Updated on 2025-11-06 GMT+08:00
Configuring the Priorities of Forwarding Rules for LoadBalancer Ingresses
When multiple ingresses share the same load balancer listener, you can prioritize forwarding rules according to the following guidelines:
  • For forwarding rules within the same ingress: If the kubernetes.io/elb.rule-priority-enabled annotation is set to true, forwarding rules are prioritized based on their order in the paths field in the ingress YAML file. Rules listed higher in the YAML file have a higher priority. If the kubernetes.io/elb.rule-priority-enabled annotation is not specified, the load balancer's sorting rules will apply.
  • For forwarding rules across different ingresses: The kubernetes.io/elb.ingress-order annotation is used to determine the priority. Additionally, kubernetes.io/elb.rule-priority-enabled is set to true by default. The rules are as follows:
    • The kubernetes.io/elb.ingress-order value ranges from 1 to 1000. A smaller value indicates a higher priority.
    • Ingresses with the kubernetes.io/elb.ingress-order annotation have a higher priority than those without the annotation.
    • If multiple ingresses are labeled with the kubernetes.io/elb.ingress-order annotation, they are prioritized by the annotation value. Within the same ingress, forwarding policies are then sorted by their listed sequence.
If the preceding annotations are not configured, the load balancer's sorting rules will apply, regardless of whether the forwarding rules belong to the same ingress or different ingresses under the same load balancer listener.
For more details, see Examples for Setting the Priorities of Forwarding Rules.
Figure 1 Customizing the priorities of forwarding rules
  • A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
    • v1.23: v1.23.15-r0 or later
    • v1.25: v1.25.10-r0 or later
    • v1.27: v1.27.7-r0 or later
    • v1.28: v1.28.5-r0 or later
    • v1.29: v1.29.1-r10 or later
    • Other clusters of later versions
  • An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
  • A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
Notes and Constraints
Using kubectl
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    The following shows an example configuration using an existing load balancer:
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/elb.port: '88'    # The port on the interconnected load balancer
        kubernetes.io/elb.id: 2c623150-17bf-45f1-ae6f-384b036f547e    # The ID of an existing load balancer
        kubernetes.io/elb.class: performance    # The load balancer type, which can only be performance
        kubernetes.io/elb.ingress-order: '1'    # The priority of forwarding rules across different ingresses
        kubernetes.io/elb.rule-priority-enabled: 'true'   # The forwarding rules of an ingress are prioritized based on the forwarding rule sequence in paths.
      rules:
        - host: ''
          http:
            paths:
              - path: /test1  # Define a forwarding rule.
                backend:  # The backend Service associated with the rule. The value provided is only an example and can be modified as needed.
                  service:
                    port:
                      number: 8081
                property:
              - path: /test2  # Define a forwarding rule.
                  service:
                    port:
                      number: 8081
                property:
      ingressClassName: cce
    Table 1 Annotations for configuring the priorities of forwarding rules
    Type
    String
    The sequence of forwarding rules across different ingresses. The value ranges from 1 to 1000. A smaller value indicates a higher priority. The priority of a forwarding rule must be unique under the same load balancer listener.
    This parameter is available only for dedicated load balancers.
    • When this annotation is configured, the kubernetes.io/elb.rule-priority-enabled annotation is enabled by default. The forwarding rules of each ingress will be sorted.
    • The priority specified in the kubernetes.io/elb.ingress-order annotation does not directly equate to the priority of the load balancer's forwarding policy. This annotation can be used to prioritize different ingresses. Ingresses with this annotation have a higher priority than those without the annotation. If multiple ingresses are labeled with this annotation, they are prioritized by the annotation value. A smaller value indicates a higher priority. For more details, see Examples for Setting the Priorities of Forwarding Rules.
    String
    This parameter can only be set to true, indicating to sort the forwarding rules of an ingress. The forwarding rules are prioritized based on the order they were added during ingress creation. A higher-listed rule indicates a higher priority.
    If this parameter is not configured, the default sorting of the forwarding rules on the load balancer will be used. After this parameter is enabled, it cannot be disabled.
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME          CLASS    HOSTS     ADDRESS          PORTS   AGE
    ingress-test  cce      *         121.**.**.**     88      10s
Assume the following configurations: The kubernetes.io/elb.ingress-order value of ingress A (ingress-a) is set to 1, and this ingress has forwarding rules A and B. The kubernetes.io/elb.ingress-order value of ingress B (ingress-b) is set to 2, and this ingress has forwarding rules C and D.
The following table lists the sorting order of the load balancer's forwarding policies when ingresses A and B access the same load balancer port.
Priority
Forwarding Rule
Ingress
A
ingress-a
2
B
ingress-a
3
C
ingress-b
4
D
ingress-b
Figure 2 Example 1 of the sorting order of the load balancer's forwarding policies
If you add rule E to ingress-b and list the rule ahead of rules C and D, modify the YAML configuration for ingress-b as follows:
kind: Ingress
  namespace: default
  annotations:
    kubernetes.io/elb.id: f7fb2aa8-34af-48fb-b451-16e8f675ff45   # The ID of the existing load balancer
    kubernetes.io/elb.class: performance    # The type of the existing load balancer, which can only be performance
    kubernetes.io/elb.ingress-order: '2'    # The priority of forwarding rules across different ingresses
  rules:
    - host: ''
      http:
        paths:
          - path: /E  # Define forwarding rule E.
              service:
                port:
                  number: 80
            property:
          - path: /C  # Define forwarding rule C.
              service:
                port:
                  number: 80
            property:
          - path: /D  # Define forwarding rule D.
              service:
                port:
                  number: 80
            property:
The following table lists the sorting order of the load balancer's forwarding rules.
Priority
Forwarding Rule
Ingress
A
ingress-a
2
B
ingress-a
3
E
ingress-b
4
C
ingress-b
5
D
ingress-b
Figure 3 Example 2 of the sorting order of the load balancer's forwarding policies
