Halaman ini belum tersedia dalam bahasa lokal Anda. Kami berusaha keras untuk menambahkan lebih banyak versi bahasa. Terima kasih atas dukungan Anda.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Help Center/
Cloud Operations Center/
User Guide/
Application and Resource Management/
Application Management/
You can modify a component to facilitate resource management by component.
Modify a component on COC.
- Log in to COC.
- In the navigation pane, choose Resources > Application and Resource Management. On the displayed page, click the Applications tab, choose the application for which you want to modify the component in the resource tree on the left, and click
Figure 1 Editing a component - Set parameters in the Modify Component drawer by referring to Table 1 and click OK.
Parent topic: Application Management
