Halaman ini belum tersedia dalam bahasa lokal Anda. Kami berusaha keras untuk menambahkan lebih banyak versi bahasa. Terima kasih atas dukungan Anda.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Help Center/
Cloud Operations Center/
User Guide/
Faults/
Incident Management/
Handling an Incident/
Upgrading/Downgrading an Incident
The incident ticket level is inconsistent with the actual situation. The incident level can be modified only after the incident is accepted.
- Log in to COC.
- In the navigation pane on the left, choose Fault Management > Incidents. On the displayed page, click the Pending tab and click the incident title to go to the incident details page.
Figure 1 Incident details
- Click the ... icon and choose Upgrade/Downgrade.
Figure 2 Upgrading/downgrading an incident
- Enter the upgrade or downgrade information and click OK.
Figure 3 Entering upgrade and downgrade information
Parent topic: Handling an Incident
