APIs Supported By the DLI JDBC Driver
The DLI JDBC driver supports multiple APIs of the JDBC standard, but some APIs cannot be invoked by users. For example, when transaction-related API prepareCall is invoked, the SQLFeatureNotSupportedException exception is reported. For details about the APIs, see the JDBC official website https://docs.oracle.com/javase/8/docs/api/java/sql/package-summary.html.
Supported APIs
The following tables list the APIs supported by the DLI JDBC driver and provide remarks on possible incompatibilities with the JDBC standard.
- Common signatures supported by Connection APIs
- Statement createStatement()
- PreparedStatement prepareStatement(String sql)
- void close()
- boolean isClosed()
- DatabaseMetaData getMetaData()
- PreparedStatement prepareStatement(String sql, int resultSetType, int resultSetConcurrency)
- Common signatures supported by Driver APIs
- Connection connect(String url, Properties info)
- boolean acceptsURL(String url)
- DriverPropertyInfo[] getPropertyInfo(String url, Properties info)
- String getColumnClassName(int column)
- int getColumnCount()
- int getColumnDisplaySize(int column)
- String getColumnLabel(int column)
- String getColumnName(int column)
- int getColumnType(int column)
- String getColumnTypeName(int column)
- int getPrecision(int column)
- int getScale(int column)
- boolean isCaseSensitive(int column)
- Common signatures supported by Statement APIs
- ResultSet executeQuery(String sql)
- int executeUpdate(String sql)
- boolean execute(String sql)
- void close()
- int getMaxRows()
- void setMaxRows(int max)
- int getQueryTimeout()
- void setQueryTimeout(int seconds)
- void cancel()
- ResultSet getResultSet()
- int getUpdateCount()
- Common signatures supported by PreparedStatement APIs
- void clearParameters()
- boolean execute()
- ResultSet executeQuery()
- int executeUpdate()
- PreparedStatement Set methods
- Common signatures supported by ResultSet APIs
- int getRow()
- boolean next()
- void close()
- int findColumn(String columnLabel)
- boolean wasNull()
- Get methods
- Common signatures supported by DatabaseMetaData APIs
- ResultSet getCatalogs()
DLI does not have the concept of Catalog, so an empty ResultSet is returned.
- ResultSet getColumns(String catalog, String schemaPattern,
- Connection getConnection()
- getTables(String catalog, String schemaPattern,String tableNamePattern, String types[])
This method does not use the Catalog parameter, and schemaPattern corresponds to the database concept of DLI.
- ResultSet getTableTypes()
- ResultSet getSchemas()
- ResultSet getSchemas(String catalog, String schemaPattern)
