating": "normal",
      "trace_type": "Others",
      "tracker_name": "system",
      "user_agent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/140.0.0.0 Safari/537.36",
      "user": {
        "access_key_id": "dddddddddddd",
        "account_id": "eeeeeeeeeeeeeeeeee",
        "domain": {
          "id": "ffffffffffffffffff",
          "name": "Test_name"
        "invoked_by": [
          "service.console"
        "name": "ggggggggggggggggggg/testname",
        "principal_id": "ggggggggggggggggggg:testname",
        "principal_urn": "sts::ggggggggggggggggggg:external-user:ggggggggggggggggggg/testname",
        "session_context": {
          "attributes": {
            "creationDate": "1779956903340",
            "mfa_authenticated": "false"
          "federation_data": {
            "group_Ids": [
              "hhhhhhhhhhhhhhhhhhh",
              "iiiiiiiiiiiiiiiiiiii"
            "identity_provider": "ggggggggggggggggggg",
            "protocol": "saml"
        "type": "ExternalUser",
        "id": "ggggggggggggggggggg"
      "time": 1779956940605,
      "record_time": 1779956940605
If you have configured trace transfer to OBS, you can view traces in OBS buckets.
When traces are transferred to OBS, the user field is serialized into a string, which needs to be deserialized for parsing.
  • Creating a bucket
    [{"code":200,"domain_id":"aaaaaaaaaaaaaaaaaa","event_type":"system","project_id":"bbbbbbbbbbbbbbbbbb","read_only":false,"record_time":1779961459823,"resource_name":"test003zcy","resource_type":"bucket","service_type":"OBS","source_ip":"x.x.x.x","time":1779961459823,"trace_id":"cccccccccccccccccccc","trace_name":"createBucket","trace_rating":"normal","trace_type":"Others","tracker_name":"system","user":"{\"access_key_id\":\"dddddddddddd\",\"account_id\":\"eeeeeeeeeeeeeeeeee\",\"domain\":{\"id\":\"ffffffffffffffffff\",\"name\":\"Test_name\"},\"invoked_by\":[\"service.console\"],\"name\":\"ggggggggggggggggggg/testname\",\"principal_id\":\"ggggggggggggggggggg:testname\",\"principal_urn\":\"sts::ggggggggggggggggggg:external-user:ggggggggggggggggggg/testname\",\"session_context\":{\"attributes\":{\"creationDate\":\"1779961225561\",\"mfa_authenticated\":\"false\"},\"federation_data\":{\"group_Ids\":[\"hhhhhhhhhhhhhhhhhhh\",\"iiiiiiiiiiiiiiiiiiii\"],\"identity_provider\":\"ggggggggggggggggggg\",\"protocol\":\"saml\"}},\"type\":\"ExternalUser\",\"id\":\"ggggggggggggggggggg\"}","user_agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/140.0.0.0 Safari/537.36"}]
  • Uploading objects
    [{"code":200,"content_length":3,"event_type":"data","project_id":"bbbbbbbbbbbbbbbbbb","read_only":false,"record_time":1779961398474,"request_id":"kkkkkkkkkkkkkkkkkk","resource_name":"test003zcy:test.txt","resource_type":"OBJECT","service_type":"OBS","source_ip":"x.x.x.x","time":1779961398474,"total_time":43,"trace_id":"cccccccccccccccccccc","trace_name":"PUT.OBJECT","trace_rating":"normal","trace_type":"Others","user":"{\"domain\":{\"id\":\"ffffffffffffffffff\",\"name\":\"Test_name\"},\"id\":\"ggggggggggggggggggg\",\"name\":\"testname\"}"}]
If you have configured trace transfer to LTS, you can view traces in LTS log streams.
The OBS traces displayed on the LTS console differ in format from those on the CTS console and those transferred to OBS buckets. The following figures show the differences.
  • Creating a bucket
  • Uploading objects
Key Fields in CTS Traces
For details about the key fields in CTS traces, see Trace Structure.
Notes and Constraints
For details about the constraints on CTS, see CTS Notes and Constraints.
  1. You have signed up for a Huawei Cloud account and completed real-name authentication.
    If you already have an account, skip this step. If you do not have one, do as follows:
    1. Visit the Huawei Cloud official website and click Sign Up.
    2. Follow the instructions to complete your registration. For details, see Signing Up for an Account.
      After the signup, you will be redirected to your personal information page.
    3. Complete real-name authentication for your individual or enterprise account.
  2. Permissions have been granted to the account.
    If you log in to the console using a Huawei Cloud account, skip this step.
    If you log in to the console as an IAM user, first contact your CTS administrator (account owner or a user in the admin user group) to obtain the CTS FullAccess permission. For details, see Assigning Permissions to an IAM User.
Querying Traces
(Optional) Step 1: Create a Data Tracker
When you enable CTS, the system automatically creates a management tracker to track management traces. Only one management tracker can be created. To track data traces, you need to create a data tracker. For details about the maximum number of data trackers that can be created for an account, see CTS Notes and Constraints.
You can create a maximum of two data trackers for the same bucket, provided that their tracked operation types do not overlap. For example, if you create a data tracker for a bucket to track both read and write operations, you cannot create a second tracker for it, because the first one already covers all operations on the bucket. Creating a second one will result in overlapping operation types.
For details about how to create a data tracker, see Creating a Tracker.
Step 2: View Historical Traces
References
