Updated on 2025-07-29 GMT+08:00
Adding Remarks
When handling an incident, you can add remarks if needed.
Remarks can be added only after an incident is acknowledged.
Adding Remarks
- Log in to COC.
- In the navigation pane, choose Fault Management > Incidents.
- On the Pending tab page, select the target incident ticket and click its title.
- Click Add Remark in the upper right corner.
- Add remarks.
- Remarks: Enter remarks.
- Click OK.
The incident remarks are added.
