- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Emergency Plan
You can create an emergency plan for a system fault that may occur and rectify the fault by referring to the emergency plan.
Creating an Emergency Plan
- Log in to COC.
- In the navigation pane on the left, choose Resilience Center > Emergency Plan. Click the Customized Plan tab.
Figure 1 Customized Plan tab page
- Click Create. On the displayed page, set the basic information about the emergency plan.
Figure 2 Creating an emergency plan
Table 1 Parameters for configuring basic information about an emergency plan Parameter
Emergency Plan Name
Customized emergency plan name
Enterprise Project
Enterprise project to which the emergency plan belongs. The default value is default.
Application
Application to which the emergency plan belongs
Recovery Duration
Expected fault recovery duration
Version
Version number
Summary
Description about the emergency plan
- Set the troubleshooting information. The emergency plan type can be set to Automation Plan or Document Plan.
- If Automation Plan is selected, you can select Scripts or Jobs for Handling Method.
Figure 3 Troubleshooting
- If Scripts is selected as the handling method, you can select custom scripts or common scripts as the associated scripts.
Figure 4 Associating a custom scriptFigure 5 Associating a common script
- If Jobs is selected as the handling method, you can select custom jobs or common jobs as the associated job.
Figure 6 Associating a custom jobFigure 7 Associating a common job
- If Document Plan is selected as the emergency plan type, you can select Not Involved, Scripts, or Jobs for Handling Method, enter the step name and description, and click Save.
Figure 8 Document plan steps
Viewing Emergency Plan Details
- Log in to COC.
- Click the name of an emergency plan to view the emergency plan details.
Figure 9 Viewing emergency plan details
Editing an Emergency Plan
- Log in to COC.
Figure 10 Customized Plan
- Locate the target plan and click Modify in the Operation column.
Figure 11 Modifying an Emergency Plan
Deleting an Emergency Plan
- Log in to COC.
- Locate the target emergency plan and click Delete in the Operation column.
Figure 12 Emergency plans
Figure 13 Deleting an emergency plan
