OBS Monitoring Metrics
Functions
This section defines the namespace, list, and dimensions of monitoring metrics reported by OBS to Cloud Eye. You can use the Cloud Eye console or API to search for monitoring metrics and alarms generated by OBS.
Cloud Eye can monitor dimensions nested to a maximum depth of four levels (levels 0 to 3). 3 is the deepest level. For example, if the monitored dimension of a metric is bucket_name,api_name, bucket_name indicates level 0 and api_name indicates level 1.
Namespace
SYS.OBS
Background Information
Before using monitoring, you may need to know the following terms.
| Term | Description | Example |
| P50 latency | P50 latency is the median latency, which means that 50% of all requests finish below this threshold, while the remaining 50% exceed it. | P50 latency is 100 ms, meaning 50% of all requests finish within 100 ms, while the remaining 50% take longer. |
| P90 latency | P90 latency means that 90% of all requests finish below this threshold, while the remaining 10% exceed it. | P90 latency is 200 ms, meaning 90% of all requests finish within 200 ms, while the remaining 10% take longer. |
| P99 latency | P99 latency means that 99% of all requests finish below this threshold, while the remaining 1% exceed it. | P99 latency is 500 ms, meaning 99% of all requests finish within 500 ms, while the remaining 1% take longer. |
Monitoring Metrics
| Metric ID | Metric | Description | Value Range | Unit | Conversion Rule | Dimension | Monitoring Period (Original Metric) |
| get_request_count | GET Requests | Number of GET requests made to all buckets and objects in the buckets of a region. | ≥ 0 | Count | N/A | bucket_name | 1 minute |
| put_request_count | PUT Requests | Number of PUT requests made to all buckets and objects in the buckets of a region. | ≥ 0 | Count | N/A | bucket_name | 1 minute |
| post_request_count | POST Requests | Number of POST requests made to all buckets and objects in the buckets of a region. | ≥ 0 | Count | N/A | bucket_name | 1 minute |
| head_request_count | HEAD Requests | Number of HEAD requests made to all buckets and objects in the buckets of a region. | ≥ 0 | Count | N/A | bucket_name | 1 minute |
| delete_request_count | DELETE Requests | Number of DELETE requests made to all buckets and objects in the buckets of a region. | ≥ 0 | Count | N/A | bucket_name | 1 minute |
| first_byte_latency | First Byte Download Delay | Average time from receiving a GET request to the time that the system starts to respond in a measurement period. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_count_4xx | 4XX Status Codes | Number of requests whose status code returned by the server is 4xx. | ≥ 0 | Count | N/A | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| request_count_5xx | 5XX Status Codes | Number of requests whose status code returned by the server is 5xx. | ≥ 0 | Count | N/A | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| total_request_latency | Average Request Latency | Average time from receiving a request to the time that the system response ends in a measurement period. | ≥ 0 | ms | N/A | tenant_id bucket_name bucket_name,api_name | 1 minute |
| total_request_callback_latency | Average Request Callback Latency | Average time required for calling a specific API in a request. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_count_per_second | Total TPS | Average number of requests per second in a statistical period. | ≥ 0 | Count/s | N/A | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| request_count_get_per_second | GET Request TPS | Average number of GET requests per second in a statistical period. | ≥ 0 | Count/s | N/A | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| request_count_put_per_second | PUT Request TPS | Average number of PUT requests per second in a statistical period. | ≥ 0 | Count/s | N/A | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| request_count_delete_per_second | DELETE Request TPS | Average number of DELETE requests per second in a statistical period. | ≥ 0 | Count/s | N/A | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| request_count_post_per_second | POST Request TPS | Average number of POST requests per second in a statistical period. | ≥ 0 | Count/s | N/A | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| request_count_head_per_second | HEAD Request TPS | Average number of HEAD requests per second in a statistical period. | ≥ 0 | Count/s | N/A | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| request_success_rate | Request Success Rate | Used to measure the availability of the storage service system. It refers to the percentage of non-server error requests (with status code 5xx returned) in the total request count. It is calculated as follows: (1 – 5xx requests/Total requests) x 100% | ≥ 0, ≤ 100 | % | N/A | tenant_id bucket_name bucket_name,api_name bucket_name,domain_name | 1 minute |
| effective_request_rate | Valid request rate | Validity of client requests. Percentage of the valid requests in the total requests. It is calculated as follows: (Number of client requests whose returned status code is 2xx or 3xx/Total number of requests) x 100% | ≥ 0, ≤ 100 | % | N/A | tenant_id bucket_name bucket_name,api_name | 1 minute |
| request_break_rate | Request interruption rate | Percentage of the number of requests interrupted by a client to the total number of requests. It is calculated as follows: (Number of requests interrupted by a client/Total number of requests) x 100% | ≥ 0, ≤ 100 | % | N/A | tenant_id bucket_name bucket_name,api_name | 1 minute |
| request_code_count | HTTP status code count | Measures the number of requests with status codes returned by the server. For details about the response status codes, see HTTP Status Codes. | ≥ 0 | Count | N/A | bucket_name bucket_name,api_name bucket_name,http_code bucket_name,api_name,http_code | 1 minute |
| api_request_count_per_second | API request TPS | Average number of specific API requests sent to all buckets and objects of a tenant per second within a statistical period. For details about the supported APIs, see Request APIs. | ≥ 0 | Count/s | N/A | bucket_name bucket_name,api_name | 1 minute |
| request_count_monitor_2XX | 2xx Status Codes | Times that the server responds to requests whose status codes are 2xx. | ≥ 0 | Count | N/A | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| request_count_monitor_3XX | 3xx Status Codes | Times that the server responds to requests whose status codes are 3xx. | ≥ 0 | Count | N/A | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| request_count_monitor_4XX | 4XX Status Codes | Times that the server responds to requests whose error codes are 4xx | ≥ 0 | Count | N/A | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| request_count_monitor_5XX | 5XX Status Codes | Times that the server responds to requests whose error codes are 5xx | ≥ 0 | Count | N/A | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| download_bytes | Total Download Bandwidth | Total size of objects downloaded per second in a measurement period. | ≥ 0 | byte/s | 1024 (IEC) | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| download_bytes_extranet | Download Bandwidth (Internet) | Total size of objects downloaded over the Internet per second in a measurement period. | ≥ 0 | byte/s | 1024 (IEC) | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| download_bytes_intranet | Download Bandwidth (Intranet) | Total size of objects downloaded over the Intranet per second in a measurement period. | ≥ 0 | byte/s | 1024 (IEC) | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| upload_bytes | Total Upload Bandwidth | Total size of objects uploaded per second in a measurement period. | ≥ 0 | byte/s | 1024 (IEC) | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| upload_bytes_extranet | Upload Bandwidth (Internet) | Total size of objects uploaded over the Internet per second in a measurement period. | ≥ 0 | byte/s | 1024 (IEC) | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| upload_bytes_intranet | Upload Bandwidth (Intranet) | Total size of objects uploaded over the Intranet per second in a measurement period. | ≥ 0 | byte/s | 1024 (IEC) | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| cdn_bytes | CDN Pull Bandwidth | The object size that CDN pulls per second from an origin server over the Internet in a given measurement period. | ≥ 0 | Byte/s | 1024 (IEC) | tenant_id bucket_name | 1 minute |
| download_traffic | Total Download Traffic | Total size of objects downloaded in a measurement period. | ≥ 0 | byte | 1024 (IEC) | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| download_traffic_extranet | Download Traffic (Internet) | Total size of objects downloaded over the Internet in a measurement period. NOTE: The Internet download traffic includes the CDN pull traffic. | ≥ 0 | byte | 1024 (IEC) | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| download_traffic_intranet | Download Traffic (Intranet) | Total size of objects downloaded over the Intranet in a measurement period. | ≥ 0 | byte | 1024 (IEC) | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| download_traffic_infrequent_access | Download Traffic (Infrequent Access) | Total size of Infrequent Access objects downloaded in a measurement period. | ≥ 0 | Byte | 1024 (IEC) | tenant_id bucket_name | 1 minute |
| upload_traffic | Total Upload Traffic | Total size of objects uploaded in a measurement period. | ≥ 0 | byte | 1024 (IEC) | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| upload_traffic_extranet | Upload Traffic (Internet) | Total size of objects uploaded over the Internet in a measurement period. | ≥ 0 | byte | 1024 (IEC) | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| upload_traffic_intranet | Upload Traffic (Intranet) | Total size of objects uploaded over the Intranet in a measurement period. | ≥ 0 | byte | 1024 (IEC) | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| cdn_traffic | CDN Pull Traffic | The total traffic generated when CDN pulls data from an origin server over the Internet in a given measurement period | ≥ 0 | Byte | 1024 (IEC) | tenant_id bucket_name | 1 minute |
| upload_transfer_rate | Average Upload Rate | Size of objects uploaded per second in a measurement period. | ≥ 0 | Bytes/s | 1024 (IEC) | bucket_name | 1 minute |
| download_transfer_rate | Average Download Rate | Size of objects downloaded per second. | ≥ 0 | Bytes/s | 1024 (IEC) | bucket_name | 1 minute |
| request_get_size_le_1MB_latency | GET Request Latency (Object ≤ 1 MB) | Average latency of GET requests against objects no larger than 1 MB in a measurement period. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_get_size_between_1MB_4MB_latency | GET Request Latency (1 MB < Object ≤ 4 MB) | Average latency of GET requests against objects that are larger than 1 MB but no larger than 4 MB in a measurement period. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_get_size_between_4MB_10MB_latency | GET Request Latency (4 MB < Object ≤ 10 MB) | Average latency of GET requests against objects that are larger than 4 MB but no larger than 10 MB in a measurement period. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_get_size_between_10MB_100MB_latency | GET Request Latency (10 MB < Object ≤ 100 MB) | Average latency of GET requests against objects that are larger than 10 MB but no larger than 100 MB in a measurement period. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_get_size_gt_100MB_latency | GET Request Latency (Object > 100 MB) | Average latency of GET requests against objects larger than 100 MB in a measurement period. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_put_size_le_1MB_latency | PUT Request Latency (Object ≤ 1 MB) | Average latency of PUT requests against objects no larger than 1 MB in a measurement period. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_put_size_between_1MB_4MB_latency | PUT Request Latency (1 MB < Object ≤ 4 MB) | Average latency of PUT requests against objects that are larger than 1 MB but no larger than 4 MB in a measurement period. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_put_size_between_4MB_10MB_latency | PUT Request Latency (4 MB < Object ≤ 10 MB) | Average latency of PUT requests against objects that are larger than 4 MB but no larger than 10 MB in a measurement period. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_put_size_between_10MB_100MB_latency | PUT Request Latency (10 MB < Object ≤ 100 MB) | Average latency of PUT requests against objects that are larger than 10 MB but no larger than 100 MB in a measurement period. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_put_size_gt_100MB_latency | PUT Request Latency (Object > 100 MB) | Average latency of PUT requests against objects larger than 100 MB in a measurement period. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| upload_server_request_latency | Total Server-Side Upload Latency | Average time required for uploading objects on the OBS server. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| upload_total_request_latency | Total E2E Upload Latency | Average end-to-end time required for uploading objects. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| download_server_request_latency | Total Server-Side Download Latency | Average time required for downloading objects on the OBS server. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| download_total_request_latency | Total E2E Download Latency | Average end-to-end time required for downloading objects. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_size_le_1MB_latency_p99 | P99 Request Latency (Object ≤ 1 MB) | P99 latency of the requests for objects no larger than 1 MB. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_size_between_1MB_4MB_latency_p99 | P99 Request Latency (1 MB < Object ≤ 4 MB) | P99 latency of the requests for objects from 1 MB (exclusive) to 4 MB. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_size_between_4MB_10MB_latency_p99 | P99 Request Latency (4 MB < Object ≤ 10 MB) | P99 latency of the requests for objects from 4 MB (exclusive) to 10 MB. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_size_between_10MB_100MB_latency_p99 | P99 Request Latency (10 MB < Object ≤ 100 MB) | P99 latency of the requests for objects from 10 MB (exclusive) to 100 MB. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_size_gt_100MB_latency_p99 | P99 Request Latency (Object > 100 MB) | P99 latency of the requests for objects larger than 100 MB. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_size_le_1MB_latency_p95 | P95 Request Latency (Object ≤ 1 MB) | P95 latency of the requests for objects no larger than 1 MB. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_size_between_1MB_4MB_latency_p95 | P95 Request Latency (1 MB < Object ≤ 4 MB) | P95 latency of the requests for objects from 1 MB (exclusive) to 4 MB. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_size_between_4MB_10MB_latency_p95 | P95 Request Latency (4 MB < Object ≤ 10 MB) | P95 latency of the requests for objects from 4 MB (exclusive) to 10 MB. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_size_between_10MB_100MB_latency_p95 | P95 Request Latency (10 MB < Object ≤ 100 MB) | P95 latency of the requests for objects from 10 MB (exclusive) to 100 MB. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_size_gt_100MB_latency_p95 | P95 Request Latency (Object > 100 MB) | P95 latency of the requests for objects larger than 100 MB. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_size_le_1MB_latency_p90 | P90 Request Latency (Object ≤ 1 MB) | P90 latency of the requests for objects no larger than 1 MB. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_size_between_1MB_4MB_latency_p90 | P90 Request Latency (1 MB < Object ≤ 4 MB) | P90 latency of the requests for objects from 1 MB (exclusive) to 4 MB. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_size_between_4MB_10MB_latency_p90 | P90 Request Latency (4 MB < Object ≤ 10 MB) | P90 latency of the requests for objects from 4 MB (exclusive) to 10 MB. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_size_between_10MB_100MB_latency_p90 | P90 Request Latency (10 MB < Object ≤ 100 MB) | P90 latency of the requests for objects from 10 MB (exclusive) to 100 MB. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_size_gt_100MB_latency_p90 | P90 Request Latency (Object > 100 MB) | P90 latency of the requests for objects larger than 100 MB. | ≥ 0 | ms | N/A | bucket_name | 1 minute |
| request_count_monitor_6XX | 6XX Status Codes | Number of requests whose status code returned by the server is 6xx. | ≥ 0 | Count | N/A | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| request_count_monitor_7XX | 7XX Status Codes | Number of requests whose status code returned by the server is 7xx. | ≥ 0 | Count | N/A | tenant_id bucket_name bucket_name,domain_name | 1 minute |
| get_mirror_range_bandwidths | Range Retrieval Bandwidth (Mirroring-based Back to Source) | Bandwidth for retrieving object ranges with mirroring-based back to source | ≥ 0 | Byte/s | 1024 (IEC) | tenant_id | 1 minute |
| get_mirror_fetch_bandwidths | Fetch Bandwidth (Mirroring-based Back to Source) | Bandwidth for fetches triggered by mirroring-based back to source | ≥ 0 | Byte/s | 1024 (IEC) | tenant_id | 1 minute |
| get_mirror_fetch_task_status | Fetch Status (Mirroring-based Back to Source) | Status of asynchronous fetches triggered by mirroring-based back to source. A value of 1 indicates that asynchronous fetches can be triggered, while a value less than 1 indicates that asynchronous fetches cannot be triggered. | ≤ 1 | Count | N/A | tenant_id | 1 minute |
| standard_request_upload_bandwidths | Avg. Bandwidth for Uploading Standard Objects | Average size of all Standard objects uploaded using PUT and POST per second in a measurement period | ≥ 0 | Byte/s | 1024 (IEC) | bucket_name | 1 minute |
| infrequent_request_upload_bandwidths | Avg. Bandwidth for Uploading Infrequent Access Objects | Average size of all Infrequent Access objects uploaded using PUT and POST per second in a measurement period | ≥ 0 | Byte/s | 1024 (IEC) | bucket_name | 1 minute |
| archive_request_upload_bandwidths | Avg. Bandwidth for Uploading Archive Objects | Average size of all Archive objects uploaded using PUT and POST per second in a measurement period | ≥ 0 | Byte/s | 1024 (IEC) | bucket_name | 1 minute |
| standard_request_delete_bytes | Avg. Bandwidth for Deleting Standard Objects | Average size of all Standard objects deleted using DELETE per second in a measurement period | ≥ 0 | Byte/s | 1024 (IEC) | bucket_name | 1 minute |
| infrequent_request_delete_bytes | Avg. Bandwidth for Deleting Infrequent Access Objects | Average size of all Infrequent Access objects deleted using DELETE per second in a measurement period | ≥ 0 | Byte/s | 1024 (IEC) | bucket_name | 1 minute |
| archive_request_delete_bytes | Avg. Bandwidth for Deleting Archive Objects | Average size of all Archive objects deleted using DELETE per second in a measurement period | ≥ 0 | Byte/s | 1024 (IEC) | bucket_name | 1 minute |
| standard_request_download_bandwidths | Avg. Bandwidth for Downloading Standard Objects | Average size of all Standard objects downloaded using GET per second in a measurement period | ≥ 0 | Byte/s | 1024 (IEC) | bucket_name | 1 minute |
| infrequent_request_download_bandwidths | Avg. Bandwidth for Downloading Infrequent Access Objects | Average size of all Infrequent Access objects downloaded using GET per second in a measurement period | ≥ 0 | Byte/s | 1024 (IEC) | bucket_name | 1 minute |
| archive_request_download_bandwidths | Avg. Bandwidth for Downloading Archive Objects | Average size of all Archive objects downloaded using GET per second in a measurement period | ≥ 0 | Byte/s | 1024 (IEC) | bucket_name | 1 minute |
| standard_download_request_count | Standard Object Download Requests | Average number of GET requests for Standard objects per second in a measurement period | ≥ 0 | Count | N/A | bucket_name | 1 minute |
| infrequent_download_request_count | Infrequent Access Object Download Requests | Average number of GET requests for Infrequent Access objects per second in a measurement period | ≥ 0 | Count | N/A | bucket_name | 1 minute |
| archive_download_request_count | Archive Object Download Requests | Average number of GET requests for Archive objects per second in a measurement period | ≥ 0 | Count | N/A | bucket_name | 1 minute |
| standard_upload_request_count | Standard Object Upload Requests | Average number of PUT and POST requests for Standard objects per second in a measurement period | ≥ 0 | Count | N/A | bucket_name | 1 minute |
| infrequent_upload_request_count | Infrequent Access Object Upload Requests | Average number of PUT and POST requests for Infrequent Access objects per second in a measurement period | ≥ 0 | Count | N/A | bucket_name | 1 minute |
| archive_upload_request_count | Archive Object Upload Requests | Average number of PUT and POST requests for Archive objects per second in a measurement period | ≥ 0 | Count | N/A | bucket_name | 1 minute |
| capacity_total | Total Used Storage Space | Measures the storage space occupied by all data. | ≥ 0 | Bytes | 1024 (IEC) | tenant_id bucket_name | 30 minutes |
| capacity_standard | Used Space - Standard Storage | Measures the storage space occupied by Standard data. | ≥ 0 | Bytes | 1024 (IEC) | tenant_id bucket_name | 30 minutes |
| capacity_infrequent_access | Used Space - Infrequent Access Storage | Measures the storage space occupied by Infrequent Access data. | ≥ 0 | Bytes | 1024 (IEC) | tenant_id bucket_name | 30 minutes |
| capacity_archive | Used Space - Archive Storage | Measures the storage space occupied by Archive data. | ≥ 0 | Bytes | 1024 (IEC) | tenant_id bucket_name | 30 minutes |
| capacity_deep_archive | Used Space - Deep Archive Storage | Measures the storage space occupied by Deep Archive data. | ≥ 0 | Byte | 1024 (IEC) | tenant_id bucket_name | 30 minutes |
| capacity_standard_single_az | Standard Storage (Single-AZ) | Space occupied by Standard data stored in a single AZ | ≥ 0 | Byte | 1024 (IEC) | tenant_id bucket_name | 30 minutes |
| capacity_standard_multi_az | Standard Storage (Multi-AZ) | Space occupied by Standard data stored in multiple AZs | ≥ 0 | Byte | 1024 (IEC) | tenant_id bucket_name | 30 minutes |
| capacity_infrequent_access_single_az | Infrequent Access Storage (Single-AZ) | Space occupied by Infrequent Access data stored in a single AZ | ≥ 0 | Byte | 1024 (IEC) | tenant_id bucket_name | 30 minutes |
| capacity_infrequent_access_multi_az | Infrequent Access Storage (Multi-AZ) | Space occupied by Infrequent Access data stored in multiple AZs | ≥ 0 | Byte | 1024 (IEC) | tenant_id bucket_name | 30 minutes |
| object_num_all | Total Number of Objects | Total number of objects (including folders and all file versions) stored in all storage classes | ≥ 0 | Count | N/A | tenant_id bucket_name | 30 minutes |
| object_num_standard_total | Number of Objects - Standard Storage | Total number of objects (including folders and all file versions) stored in the Standard storage class | ≥ 0 | Count | N/A | tenant_id bucket_name | 30 minutes |
| object_num_infrequent_access_total | Number of Objects - Infrequent Access Storage | Total number of objects (including folders and all file versions) stored in the Infrequent Access storage class | ≥ 0 | Count | N/A | tenant_id bucket_name | 30 minutes |
| object_num_archive_total | Number of Objects - Archive Storage | Total number of objects (including folders and all file versions) stored in the Archive storage class | ≥ 0 | Count | N/A | tenant_id bucket_name | 30 minutes |
| object_num_deep_archive_total | Number of Objects - Deep Archive Storage | Total number of objects (including folders and all file versions) stored in the Deep Archive storage classes | ≥ 0 | Count | N/A | tenant_id bucket_name | 30 minutes |
| object_num_standard_single_az | Standard Objects (Single-AZ) | Total number of Standard objects (including folders and all object versions) stored in a single AZ | ≥ 0 | Count | N/A | tenant_id bucket_name | 30 minutes |
| object_num_standard_multi_az | Standard Objects (Multi-AZ) | Total number of Standard objects (including folders and all object versions) stored in multiple AZs | ≥ 0 | Count | N/A | tenant_id bucket_name | 30 minutes |
| object_num_infrequent_access_single_az | Infrequent Access Objects (Single-AZ) | Total number of Infrequent Access objects (including folders and all object versions) stored in a single AZ | ≥ 0 | Count | N/A | tenant_id bucket_name | 30 minutes |
| object_num_infrequent_access_multi_az | Infrequent Access Objects (Multi-AZ) | Total number of Infrequent Access objects (including folders and all object versions) stored in multiple AZs | ≥ 0 | Count | N/A | tenant_id bucket_name | 30 minutes |
If a metric has multiple monitoring dimensions, you need to specify each dimension when you use an API to query this metric.
For example, the request_code_count metric represents the number of requests with status code 400 for the bucket test-bucket. This metric has the dimensions of bucket_name,http_code, where bucket_name indicates level 0 and http_code indicates level 1.
- To individually query this metric via API, specify the http_code dimension as follows:
dim.0=bucket_name,test-bucket&dim.1=http_code,400
test-bucket and 400 are the values of dimensions bucket_name and http_code, respectively. For details about how to obtain the values, see Dimensions.
- To query this metric via API in a batch operation, specify the http_code dimension as follows:
"dimensions": [ { "name": "bucket_name", "value": "test-bucket" }, { "name": "http_code", "value": "400" } ]test-bucket and 400 are the values of dimensions bucket_name and http_code, respectively. For details about how to obtain the values, see Dimensions.
Dimensions
| Key | Value |
| tenant_id | User dimension. The value is an account ID. To obtain the ID, see Obtaining Account, IAM User, Project, User Group, Region, and Agency Information. |
| bucket_name | Bucket dimension. The value is the bucket name. For details about the value, see Listing Buckets. |
| bucket_name,api_name | API dimension. For details about the value, see Table 5. |
| bucket_name,domain_name | Domain name dimension. The value is the domain name of the bucket to be accessed. For details about the value, see Viewing Bucket Information. |
| HTTP return code dimension. For details about the values, see Table 6. |
Request APIs
The following table lists the APIs supported by the bucket_name,api_name dimension in Table 4.
| ID | Name |
| LIST.BUCKETS | Listing Buckets |
| PUT.BUCKET | Creating a Bucket |
| LIST.BUCKET.OBJECTS | Listing Objects in a Bucket |
| LIST.BUCKET.OBJECTVERSIONS | Listing Objects in a Bucket (Versioning) |
| HEAD.BUCKET | Obtaining Bucket Metadata |
| GET.BUCKET.LOCATION | Obtaining Bucket Location |
| LIST.BUCKET.UPLOADS | Listing Multipart Uploads |
| POST.OBJECT.MULTIDELETE | Batch Deleting Objects |
| POST.OBJECT | Uploading Objects - POST |
| PUT.PART | Uploading Parts |
| PUT.PART.COPY | Copying Parts |
| DELETE.UPLOAD | Canceling a Part |
| LIST.OBJECT.UPLOAD | Listing Uploaded Parts of an Object |
| POST.UPLOAD.COMPLETE | Completing a Multipart Upload |
| POST.UPLOAD.INIT | Initiating a Multipart Upload |
| PUT.OBJECT | Uploading Objects |
| APPEND.OBJECT | Appending an Object |
| PUT.OBJECT.COPY | Copying an Object |
| DELETE.OBJECT | Deleting an Object |
| GET.OBJECT | Downloading an Object |
| HEAD.OBJECT | Heading objects |
| POST.OBJECT.RESTORE | Restoring an Object |
| PUT.OBJECT.METADATA | Modifying Object Metadata |
HTTP Status Codes
The following table lists the HTTP status codes supported by the tenant_id,http_code, bucket_name,api_name,http_code, and bucket_name,http_code dimensions in Table 4.
| HTTP Status Code | Description |
| 400 | Incorrect request packet format. |
| 301 | Permanent redirection. Retry according to the returned location. |
| 307 | Temporary redirection. When DNS updates, requests are redirected to the bucket. |
| 401 | Authentication and authorization failed. |
| 403 | Insufficient permission, access denied, limited MimeType, file type not allowed, or others |
| 404 | Requested resource not found |
| 405 | The specified method is not allowed against the requested resource. |
| 406 | CRC32 check failed for the uploaded data. |
| 408 | No read or write operations occurred within the timeout period of the socket connection between the client and the server. |
| 409 | There was a conflict with the current state of the requested resource. |
| 411 | The HTTP request did not include the required Content-Length header. |
| 412 | At least one of the specified preconditions was not met. |
| 413 | Incorrect size of the uploaded object. |
| 414 | The URI used in the request was too long. |
| 416 | The requested range could not be obtained. |
| 429 | There were too many requests in a short period of time. |
| 499 | The traffic on the client is interrupted or data transmission on the client times out. |
| 500 | Internal error. Please try again later. |
| 501 | The request method was not implemented by the server. |
| 503 | Service was unavailable because either an internal error occurred or high concurrency triggered connection throttling. |
| 579 | The object is successfully uploaded, but the callback fails. |
| 599 | The server fails to operate. |
| 612 | The specified resource does not exist or has been deleted. |
| 614 | The target resources already exist. |
| 650 | Access of monitoring callbacks to the origin server times out or fails. |
| 701 | The block expires, the segments are discontinuous, the total block size does not match the object size, or others. |
