- Billing
- Getting Started
User Guide
- Overview
- Permissions Management
- Environment Management
- Application Management
- Component Management
- Instance Management
- Component Configurations
- Component O&M
- System Settings
- Key Operations Recorded by CTS
Best Practices
- CAE Best Practices
- Using CAE to Host Nginx Static File Servers
- Interconnecting GitLab with Jenkins for Automatic Build and Deployment on CAE
- Deploying Components Based on the Dependency Sequence Using the Jenkins Pipeline
- Deploying Spring Cloud Applications to CAE to Automatically Connect to the Nacos Engine
- Graceful Startup of a Spring Cloud Application
- Health Check
- Lifecycle Management
- Sending Event Alarms to WeCom
Connecting to the CodeArts Pipeline to Automatically Upgrade CAE Components
- Overview
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to a CodeArts Release Repo
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to the OBS Bucket
- Upgrading a CAE Component After Uploading an Image Built Using the Pipeline to the SWR Image Repository
- Configuring PromQL to Implement Custom Auto Scaling
- Configuring the Interconnection Between CAE and DEW to Help Applications Obtain Encrypted Secrets from DEW
- Deploying ASP.NET Core Applications to CAE
- Connecting the Network Through Enterprise Routes
- API Reference
- Component Management FAQs
Component Configuration FAQs
- Is Manual Scaling Still Effective When a Scaling Policy Is Configured?
- Can Components Be Scaled Without a Scaling Policy?
- Why Is My Instance Abnormal After Cloud Storage Is Configured?
- What Do I Do If a Component Becomes Not Ready?
- How Does CAE Support Dark Launch?
- How Do I Provide Prometheus Metrics for a Java Application?
- System Configuration FAQs
- Service Resources FAQs
Authorizing Cloud Storage
Cloud storage is a service that provides storage for applications. CAE supports multiple types of cloud storage mounting. Cloud storage can be mounted to containers to ensure application reliability.
After authorization, the cloud storage will be used by each component, but must be configured in the corresponding component configuration.
Authorizing a Parallel File System
- This service supports only authorization and creation of parallel file systems with multi-AZ data redundancy storage and Standard storage.
- Before authorizing a parallel file system, ensure its object data is backed up or out of use, and not occupied by other services (such as CTS and Cloud Eye).
- Parallel file systems are charged separately. For details, see Product Pricing Details.
- Log in to CAE.
- Choose System Settings.
- Click Edit in the Cloud Storage Authorizations module.
- Click Authorize Parallel File System.
- (Optional) To create a parallel file system, click Create Parallel File System, enter a name, and click OK.
- Select the created parallel file system. You can also enter a keyword in the search box above the list to filter data.
- Click Authorize.
- In the displayed dialog box, enter the AK/SK and click OK.
You can click Obtain Access Key to obtain the AK/SK. For details, see Access Keys.
If your environment was created before April 20, 2024, skip this step.
- If "Authorization successful" is displayed, the parallel file system has been authorized.
Authorizing a Bucket
- This service supports only authorization and creation of Standard buckets.
- Before authorizing object storage, ensure its data is backed up or out of use, and not occupied by other services (such as CTS and Cloud Eye).
- Buckets are charged separately. For details, see Pricing Details.
- Log in to CAE.
- Click Authorize Bucket.
- (Optional) To create a bucket, clickCreate Bucket, enter a name, and click OK.
Figure 1 Authorizing a bucket
- Select the created bucket. You can also enter a keyword in the search box above the list to filter data.
- Click Authorize.
- If "Authorization successful" is displayed, the bucket has been authorized.
Unbinding Cloud Storage
If the authorized cloud storage has been bound to a component, choose Component Configurations > Cloud Storage to delete the mounted data of the component before unbinding the cloud storage. For details, see Deleting a Cloud Storage Mounting Configuration.
- Log in to CAE.
- Select the target cloud storage and click Unbind in the Operation column.
