Help Center/ Cloud Operations Center/ User Guide/ Resource Management/ Viewing Resource Details on the Resource Management Page
Updated on 2025-08-08 GMT+08:00
Resource List only displays some resource attributes. The following example shows how to query more details about a resource.
Precautions
  • Currently, Alibaba Cloud resource details cannot be viewed.
  • For on-premises IDCs, only VM resource details can be viewed.
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Select the cloud vendor whose resources are to be viewed.
    Huawei Cloud is selected by default.
  4. Select the resource type to be synchronized.
    By default, Elastic Cloud Server (ECS) is selected.
  5. Click the target DB instance to go to the DB instance details page.
    You can view the resource name, ID, enterprise project, region, cloud server information, application, group, and component. In addition, you can switch to the corresponding group page.
  6. Click View Resource Details.
    The resource service details page is displayed.
