Reviewing a Closed Incident Ticket
After an incident is verified, a fault report is automatically created based on fault review rules. You can review the fault using this report to prevent it from happening again. The fault review information includes over 15 analysis items, such as fault symptoms, fault impacts, fault handling processes, root cause analyses, solutions, similar faults, and improvement measures.
By default, incidents of the P1, P2, P3, and P4 levels and incidents of all levels for which a war room is initiated need to be reviewed. This rule can be modified in Fault Review Rules.
Fault Review
- Log in to COC.
- In the navigation pane, choose Fault Management > Incidents.
- Click the All Incident Tickets tab.
- Locate the incident ticket to be reviewed and click Fault Report in the Fault Report/Status column.
The system automatically fills the basic information about the incident ticket in the review report, such as the fault symptom, fault handling process, and fault cause. The information can be modified.
- Click Edit Report.
- Set parameters for fault information.
Table 1 Parameters for fault information Parameter
Report Title
Specify the title of the fault report.
Report responsible person
Select the fault report owner.
Symptom
Enter the fault symptom.
The value can contain a maximum of 1,000 characters.
Affected Customers
Enter the affected customer.
Affected Application
Enter the impact description of the application.
You can add and delete affected applications.
- Set parameters in the Process area.
Table 2 Parameters for a handling process Parameter
Process
Set the fault handling time and description.
You can add and delete a handling process.
- Set parameters in the Root cause analysis area.
Table 3 Parameters for root cause analysis Parameter
Root Cause Analysis
Enter the root cause analysis of the fault.
Click Add File to upload attachments related to root cause analysis.
A maximum of 10 files can be uploaded. The supported file types are JPG, PNG, DOCX, TXT, and PDF. The size of the file to be uploaded cannot exceed 10 MB.
- Set parameters in the Monitoring & Alerting area.
Table 4 Parameters for monitoring and alarming Parameter
Is it prioritized over customer discovery
The options are Yes and No.
Alarm Ticket No.
This parameter is mandatory when Is it prioritized over customer discovery is set to Yes. You can add or delete alarm tickets.
- Set parameters in the Change area.
Table 5 Change parameters Parameter
Change Involved
Change Ticket No.
This parameter is mandatory when Change Involved is set to Yes. You can add and delete change tickets.
- Set parameters in the Solution area.
Table 6 Parameters of the solution Parameter
Short term solution (how to recover from faults)
Enter the short-term solution to the fault.
Click Add File to upload attachments related to the short-term solution.
Long term plan (how to avoid recurrence)
Enter the long-term solution to the fault.
Click Add File to upload attachments related to the long-term solution.
Application Resilience Related Planning and Analysis
Enter the application resilience planning and analysis.
Click Add File to upload attachments related to application resilience.
- Set parameters in the Failure Modes area.
Table 7 Failure mode parameters Parameter
Failure Mode Available
Failure Modes
This parameter is mandatory when Failure Mode Available is set to Yes. You can add or delete failure modes.
- Set parameters for a contingency plan.
Table 8 Parameters for a contingency plan Parameter
Contingency Plan Available
The options are Yes, No, and N/A.
Contingency Plans
This parameter is mandatory when Contingency Plan Available is set to Yes. You can add or delete contingency plans.
- Set the parameters for similar faults.
Table 9 Parameters for similar faults Parameter
Is there a similar fault
Incident Ticket No.
This parameter is mandatory when Is there a similar fault is set to Yes.
You can add or delete an incident ticket.
- Set parameters for fault drills.
Table 10 Parameters for fault drills Parameter
Have you conducted a fault drill
The options are Yes, No, and Not Involved.
Fault Drill
This parameter is mandatory when Have you conducted a fault drill is set to Yes.
You can add and delete fault drill tasks.
- Set parameters for improvement measures.
Table 11 Parameters for improvement measures Parameter
Product Improvement
Enter the product improvement details.
You can create or delete product improvement tickets.
Operations Improvement
Enter the operations improvement details.
You can create or delete O&M improvement tickets.
Management Improvement
Enter the management improvement details.
You can create or delete management improvement tickets.
- Click OK.
- In the displayed dialog box, set the fault review progress. The options are Reviewed, Reviewing, and Not reviewed.
- Click OK.
