Halaman ini belum tersedia dalam bahasa lokal Anda. Kami berusaha keras untuk menambahkan lebih banyak versi bahasa. Terima kasih atas dukungan Anda.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Show all
Drill Plan
When creating a drill plan, you can specify an executor and the planned drill time. The executor creates a drill task by receiving a ticket. A drill task is associated with the fault mode and region.
Precautions
You do not need to specify the enterprise project to which the drill plan belongs. The enterprise project must be the same as that associated with the fault mode.
- Log in to COC.
- In the navigation pane on the left, choose Resilience Center > Chaos Drill. On the displayed page, click Risk Management Tasks, and click Drill Plans.
Figure 1 Drill Plans
- Click Create Drill Plan. In the displayed dialog box, set Failure Mode, Executed By, Region, and Planned Drill Time, and click OK.
Figure 2 Creating a drill plan
- The executor clicks Receive in the Operation column. The page for creating a drill task is displayed. The drill task is associated with the specified failure mode and region. In addition, the executor can track the progress of the drill task.
Figure 3 Creating a drill task
