Help Center/ Data Lake Insight/ User Guide/ Submitting a SQL Job Using JDBC/ Downloading and Installing the JDBC Driver Package
Updated on 2026-09-08 GMT+08:00
To connect to DLI, JDBC is utilized. You can obtain the JDBC installation package from Maven or download the JDBC driver file from the DLI management console.
This section describes how to connect to DLI and submit a SQL job using JDBC.
Obtaining the Server Connection Address
The address for connecting to DLI is in the format of jdbc:dli://<endPoint>/<projectId>. So, you need to obtain the endpoint and project ID.
Obtain the DLI endpoint from Regions and Endpoints. Specifically, log in to the public cloud, hover over your username in the upper right corner, and choose My Credentials from the shortcut menu. You can obtain the project ID on the displayed API Credentials tab page.
For users who started using DLI before May 2024, to use JDBC 2.X, they can only receive a maximum of 1,000 query results. To view more job results, you are advised to enable the function of writing query results into buckets to query more than 1,000 data records from the job bucket.
To use the function of writing query results into buckets, the following conditions must be met:
  • On the DLI management console, choose Global Configuration > Project to configure the job bucket.
  • Configure the job result storage policy in the DLI queue properties and enable the function of writing query results into buckets. For details, see Setting Queue Properties.
    The function of writing query results into buckets is currently in the limited use phase for some users. To use this function, submit a service ticket.
    • Starting May 2024, new users can directly use DLI's function to write query results into buckets without needing to apply for it.
    • For users who started using DLI before May 2024, to use this function, they must submit a service ticket to apply for it.
  • Method 1: Adding the JDBC driver using the Maven central repository
    The Maven central repository is part of the Apache Maven project that provides Java libraries and frameworks.
    When the JDBC retrieval method is not specified, the default approach is to add the JDBC driver using the Maven central repository.
    Use Maven to add the Maven configuration item on which huaweicloud-dli-jdbc depends. (This is the default operation and does not need to be configured separately.)
    3
    4
    5
     <dependency>
        <groupId>com.huawei.dli</groupId>
        <artifactId>huaweicloud-dli-jdbc</artifactId>
        <version>x.x.x</version>
     </dependency>
  • Method 2: Obtaining the JDBC driver using Maven to configure the Huawei image source
    When using Maven to manage project dependencies, you can modify the settings.xml file to configure the Huawei image source to obtain the JDBC driver.
    <mirror>
        <id>huaweicloud</id>
        <mirrorOf>*</mirrorOf>
        <url>https://mirrors.huaweicloud.com/repository/maven/</url>
    </mirror>
  • Method 3: Downloading the JDBC driver file from the DLI management console
    1. Log in to the DLI management console.
    2. Click SDK Download under the Common Links section on the right of the Overview page.
    3. On the DLI SDK DOWNLOAD page, select a driver and download it.
      Click huaweicloud-dli-jdbc-x.x.x to download a JDBC driver package.
      The JDBC driver package is named huaweicloud-dli-jdbc-<version>.zip. It can be used in all versions of all platforms (such as Linux and Windows) and depends on JDK 1.7 or later.
    4. The downloaded JDBC driver package contains .bat (Windows) or .sh (Linux/Mac) scripts, which are used to automatically install the JDBC driver to the local Maven repository.
      You can choose a script based on your OS to install the JDBC driver.
      • Windows: Double-click the .bat file or run the file in the CLI.
      • Linux/Mac: Run the .sh script.
Authentication
You need to be authenticated when using JDBC to create DLI driver connections.
JDBC currently supports two authentication modes: AK/SK-based and token-based. Token-based authentication is only supported by dli-jdbc-1.x. AK/SK-based authentication is recommended.
  • (Recommended) Generating an AK/SK
    2. Hover over the username in the upper right corner and select My Credentials from the shortcut list.
    3. The Projects area is displayed on the API Credentials tab page by default. Choose Access Keys in the navigation pane on the left.
    4. Click Create Access Key. In the dialog box that appears, configure Login Password and SMS Verification Code.
    5. Click OK to download the certificate.
    6. Once the certificate is downloaded, you can obtain the AK and SK information in the credentials file.
    Hard coding AKs and SKs or storing them in code in plaintext poses significant security risks. You are advised to store them in encrypted form in configuration files or environment variables and decrypt them when needed to ensure security.
  • Obtaining a token
    When using token-based authentication, you need to obtain the user token and configure the token information in the JDBC connection parameters. You can obtain the token as follows:
    1. Send POST https://<IAM_Endpoint>/v3/auth/tokens. To obtain the IAM endpoint and region name in the message body, see Regions and Endpoints.
      Here is an example request:
      Replace the content in italic in the sample code with the actual values. For details, see Identity and Access Management API Reference.
        "auth": {
          "identity": {
            "methods": [
              "password"
            "password": {
              "user": {
                "name": "username",
                "password": "password",
                "domain": {
                  "name": "domainname"
          "scope": {
            "project": {
              "id": "0aa253a31a2f4cfda30eaa073fee6477" //Assume that project_id is 0aa253a31a2f4cfda30eaa073fee6477.
    2. After the request is processed, the value of X-Subject-Token in the response header is the token value.
