Installing UniAgent on a Host
UniAgent is the core component of the cloud service O&M system. Its core capabilities include middleware metric collection, customized metric collection, and script delivery and execution channel. It provides underlying support for automated O&M of cloud resources.
This section describes how to install, reinstall, upgrade, and uninstall UniAgent, as well as synchronize the status of UniAgent on COC, helping you complete component deployment and lifecycle management. Once UniAgent is installed, you can use it to automate operations, such as metric monitoring and batch script execution, for target resources.
- Currently, you can only perform UniAgent-related operations on ECSs and BMSs on COC.
- You can install UniAgent tools on a maximum of 100 ECSs in batches.
- Currently, this function is available only for Linux OSs. For Windows OSs, you need to manually install UniAgent. For details, see Installing UniAgent on an ECS.
- For Linux x86_64 servers, all OSs and versions listed in Table 1 are supported.
- For Linux Arm servers, CentOS 7.4/7.5/7.6, EulerOS 2.0, and Ubuntu 18.04 are supported.
Table 1 Linux operating systems and versions supported by UniAgent OS
Version
EulerOS
1.1 64-bit
2.0 64-bit
CentOS
7.1 64-bit
7.2 64-bit
7.3 64-bit
7.4 64-bit
7.5 64-bit
7.6 64-bit
7.7 64-bit
7.8 64-bit
7.9 64-bit
8.0 64-bit
Ubuntu
16.04 server 64-bit
18.04 server 64-bit
20.04 server 64-bit
22.04 server 64-bit
Installing UniAgent
- Log in to COC.
- In the navigation pane, choose Resources > Application and Resource Management.
- On the Resources page, select the target instance and choose UniAgent > Install or click Install Now in the UniAgent Status column. When UniAgent is installed in a VPC for the first time, you need to manually install UniAgent and set the first host with UniAgent installed as the installation host. For details, see How Do I Install the UniAgent Component for the First Time?Figure 1 Installing UniAgent
- On the page for installing UniAgent, set basic information for installing UniAgent.
Table 2 Parameters for installing UniAgent Parameter
UniAgent Version
Select a UniAgent version from the drop-down list.
Host Access Mode
There are three access modes: Direct access (private network), Direct access (public network), and Proxy access.
- Direct access (private network): intended for Huawei Cloud hosts.
- Direct access (public network): intended for non-Huawei Cloud hosts.
- Proxy access: Select a proxy area where a proxy has been configured and remotely install UniAgent on a host through the proxy.
Proxy Area
When Host Access Mode is set to Proxy access, you need to select a proxy area.
A proxy area is used to manage proxies by category. A proxy is a Huawei Cloud Elastic Cloud Server (ECS) purchased and configured on Huawei Cloud to enable network communication between multiple clouds.
Installation Host
Select an installation host from the drop-down list.
Select a host where UniAgent has been installed. The installation host helps install UniAgent on other hosts in the same VPC.
Hosts About to Accommodate UniAgent
Enter detailed information about the host where UniAgent needs to be installed.
- Host Name: host name.
- Host IP Address: IP address of the host.
- OS: operating system of the host. Currently, only Linux is supported.
- Login Account: account for logging in to the host. For the Linux OS, using the root account is recommended so that you have sufficient read and write permissions.
- Login Port: port for accessing the host.
- Authentication Mode: Currently, only password-based authentication is supported.
- Password: password for logging in to the host.
- O&M Test Result: shows whether the network between the installation host and the host where UniAgent needs to be installed is normal.
- Operation:
- Test Network
- Delete
- (Optional) Perform batch operations.
- Test Connection: Select multiple hosts to be installed and click Test Connection to perform O&M connection tests on the selected hosts in batches.
- Batch Specify Data
- Manual batch parameter settings: Login accounts, login ports, and passwords can be filled in batches. Figure 2 Manual input
- Importing data in batches using an Excel file: You can click Download Template, manually enter data based on the template, and import data in batches using an Excel file. Figure 3 Importing data in batches
- Batch export: Export all data of the hosts to be installed in batches.
- Click OK and wait until the installation is complete.
It takes several minutes to install the UniAgent and synchronize the status. You can wait patiently and synchronize the UniAgent status. After the installation is successful, the UniAgent status in the resource list is Running. You can perform subsequent O&M operations.
Reinstalling UniAgent
- Log in to COC.
- Select the instances with the UniAgent status of Abnormal, Uninstalled, or Installation failed, then choose UniAgent > Reinstall or click Reinstall in the UniAgent Status column. Figure 4 Reinstalling UniAgent
- The parameters are almost the same as those for installing UniAgent. For details, see Table 3.
Table 3 Parameters for installing UniAgent Parameter
UniAgent Version
Host Access Mode
Proxy Area
Installation Host
- Operation:
- Test Network
- Delete
- After the setting is complete, click OK and wait until the reinstallation is complete.
Upgrading UniAgent
- Log in to COC.
- Select the instance where UniAgent has been installed and choose UniAgent > Upgrade. The UniAgent upgrade page is displayed. Figure 5 Upgrading UniAgent
- On the UniAgent upgrade page, select the version to be upgraded. Figure 6 Selecting the upgrade version
- Click OK. In the confirmation dialog box, confirm the upgrade version and click OK. Wait until the upgrade is complete. After the upgrade is successful, the UniAgent target version is displayed on the details page.Figure 7 Viewing the target version
Uninstalling UniAgent
- Log in to COC.
- Select the instances where UniAgent has been installed and choose UniAgent > Uninstall. Figure 8 Uninstalling UniAgent
- Click OK and wait until the uninstallation is complete.
Synchronizing the UniAgent Status
- Log in to COC.
- Select the instances where UniAgent has been installed and choose UniAgent > Synchronize Status. If the message "Status synchronized" is displayed, the synchronization is complete.Figure 9 Synchronizing the UniAgent status
Viewing UniAgent Operation Logs
- Log in to COC.
- Click UniAgent Operation Logs to view historical UniAgent operation records. Figure 10 Synchronizing the UniAgent status
- Click UniAgent FAQs to view the problems frequently encountered and their solutions when performing UniAgent-related operations. Figure 11 Synchronizing the UniAgent status
