GPU View
GPU resource metrics are used to measure GPU performance and usage, including the GPU usage, temperature, and GPU memory, so you can better monitor the GPU.
Chart Description
         Metric  |
         Unit  |
         Description  |
         Cluster - GPU Memory Usage  |
         GPU memory usage of the cluster. Formula: Used GPU memory of the cluster/Total GPU memory of the cluster  |
         Cluster - GPU Compute Usage  |
         GPU compute usage of the cluster. Formula: Used GPU compute of the cluster/Total GPU compute of the cluster  |
         Node - Used GPU Memory  |
         byte  |
         GPU memory used by the node.  |
         Node - GPU Compute Usage  |
         GPU compute usage of each node. Formula: Total GPU compute used by containers on the node/Total GPU compute of the node  |
         Node - GPU Memory Usage  |
         GPU memory usage of each node. Formula: Total GPU memory used by containers on the node/Total GPU memory of the node  |
         GPU - Used GPU Memory  |
         byte  |
         Total GPU memory used by containers on the GPU  |
         GPU - GPU Compute Usage  |
         GPU compute usage of each graphics card. Formula: Total GPU compute used by containers on the graphics card/Total GPU compute of the graphics card  |
         GPU - Temperature  |
         °C  |
         Temperature of each GPU.  |
         GPU - Memory Clock  |
         Hz  |
         Memory clock of each GPU.  |
         GPU - PCIe Bandwidth  |
         byte/s  |
         PCle bandwidth of each GPU.  |
Metric List
          Metric  |
          Type  |
          Description  |
          cce_gpu_gpu_utilization  |
          Gauge  |
          GPU compute usage.  |
          cce_gpu_memory_utilization  |
          Gauge  |
          GPU memory usage.  |
          cce_gpu_memory_used  |
          Gauge  |
          Used GPU memory.  |
          cce_gpu_memory_total  |
          Gauge  |
          Total GPU memory.  |
          cce_gpu_memory_free  |
          Gauge  |
          Free GPU memory.  |
          cce_gpu_memory_clock  |
          Gauge  |
          The speed at which the GPU memory operates.  |
          cce_gpu_gpu_temperature  |
          Gauge  |
          GPU temperature.  |
          cce_gpu_pcie_link_bandwidth  |
          Gauge  |
          GPU PCIe bandwidth.  |
          cce_gpu_pcie_throughput_rx  |
          Gauge  |
          GPU PCIe RX bandwidth.  |
