Connecting to DLI and Submitting SQL Jobs Using JDBC
In Linux or Windows, you can connect to the DLI server using JDBC.
- Jobs submitted to DLI using JDBC can only run on the Spark engine.
- When JDBC 2.X is used, a maximum of 1,000 query results can be returned for users who started using DLI before May 2024. To view more job results, you are advised to enable the function of writing query results into buckets to query more than 1,000 data records from the job bucket. To use the function of writing query results into buckets, the following conditions must be met:
- On the DLI management console, choose Global Configuration > Project to configure the job bucket.
- Configure the job result storage policy in the DLI queue properties and enable the function of writing query results into buckets. For details, see Setting Queue Properties. The function of writing query results into buckets is currently in the limited use phase for some users. To use this function, submit a service ticket.
- Starting May 2024, new users can directly use DLI's function to write query results into buckets without needing to apply for it.
- For users who started using DLI before May 2024, to use this function, they must submit a service ticket to apply for it.
| DLI Data Type | JDBC Type | Java Type |
| INT | INTEGER | java.lang.Integer |
| STRING | VARCHAR | java.lang.String |
| FLOAT | FLOAT | java.lang.Float |
| DOUBLE | DOUBLE | java.lang.Double |
| DECIMAL | DECIMAL | java.math.BigDecimal |
| BOOLEAN | BOOLEAN | java.lang.Boolean |
| SMALLINT/SHORT | SMALLINT | java.lang.Short |
| TINYINT | TINYINT | java.lang.Short |
| BIGINT/LONG | BIGINT | java.lang.Long |
| TIMESTAMP | TIMESTAMP | java.sql.Timestamp |
| CHAR | CHAR | Java.lang.Character |
| VARCHAR | VARCHAR | java.lang.String |
| DATE | DATE | java.sql.Date |
Before using JDBC, perform the following operations:
- Getting authorized.
DLI uses the Identity and Access Management (IAM) to implement fine-grained permissions for your enterprise-level tenants. IAM provides identity authentication, permissions management, and access control, helping you securely access your HUAWEI CLOUD resources.
With IAM, you can use your HUAWEI CLOUD account to create IAM users for your employees, and assign permissions to the users to control their access to specific resource types.
Currently, roles (coarse-grained authorization) and policies (fine-grained authorization) are supported. For details about permissions and authorization operations, see the Data Lake Insight User Guide.
- Create a queue. Choose Resources > Queue Management. On the page displayed, click Buy Queue in the upper right corner. On the Buy Queue page displayed, select For general purpose for Type, that is, the compute resources of the Spark job.
If the user who creates the queue is not an administrator, the queue can be used only after being authorized by the administrator. For details about how to assign permissions, see Queue Permission Management.
- Install JDK 1.7 or later on the computer where JDBC is installed, and configure environment variables.
- Obtain the DLI JDBC driver package huaweicloud-dli-jdbc-<version>.zip by referring to Downloading and Installing the JDBC Driver Package. Decompress the package to obtain huaweicloud-dli-jdbc-<version>-jar-with-dependencies.jar.
- On the computer using JDBC, add huaweicloud-dli-jdbc-1.1.1-jar-with-dependencies.jar to the classpath path of the Java project.
- DLI JDBC provides two authentication modes, namely, token and AK/SK, to connect to DLI. For how to obtain the token and AK/SK, see Authentication.
- Run the Class.forName() command to load the DLI JDBC driver.
Class.forName("com.huawei.dli.jdbc.DliDriver");
- Call the GetConnection method of DriverManager to create a connection.
Connection conn = DriverManager.getConnection(String url, Properties info);
JDBC configuration items are passed using the URL. For details, see Table 2. JDBC configuration items can be separated by semicolons (;) in the URL, or you can dynamically set the attribute items using the Info object. For details, see Table 3.Table 2 Database connection parameters Parameter
url
The URL format is as follows:
jdbc:dli://<endPoint>/projectId? <key1>=<val1>;<key2>=<val2>...
- EndPoint indicates the DLI domain name. ProjectId indicates the project ID.
To obtain the endpoint corresponding to DLI, see Regions and Endpoints. To obtain the project ID, log in to the public cloud, hover over the username in the upper right corner, and select My Credentials.
- Other configuration items are listed after ? in the form of key=value. The configuration items are separated by semicolons (;). They can also be passed using the Info object.
Info
The Info object passes user-defined configuration items. If Info does not pass any attribute item, you can set it to null. The format is as follows: info.setProperty ("Attribute item", "Attribute value").
Table 3 Attribute items Item
Mandatory
Default Value
Supported dli-jdbc
queuename
Yes
Queue name of DLI.
dli-jdbc-1.x
dli-jdbc-2.x
databasename
No
Name of a database.
dli-jdbc-1.x
dli-jdbc-2.x
enginetype
No
spark
DLI queue type. Option:
spark: queue of the Spark engine.
The default value is spark.
dli-jdbc-1.x
dli-jdbc-2.x
catalog
No
If left unset, DLI catalog is used by default.
Metadata catalog name
- It is mandatory when a LakeFormation catalog is used. In this case, it indicates the name of the LakeFormation catalog used.
When querying the LakeFormation catalog, there must be a default database under the catalog.
- If left unset, a DLI catalog is used by default. You do not need to set this parameter when using the DLI catalog.
dli-jdbc-1.x
dli-jdbc-2.x
authenticationmode
No
token
Authentication mode. Currently, token- and AK/SK-based authentication modes are supported.
dli-jdbc-1.x
accesskey
Yes
AK that acts as the authentication key. For how to obtain the AK, see Authentication.
dli-jdbc-1.x
dli-jdbc-2.x
secretkey
Yes
SK that acts as the authentication key. For how to obtain the SK, see Authentication.
dli-jdbc-1.x
dli-jdbc-2.x
regionname
This parameter must be configured if authenticationmode is set to aksk.
Region name. For details, see Regions and Endpoints.
dli-jdbc-1.x
dli-jdbc-2.x
token
This parameter must be configured if authenticationmode is set to token.
Token-based authentication. For details, see Authentication.
dli-jdbc-1.x
charset
No
UTF-8
JDBC encoding mode.
dli-jdbc-1.x
dli-jdbc-2.x
usehttpproxy
No
false
Whether to use the access proxy.
dli-jdbc-1.x
proxyhost
This parameter must be configured if usehttpproxy is set to true.
Access proxy host.
dli-jdbc-1.x
dli-jdbc-2.x
proxyport
Access proxy port.
dli-jdbc-1.x
dli-jdbc-2.x
dli.sql.checkNoResultQuery
No
false
Whether to allow invoking the executeQuery API to execute statements (for example, DDL) that do not return results.
- Value false indicates that invoking of the executeQuery API is allowed.
- Value true indicates that invoking of the executeQuery API is not allowed.
dli-jdbc-1.x
dli-jdbc-2.x
jobtimeout
No
300
End time of the job submission. Unit: second
dli-jdbc-1.x
dli-jdbc-2.x
directfetchthreshold
No
1000
Check whether the number of returned results exceeds the threshold based on service requirements.
The default threshold is 1000.
dli-jdbc-1.x
- Create a Statement object, set related parameters, and submit Spark SQL to DLI.
Statement statement = conn.createStatement();
statement.execute("SET dli.sql.spark.sql.forcePartitionPredicatesOnPartitionedTable.enabled=true");
statement.execute("select * from tb1");
- Obtain the result.
ResultSet rs = statement.getResultSet();
- Display the result.
while (rs.next()) { int a = rs.getInt(1); int b = rs.getInt(2); } - Close the connection.
conn.close();
Example
- Hard coding AKs and SKs or storing them in code in plaintext poses significant security risks. You are advised to store them in encrypted form in configuration files or environment variables and decrypt them when needed to ensure security.
- In this example, the AK and SK stored in the environment variables are used. Specify the environment variables System.getenv("AK") and System.getenv("SK") in the local environment first.
import java.sql.*;
import java.util.Properties;
public class DLIJdbcDriverExample {
public static void main(String[] args) throws ClassNotFoundException, SQLException {
Connection conn = null;
try {
String url = "jdbc:dli://<endpoint>/<projectId>?databasename=db1;queuename=testqueue";
Properties info = new Properties();
info.setProperty("authenticationmode", "aksk");
info.setProperty("regionname", "<real region name>");
info.setProperty("accesskey", "<System.getenv("AK")>");
info.setProperty("secretkey", "<System.getenv("SK")>");
conn = DriverManager.getConnection(url, info);
int line = 0;
while (rs.next()) {
line ++;
System.out.println("Line:" + line + ":" + a + "," + b);
statement.execute("describe tb1");
ResultSet rs1 = statement.getResultSet();
line = 0;
while (rs1.next()) {
line ++;
String a = rs1.getString(1);
String b = rs1.getString(2);
} catch (SQLException ex) {
} finally {
if (conn != null) {
conn.close();
} What is your overall rating for this page?
