Updated on 2025-08-08 GMT+08:00
Viewing Resource Topologies
The resource topology is presented in graphs. Nodes represent resources, and lines represent the resource relationships. It displays the relationships between resources more intuitively, facilitating the use, monitoring, and management of resources.
Precautions
The topology of Huawei Cloud resources can be viewed.
Currently, only the topologies of instances of Elastic Cloud Servers (ECS), MapReduce Services (MRS), Bare Metal Server (BMS), and Cloud Container Engine (CCE) can be viewed.
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Select the cloud vendor whose resources are to be viewed.
    Huawei Cloud is selected by default.
  4. Select the resource type to be synchronized.
    By default, Elastic Cloud Server (ECS) is selected.
  5. Select the target instance and click View Topology in the Operation column.
