xGPU View
A GPU can be virtualized into xGPUs. The xGPU view displays the GPU memory and compute allocation rate of xGPUs from multiple perspectives, such as nodes, GPUs, and containers, so you can better monitor the GPU.
Metric Description
Metric |
Unit |
Description |
Cluster - xGPU Device GPU Memory Usage |
GPU memory usage of all xGPU devices in the cluster. Formula: Used GPU memory of all xGPU devices in the cluster/Total GPU memory of the cluster |
Cluster - xGPU Device GPU Compute Usage |
GPU compute usage of all xGPU devices in the cluster. Formula: Used GPU compute of all xGPU devices in the cluster/Total GPU compute of the cluster |
Node - xGPU Device GPU Memory Usage |
GPU memory usage of all xGPU devices on the node. Formula: Used GPU memory of all xGPU devices on the node/Total GPU memory of the node |
Node - xGPU Device GPU Compute Usage |
GPU compute usage of all xGPU devices on the node. Formula: Used GPU compute of all xGPU devices on the node/Total GPU compute of the node |
Node - Number of xGPU Devices |
N/A |
The number of xGPU devices on the node. |
Node - Allocated GPU Memory of xGPU Devices |
byte |
Maximum GPU memory that can be used by all xGPU devices on the node. |
GPU - xGPU Device GPU Memory Usage |
Percentage of used GPU memory of all xGPU devices on the GPU. Formula: Used GPU memory of all xGPU devices on the GPU/Total GPU memory of the GPU |
GPU - Allocated GPU Memory of xGPU Devices |
byte |
Maximum GPU memory that can be used by all xGPU devices on the GPU. |
GPU - GPU Memory Allocation Rate of xGPU Devices |
Percentage of the maximum GPU memory that can be used by all xGPU devices on the GPU. Formula: Maximum GPU memory that can be used by all xGPU devices on the GPU/Total GPU memory of the GPU |
GPU - xGPU Device GPU Compute Usage |
Percentage of the GPU compute used by all xGPU devices on the GPU. Formula: GPU compute used by all xGPU devices on the GPU/Total GPU compute of the GPU |
GPU - Number of xGPU Devices |
N/A |
The number of xGPU devices created on the GPU. |
GPU - Scheduling Policy |
N/A |
GPU - Number of Unhealthy xGPU Devices |
N/A |
The number of unhealthy xGPU devices on the GPU. |
Allocated Container GPU Memory |
byte |
Maximum GPU memory that can be used by a container. |
Container GPU Compute Usage |
GPU compute used by containers on the xGPU device. Formula: GPU compute used by containers on the xGPU device/Total GPU compute of the xGPU device |
Used Container GPU Memory |
byte |
GPU memory used by containers on the xGPU device. |
Container GPU Memory Usage |
GPU compute used by containers on the xGPU device. Formula: GPU memory used by containers on the xGPU device/Total GPU memory of the xGPU device |
Metric List
Metric |
Type |
Description |
xgpu_memory_total |
Gauge |
Total xGPU memory. |
xgpu_memory_used |
Gauge |
Used xGPU memory. |
xgpu_core_percentage_total |
Gauge |
Total xGPU compute. |
xgpu_core_percentage_used |
Gauge |
xGPU compute usage. |
gpu_schedule_policy |
Gauge |
There are three GPU modes.
xgpu_device_health |
Gauge |
Health of an xGPU device. Currently, the virtualization domain does not provide a specific interface to check the xGPU health. The xGPU health is based on the health of the GPU where the xGPU device is located. The value 0 indicates that the xGPU is healthy, and the value 1 indicates that the xGPU is unhealthy. |
