Configuring a LoadBalancer Ingress Using Annotations
You can add annotations to a YAML file for more advanced ingress functions. This section describes the annotations that can be used when you create a LoadBalancer ingress.
Interconnection with ELB
Table 1 Annotations for interconnecting with ELB
Type
Supported Cluster Version
kubernetes.io/elb.class
String
Select a proper load balancer type.
  • performance: dedicated load balancer, which can be used only in clusters of v1.17 and later.
v1.9 or later
kubernetes.io/ingress.class
String
  • cce: A proprietary LoadBalancer ingress is used.
  • nginx: Nginx Ingress is used.
This parameter is mandatory when an ingress is created by calling the API.
For clusters of v1.23 or later, use the parameter ingressClassName. For details, see Using kubectl to Create a LoadBalancer Ingress.
Only clusters of v1.21 or earlier
kubernetes.io/elb.port
String
This parameter indicates the external port registered with the address of the LoadBalancer Service.
The value ranges from 1 to 65535.
Some ports are high-risk ports and are blocked by default, for example, port 21.
v1.9 or later
kubernetes.io/elb.id
String
Mandatory when an existing load balancer is to be interconnected.
ID of a load balancer.
How to obtain:
On the management console, click Service List, and choose Networking > Elastic Load Balance. Click the name of the target load balancer. On the Summary tab page, find and copy the ID.
v1.9 or later
kubernetes.io/elb.ip
String
Service address of a load balancer. The value can be the public IP address of a public network load balancer or the private IP address of a private network load balancer.
v1.9 or later
kubernetes.io/elb.autocreate
Table 9 Object
Mandatory when load balancers are automatically created.
Example
  • If a public network load balancer will be automatically created, set this parameter to the following value:
    '{"type":"public","bandwidth_name":"cce-bandwidth-1551163379627","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_bgp","name":"james"}'
  • If a private network load balancer will be automatically created, set this parameter to the following value:
    {"type":"inner","name":"A-location-d-test"}
v1.9 or later
kubernetes.io/elb.enterpriseID
String
Optional when load balancers are automatically created.
Clusters of v1.15 and later versions support this field. In clusters earlier than v1.15, load balancers are created in the default project by default.
This parameter indicates the ID of the enterprise project in which the ELB load balancer will be created.
If this parameter is not specified or is set to 0, resources will be bound to the default enterprise project.
How to obtain:
Log in to the management console and choose Enterprise > Project Management on the top menu bar. In the list displayed, click the name of the target enterprise project, and copy the ID on the enterprise project details page.
v1.15 or later
kubernetes.io/elb.subnet-id
String
ID of the subnet where the cluster is located. The value can contain 1 to 100 characters.
  • Mandatory when a cluster of v1.11.7-r0 or earlier is to be automatically created.
  • Optional for clusters later than v1.11.7-r0.
Mandatory for clusters earlier than v1.11.7-r0
Discarded in clusters later than v1.11.7-r0
The following shows how to use the preceding annotations:
Using HTTP/2
Table 2 Annotations of using HTTP/2
Type
kubernetes.io/elb.http2-enable
String
Whether HTTP/2 is enabled. Request forwarding using HTTP/2 improves the access performance between your application and the load balancer. However, the load balancer still uses HTTP/1.x to forward requests to the backend server.
Options:
  • true: enabled
  • false: disabled (default value)
Note: HTTP/2 can be enabled or disabled only when the listener uses HTTPS. This parameter is invalid and defaults to false when the listener protocol is HTTP.
v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later
For details, see Configuring HTTP/2 for a LoadBalancer Ingress.
Configuring ELB Certificates
Table 3 ELB certificate annotations
Type
kubernetes.io/elb.tls-certificate-ids
String
ELB certificate IDs, which are separated by comma (,). The list length is greater than or equal to 1. The first ID in the list is the server certificate, and the other IDs are SNI certificates in which a domain name must be contained.
To obtain the certificate, log in to the CCE console, choose Service List > Networking > Elastic Load Balance, and click Certificates in the navigation pane. In the load balancer list, copy the ID under the target certificate name.
v1.19.16-r2, v1.21.5-r0, v1.23.3-r0, or later
For details, see Using the ELB Certificate.
Interconnecting with HTTPS Backend Services
Table 4 Annotations for interconnecting with HTTPS backend services
Type
kubernetes.io/elb.pool-protocol
String
To interconnect with HTTPS backend services, set this parameter to https.
v1.23.8, v1.25.3, or later
For details, see Configuring HTTPS Backend Services for a LoadBalancer Ingress.
Configuring Timeout for an Ingress
Table 5 Annotations of configuring ingress redirection rules
Type
kubernetes.io/elb.keepalive_timeout
String
Timeout for client connections. If there are no requests reaching the load balancer during the timeout duration, the load balancer will disconnect the connection from the client and establish a new connection when there is a new request.
Value:
  • For TCP listeners, the value ranges from 10 to 4000 (in seconds). The default value is 300.
  • For HTTP or HTTPS listeners, the value ranges from 0 to 4000 (in seconds). The default value is 60.
For UDP listeners, this parameter does not take effect.
Dedicated load balancers: v1.19.16-r30, v1.21.10-r10, v1.23.8-r10, v1.25.3-r10, or later
Shared load balancers: v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later
kubernetes.io/elb.client_timeout
String
Timeout for waiting for a request from a client. There are two cases:
  • If the client fails to send a request header to the load balancer during the timeout duration, the request will be interrupted.
  • If the interval between two consecutive request bodies reaching the load balancer is greater than the timeout duration, the connection will be disconnected.
The value ranges from 1 to 300 (in seconds). The default value is 60.
This parameter is available only for HTTP and HTTPS listeners.
Minimum value: 1
Maximum value: 300
Default value: 60
kubernetes.io/elb.member_timeout
String
Timeout for waiting for a response from a backend server. After a request is forwarded to the backend server, if the backend server does not respond within the duration specified by member_timeout, the load balancer will stop waiting and return HTTP 504 Gateway Timeout.
Minimum value: 1
Maximum value: 300
Default value: 60
For details, see Configuring Timeout for a LoadBalancer Ingress.
Adding Resource Tags
Table 6 Annotations
Type
kubernetes.io/elb.tags
String
Add resource tags to a load balancer. This parameter can be configured only when a load balancer is automatically created.
A tag is in the format of "key=value". Use commas (,) to separate multiple tags.
v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, or later
For details, see Creating an Ingress - Automatically Creating a Load Balancer.
Configuring a Custom Listening Port
A custom listening port can be configured for an ingress. In this way, both ports 80 and 443 can be exposed.
Table 7 Annotations for a custom listening port
Type
kubernetes.io/elb.listen-ports
String
Create multiple listening ports for an ingress. The port number ranges from 1 to 65535.
The following is an example for JSON characters:
kubernetes.io/elb.listen-ports: '[{"HTTP":80},{"HTTPS":443}]'
  • Only the listening ports that comply with both HTTP and HTTPS are allowed.
  • Only newly created ingresses are allowed. Additionally, after multiple listening ports are configured, annotations cannot be modified or deleted.
  • If both kubernetes.io/elb.listen-ports and kubernetes.io/elb.port are configured, kubernetes.io/elb.listen-ports takes a higher priority.
  • Ingress configuration items such as the blocklist, trustlist, and timeout concurrently take effect on multiple listening ports.
  • Advanced forwarding policies are not supported.
v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later
For example, if an existing ELB is used, the configuration is as follows:
kind: Ingress
  annotations:
    kubernetes.io/elb.id: 2c623150-17bf-45f1-ae6f-384b036f547e     # ID of an existing load balancer
    kubernetes.io/elb.class: performance    # Load balancer type
    kubernetes.io/elb.listen-ports: '[{"HTTP": 80},{"HTTPS": 443}]'    # Multi-listener configuration
    kubernetes.io/elb.tls-certificate-ids: 6cfb43c9de1a41a18478b868e34b0a82,6cfb43c9de1a41a18478b868e34b0a82   # HTTPS certificate configuration
  namespace: default
  ingressClassName: cce
  rules:
  - host: example.com
    http:
      paths:
      - backend:
          service:
            port:
              number: 8888
        path: /
        property:
Configuring a Custom Header Forwarding Policy
Table 8 Annotations for configuring a custom header forwarding policy
Type
kubernetes.io/elb.headers.${svc_name}
String
Custom header of the Service associated with an ingress. ${svc_name} is the Service name.
Format: a JSON string, for example, {"key": "test", "values": ["value1", "value2"]}
  • key/value indicates the key-value pair of the custom header. A maximum of eight values can be configured.
    Enter 1 to 40 characters for a key. Only letters, digits, hyphens (-), and underscores (_) are allowed.
    Enter 1 to 128 characters for a value. Asterisks (*) and question marks (?) are allowed, but spaces and double quotation marks are not allowed. An asterisk can match zero or more characters, and a question mark can match one character.
  • Either a custom header or grayscale release can be configured.
  • Enter 1 to 51 characters for ${svc_name}.
v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later
For details, see Configuring a Custom Header Forwarding Policy for a LoadBalancer Ingress.
Parameters for Automatically Creating a Load Balancer
Table 9 elb.autocreate data structure
Mandatory
Type
name
No
String
Name of the automatically created load balancer.
The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed.
Default: cce-lb+service.UID
type
No
String
Network type of the load balancer.
  • public: public network load balancer
  • inner: private network load balancer
Default: inner
bandwidth_name
Yes for public network load balancers
String
Bandwidth name. The default value is cce-bandwidth-******.
No
String
Bandwidth mode.
  • bandwidth: billed by bandwidth
  • traffic: billed by traffic
Default: bandwidth
bandwidth_size
Integer
Bandwidth size. The value ranges from 1 Mbit/s to 2000 Mbit/s by default. Configure this parameter based on the bandwidth range allowed in your region.
The minimum increment for bandwidth adjustment varies depending on the bandwidth range.
  • The minimum increment is 1 Mbit/s if the allowed bandwidth does not exceed 300 Mbit/s.
  • The minimum increment is 50 Mbit/s if the allowed bandwidth ranges from 300 Mbit/s to 1000 Mbit/s.
  • The minimum increment is 500 Mbit/s if the allowed bandwidth exceeds 1000 Mbit/s.
bandwidth_sharetype
String
Bandwidth sharing mode.
  • PER: dedicated bandwidth
eip_type
String
EIP type.
  • 5_bgp: dynamic BGP
The specific type varies with regions. For details, see the EIP console.
vip_subnet_cidr_id
No
String
Subnet where a load balancer is located. The subnet must belong to the VPC where the cluster resides.
If this parameter is not specified, the ELB load balancer and the cluster are in the same subnet.
This field can be specified only for clusters of v1.21 or later.
vip_address
No
String
Private IP address of the load balancer. Only IPv4 addresses are supported.
The IP address must be in the ELB CIDR block. If this parameter is not specified, an IP address will be automatically assigned from the ELB CIDR block.
This parameter is available only in clusters of v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, or later versions.
available_zone
Yes
Array of strings
AZ where the load balancer is located.
This parameter is available only for dedicated load balancers.
l4_flavor_name
Yes
String
Flavor name of the layer-4 load balancer.
  • Elastic: applies to fluctuating traffic, billed based on total traffic. Clusters of v1.21.10-r10, v1.23.8-r10, v1.25.3-r10, and later versions support elastic specifications.
  • Fixed: applies to stable traffic, billed based on specifications.
l7_flavor_name
No
String
Flavor name of the layer-7 load balancer.
This parameter is available only for dedicated load balancers. The value of this parameter must be the same as that of l4_flavor_name, that is, both are elastic specifications or fixed specifications.
elb_virsubnet_ids
No
Array of strings
Subnet where the backend server of the load balancer is located. If this parameter is left blank, the default cluster subnet is used. Load balancers occupy different number of subnet IP addresses based on their specifications. Do not use the subnet CIDR blocks of other resources (such as clusters and nodes) as the load balancer CIDR block.
Example:
"elb_virsubnet_ids": [
   "14567f27-8ae4-42b8-ae47-9f847a4690dd"
