- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Account Management
Account Management allows you to centrally manage human-machine accounts of Huawei Cloud ECSs, RDS DB instances, and middleware. Multiple accounts are collected in a unified manner to prevent risks such as forgetting the passwords of multiple resource accounts and leakage of passwords. Users can obtain passwords through Account Management.
Figure 1 Resource account management process
You can obtain the host password from the Accounts tab page only after you complete the resource account management process.
