Configuring a Blocklist/Trustlist Access Policy for a LoadBalancer Ingress
You can add IP addresses to a trustlist or blocklist to control access to a listener of a LoadBalancer ingress.
- Trustlist: Only the IP addresses in the list can access the listener.
- Blocklist: The IP addresses in the list are not allowed to access the listener.
- A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
- v1.23: v1.23.12-r0 or later
- v1.25: v1.25.7-r0 or later
- v1.27: v1.27.4-r0 or later
- v1.28: v1.28.2-r0 or later
- Other clusters of later versions
- An IP address group has been created on the ELB console. For details, see Creating an IP Address Group.
Notes and Constraints
- After a blocklist or trustlist access policy is configured, if you delete the blocklist or trustlist access policy configuration on the CCE console or delete the target annotation from the YAML file, the configuration on the ELB will be retained.
- If multiple ingresses share the same external port on a load balancer, you are advised to use the same blocklist/trustlist configuration for these ingresses. Otherwise, the configuration of the first created ingress will take precedence. For details, see Configuring Multiple Ingresses to Use the Same External ELB Port.
You can configure a blocklist/trustlist access policy for an ingress using either the CCE console or kubectl.
- Choose Services & Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
- Configure ingress parameters.
This example explains only key parameters for configuring blocklist/trustlist access policies. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
Table 1 Key parameters Parameter
Example
Name
Enter an ingress name.
ingress-test
Load Balancer
Select a load balancer to be associated with the ingress or automatically create a load balancer. A load balancer can be dedicated or shared.
Dedicated
Listener
- Frontend Protocol: HTTP and HTTPS are available.
- External Port: specifies the port of the load balancer listener.
- Access Control
- Inherit ELB Configurations: CCE does not modify the existing access control configurations on the ELB console.
- Allow all IP addresses: No access control is configured.
- Trustlist: Only the selected IP address group can access the load balancer.
- Blocklist: The selected IP address group cannot access the load balancer.
NOTE:For clusters of v1.25.16-r10, v1.27.16-r10, v1.28.15-r0, v1.29.10-r0, v1.30.6-r0, v1.31.1-r0, or later, when using a dedicated load balancer, you can select a maximum of five IP address groups at a time for access control.
Forwarding Policy
- Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through the IP address. Ensure that the domain name has been registered and licensed. Once a forwarding policy is configured with a domain name specified, you must use the domain name for access.
- Path Matching Rule: Select Prefix match, Exact match, or RegEx match.
- Path: Enter the path provided by a backend application for external access. The path added must be valid in the backend application, or the forwarding cannot take effect.
- Destination Service: Select an existing Service. Only Services that meet the requirements are automatically displayed in the Service list. If no Service meets the requirements, create one by following the operations provided in Services Supported by Ingresses.
- Destination Service Port: Select the access port of the destination Service.
- Domain Name: You do not need to configure this parameter.
- Path Matching Rule: Prefix match
- Path: /
- Destination Service: nginx
- Destination Service Port: 80
Figure 1 Configuring a blocklist/trustlist access policy - Click OK.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file named ingress-test.yaml. The file name can be customized.
vi ingress-test.yaml
An example YAML file of an ingress created using an existing load balancer is as follows:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.id: <your_elb_id> # Load balancer ID. Replace it with the actual value. kubernetes.io/elb.class: performance # Load balancer type kubernetes.io/elb.port: '80' # External port of the load balancer listener kubernetes.io/elb.acl-id: <your_acl_id> # ID of an IP address group for accessing a load balancer kubernetes.io/elb.acl-status: 'on' # Enable access control. kubernetes.io/elb.acl-type: 'white' # Trustlist for access control spec: rules: - host: '' http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with the name of your target Service. port: number: 80 # Replace 80 with the port number of your target Service. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cce
Table 2 Annotations for ELB access control Parameter
Type
String
- If this parameter is not specified, CCE does not modify access control on the ELB.
- If this parameter is left empty, all IP addresses are allowed to access the load balancer.
- If this parameter is set to the IP address group ID of the load balancer, access control is enabled and you need to configure an IP address blocklist or trustlist for the load balancer. Additionally, you need to configure both kubernetes.io/elb.acl-status and kubernetes.io/elb.acl-type.
For clusters of v1.25.16-r10, v1.27.16-r10, v1.28.15-r0, v1.29.10-r0, v1.30.6-r0, v1.31.1-r0, or later, when using a dedicated load balancer, you can select a maximum of five IP address groups at a time, separated by commas (,).
How to obtain:
Log in to the ELB console, choose Elastic Load Balance > IP Address Groups, and copy the ID of the target IP address group. For details, see Creating an IP Address Group.
String
This parameter is mandatory when you configure an IP address blocklist or trustlist for a load balancer. Options:
- on or true: Access control is enabled.
- off or false: Access control is disabled.
String
- black: indicates a blocklist. The selected IP address group cannot access the load balancer.
- white: indicates a trustlist. Only the selected IP address group can access the load balancer.
- Create an ingress.
If information similar to the following is displayed, the ingress has been created:
ingress/ingress-test created
- Check the created ingress.
kubectl get ingress
NAME CLASS HOSTS ADDRESS PORTS AGE ingress-test cce * 121.**.**.** 80 10s
