Help Center/ Object Storage Service/ User Guide/ Domain Name Management/ Accessing a Bucket Using a CDN Acceleration Domain Name
Updated on 2026-09-23 GMT+08:00
More and more companies in various industries use OBS to store static resource files such as images, videos, and software packages, and use OBS as the storage source for websites, forums, apps, and games. These static resources can be obtained by accessing OBS through URLs. Generally, files are stored in only one region. If you access OBS far away from the region where files are stored, the response speed may be slow. In scenarios where frequent access is required, accessing OBS to obtain files consumes a large amount of traffic.
To improve the speed and stability for accessing static resource files, you can use CDN acceleration. If you have configured a user-defined domain name for a bucket, you can directly enable CDN acceleration for the domain name. If you have not configured a user-defined domain name for the bucket, you can configure a CDN acceleration domain name.
CDN acceleration applies to the following scenarios:
  • Website acceleration
    When static resources (such as images and files) on portals, e-commerce platforms, or user-generated content (UGC) apps are accessed by large or globally distributed user bases, CDN acceleration can make the responses faster.
  • Download acceleration
    CDN acceleration enables higher bandwidth and faster transmission, which reduces the time required for downloading files from websites, game clients, or app stores.
  • On-demand service acceleration
    In scenarios, such as online education and video sharing, that offer video on demand (VOD) and audio on demand (AOD) services, CDN acceleration can minimize playback buffering.
For details, see Application Scenarios.
Video Tutorial
This video shows how to configure a CDN acceleration domain name for an OBS bucket:
  1. On OBS Console, bind an acceleration domain name to the OBS bucket.
  2. On the DNS console, add a CNAME record set.
Billing for CDN-Accelerated Access to OBS
When you use Huawei Cloud CDN to accelerate access to the data stored in OBS, charges from both OBS and CDN apply.
Figure 1 shows how and what costs are generated.
Figure 1 Using CDN to access OBS
Table 1 describes the billing items in detail.
Table 1 Billing items for accessing OBS via CDN acceleration
Billing Item
Billing Party
Billing Mode
Requests
OBS
When you attempt to access data the first time, a CDN edge PoP will send requests to pull data from the origin server (OBS). OBS charges based on the number of API requests.
Pay-per-Use
CDN pull traffic
OBS
Pull traffic generated when the origin server (OBS 3.0 bucket) returns data and caches it on the CDN edge PoP. If Direct Connect is used, the price will be different. For details, see Product Pricing Details.
Such traffic is only generated for OBS 3.0 buckets. If data is pulled from OBS 2.0 buckets, the data is directly transferred out over the Internet.
Pay-per-Use
CDN traffic
CDN
Outbound traffic generated when you access a CDN edge PoP. For details, see Billing by Traffic.
Pay-per-Use
Resource packages (prepaid CDN traffic packages)
How It Works
Accessing OBS without CDN acceleration: Files are stored in only one region. Therefore, when a client accesses OBS far away from the region, the response speed may be slow.
Accessing OBS with CDN acceleration: When a client initiates a request, CDN searches for the CDN PoP that responds the fastest to the domain name and checks whether the CDN PoP has already cached the data requested by the client.
  • If cached, the CDN PoP returns the data to the client.
  • If not, the CDN PoP pulls the data from OBS, returns the data to the client, and caches the data on itself.
Therefore, CDN-based acceleration reduces latency, lowers costs, and enhances the end-user experience.
The following explains how a client accesses OBS without and with CDN acceleration.
Figure 2 shows the process of accessing OBS directly from clients without CDN acceleration.
Figure 2 Process of obtaining data from OBS
When a client initiates a request, CDN searches for the CDN PoP that responds the fastest to the domain name and detects that the requested data is not cached on the PoP. Then, the CDN PoP pulls the data from OBS, returns the data to the client, and caches the data on itself. Figure 3 shows the request process.
Figure 3 Accessing OBS with CDN acceleration (without cached data on the CDN PoP)
When a client initiates a request, CDN searches for the CDN PoP that responds the fastest to the domain name and detects that the requested data is cached on the PoP. Then, the CDN PoP returns the data to the client, without pulling data from OBS. Figure 4 shows the request process.
Figure 4 Accessing OBS with CDN acceleration (with cached data on the CDN PoP)
Only buckets whose version is 3.0 or later support CDN acceleration. To check the version of a bucket, go to OBS Console, click the bucket name and go to the Overview page, and find the version in the Basic Information area.
Configuring an Acceleration Domain Name
You can use OBS Console to configure acceleration domain names. You cannot use APIs, SDKs, OBS Browser+, or obsutil to do so.
To configure an acceleration domain name on OBS Console, perform the following two steps:
  1. Bind an acceleration domain name to the bucket.
  2. Add a CNAME record set to map the acceleration domain name to the default domain name of the bucket.
Enabling Acceleration for a User-Defined Domain Name
You can use OBS Console to enable acceleration for the user-defined domain name bound to the bucket. You cannot use APIs, SDKs, OBS Browser+, or obsutil to do so.
To enable acceleration on OBS Console, perform the following two steps:
  1. Enable acceleration for the bound user-defined domain name.
Production Deployment and Risk Mitigation
Once the base integration between CDN and OBS is in place, you can combine both services in production environments. On top of encrypted transmission and smooth CDN domain cutover, configure cache Time to Live (TTL), resource prefetch, cache refresh, CORS rules, and large file transfer optimization to improve access performance. At the same time, use URL validation, traffic monitoring and alerts, origin access protection, and log auditing to build a strong risk-control baseline and achieve stable rollout and full observability.
