- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Automated O&M/
Account Management/
Password Change Tasks
Configuring Password Change Regions
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M. In the Routine O&M area, click Account Management.
- Click the Change Account Password tab and then then Password Change Tasks tab, and select the region where periodic password change needs to be enabled. Click Select Region, select the region to be configured, click the rightward arrow, and click OK. Then you can click View Details in the Operation column to view the password change task in the configured region. You can also delete the region based on service requirements.
Figure 1 Configuring regions
- You can obtain host passwords on the Accounts tab page as needed.
Parent topic: Account Management
