Halaman ini belum tersedia dalam bahasa lokal Anda. Kami berusaha keras untuk menambahkan lebih banyak versi bahasa. Terima kasih atas dukungan Anda.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Help Center/
Cloud Operations Center/
User Guide/
Automated O&M/
Patch Management/
Repairing Patches
Repairing Patches
The patch repair feature allows users to repair non-compliant ECS, CCE, or BMS instances scanned by patches. The patch repair feature upgrades or installs non-compliant patches on ECS or CCE instances.
Repair patches on COC.
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M. Click Patch management. On the displayed page, click Patch Scanning.
- Select the instance whose patch needs to be repaired and click Repair.
Figure 1 Select the target instances
- Set the batch policy.
Batch policy
- Automatic: The selected hosts are automatically divided into multiple batches based on the preset rule.
- Manual: You can manually create multiple batches and add instances to each batch as required.
- No batch: All hosts to be executed are in the same batch.
Figure 2 Selecting the batch policy - Set a suspension policy.
Suspension threshold: You can set the execution success rate. When the number of failed hosts reaches the pre-set suspension threshold figure, the service ticket status becomes abnormal and the service ticket stops being executed.Figure 3 Suspension policy
- Set whether to allow restart.
If you select No, you need to restart the system at another time due to some patches only taking effect after the system is restarted.
- Confirm the execution information. If the information is correct, click OK.
Figure 4 Execution information page
Parent topic: Patch Management
