Emergency Plan
Updated on 2024-11-20 GMT+08:00
You can create an emergency plan for a system fault that may occur and rectify the fault by referring to the emergency plan.
Creating an Emergency Plan
  1. Log in to COC.
  2. In the navigation pane on the left, choose Resilience Center > Emergency Plan. Click the Customized Plan tab.
    Figure 1 Customized Plan tab page
  3. Click Create. On the displayed page, set the basic information about the emergency plan.
    Figure 2 Creating an emergency plan
    Table 1 Parameters for configuring basic information about an emergency plan
    Emergency Plan Name
    Customized emergency plan name
    Enterprise Project
    Enterprise project to which the emergency plan belongs. The default value is default.
    Application
    Application to which the emergency plan belongs
    Recovery Duration
    Expected fault recovery duration
    Version
    Version number
    Summary
    Description about the emergency plan
  4. Set the troubleshooting information. The emergency plan type can be set to Automation Plan or Document Plan.
  5. If Automation Plan is selected, you can select Scripts or Jobs for Handling Method.
    Figure 3 Troubleshooting
  6. If Scripts is selected as the handling method, you can select custom scripts or common scripts as the associated scripts.
    Figure 4 Associating a custom script
    Figure 5 Associating a common script
  7. If Jobs is selected as the handling method, you can select custom jobs or common jobs as the associated job.
    Figure 6 Associating a custom job
    Figure 7 Associating a common job
  8. If Document Plan is selected as the emergency plan type, you can select Not Involved, Scripts, or Jobs for Handling Method, enter the step name and description, and click Save.
    Figure 8 Document plan steps
Viewing Emergency Plan Details
  1. Log in to COC.
  3. Click the name of an emergency plan to view the emergency plan details.
    Figure 9 Viewing emergency plan details
Editing an Emergency Plan
  1. Log in to COC.
    Figure 10 Customized Plan
  3. Locate the target plan and click Modify in the Operation column.
    Figure 11 Modifying an Emergency Plan
Deleting an Emergency Plan
  1. Log in to COC.
  3. Locate the target emergency plan and click Delete in the Operation column.
    Figure 12 Emergency plans
  4. In the displayed dialog box, click OK.
    Figure 13 Deleting an emergency plan
