API Server View
The API server view displays information about requests, work queues, and resources, so you can better monitor the API server.
Metric Description
API server metrics include request metrics, work queue metrics, and resource metrics. You can view these metrics in the following tables.
Metric |
Unit |
Description |
Alived |
N/A |
The number of live component instances. |
QPS |
request/s |
The number of requests with different response codes per second. |
Request Success Rate (Read) |
The percentage of read requests whose response code is 20x per second. |
Requests Being Processed |
N/A |
The number of requests being processed by the API server. |
Request Rate (Read) |
request/s |
The number of read requests with different response codes per second. |
Request Error Rate (Read) |
The percentage of read requests that are rejected per second. |
P99 Request Latency (Read) |
ms |
P99 latency of read operations. |
Request Rate (Write) |
request/s |
The number of write requests with different response codes per second. |
Request Error Rate (Write) |
The percentage of write requests that are rejected per second. |
P99 Request Latency (Write) |
ms |
P99 latency of write operations. |
Metric |
Unit |
Description |
Work Queue Growth Rate |
N/A |
The number of additions handled by the API server work queue per second. |
Work Queue Depth |
N/A |
Depth of a work queue. |
Work Queue Latency (P99) |
ms |
P99 latency of each API server request in a work queue. |
Metric |
Unit |
Description |
Used Memory |
byte |
Memory used by the API server. |
Used CPU |
core |
CPU used by the API server. |
Goroutines |
N/A |
The number of goroutines. |
Metric List
The following is the metric list of the API server view.
Metric |
Type |
Description |
up |
Gauge |
Component status. |
apiserver_request_total |
Counter |
Counter of API server requests broken out for code and other items. |
go_goroutines |
Gauge |
The number of goroutines that currently exist. |
apiserver_current_inflight_requests |
Gauge |
Maximum number of requests that were being actively served in the last one-second window. |
apiserver_request_duration_seconds_bucket |
Histogram |
Latency for each request to the API server in seconds. |
workqueue_depth |
Gauge |
Current depth of a work queue. |
workqueue_adds_total |
Counter |
Total number of additions handled by a work queue. |
workqueue_queue_duration_seconds_bucket |
Histogram |
How long in seconds an item stays in a work queue before being requested. |
process_resident_memory_bytes |
Gauge |
Resident memory size in bytes. |
process_cpu_seconds_total |
Counter |
Total user and system CPU time spent in seconds. |
