Managing Cross-Account Resources
COC provides secure and reliable cross-account data aggregation and resource O&M capabilities. If your account is an enterprise account and is an administrator registered in the Organizations service or a delegated administrator of the COC service, you can manage resources of other accounts in the organization in a unified manner. In addition, you can view and manage all resources in the organization on the COC console.
A view consists of a group of filters. You can configure the filter criteria to access desired resources on Huawei Cloud in cross-account scenarios.
To create a view, you can set the basic view information and configure filter criteria such as organization unit and resource type.
Precautions
- A maximum of 10 views can be created.
- After a view is created, you need to manually synchronize resources in the current view.
- If the resources of an existing view have changed, you need to synchronize the resources again. For details, see Manually Synchronizing Resources.
Creating a View
- Log in to COC.
- In the navigation pane, choose Resources > Application and Resource Management.
- Click Cross-Account Resources and click View Management. Figure 2 View management
- On the view management page, click Create View.
- Set basic view information based on Table 1. Figure 3 Setting basic information
Table 1 Parameters for creating a view Parameter
Name
Customize a view name based on the naming rule.
The view name can contain 3 to 50 characters, including letters, digits, hyphens (-), and underscores (_).
Select Organization
Select the target organizational units.
An OU is a container of accounts. You can group accounts into an OU and apply policies to the OU based on your business requirements.
- Click Next. The page for selecting resources is displayed.
- Select the resource types that need to be managed across accounts. Figure 4 Selecting resources
- Click OK. The view is created.
- After synchronizing resources, you can view the resource information of the corresponding view in the resource list. Cross-account resources under management may only be centrally viewed and managed and cannot be directly invoked using the automated O&M capability.Figure 5 Viewing cross-account resources
Modifying a View
- Log in to COC.
- Click Cross-Account Resources and click View Management. Figure 6 View management
- Locate the row that contains the view you want to modify and click Modify in the Operation column.
- Modify the view by referring to Table 2.
Table 2 Parameters for modifying a view Parameter
Name
Select Organization
Select Resource
Select the target resource type.
- After confirming that the information is correct, click OK. The view is modified.
After the view is modified, you need to manually synchronize resources again.
Deleting a View
- Log in to COC.
- Click Cross-Account Resources and click View Management. Figure 7 View management
- Locate the view you want to delete and click Delete in the Operation column.
- In the displayed dialog box, click OK. The view is deleted.
After the view is deleted, it will no longer be displayed in the view list.
