El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Automated O&M/
Parameter Management/
Parameter Center/
Creating a Parameter
You can manage real-time parameters and manage the full lifecycle of text parameters and encrypted data.
Precautions
Parameter policies may delete parameters. Exercise caution when configuring parameter policies.
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M. In the Routine O&M area, click Parameter Center. Click Create Parameter.
Figure 1 Creating a parameter
- Set the basic information. (Parameter Name, Enterprise Project, and Parameter Type cannot be changed after the parameter is created.)
Figure 2 Basic information
- Determine whether to set a policy for deleting the parameter upon expiration. If you do not want to set such a policy, skip Step 5 and Step 6.
Figure 3 Policy for deleting the parameter upon expiration
- Determine whether to set pre-deletion notifications. If you do not want to set such notifications, skip this step. If you want to set such notifications, click Add Pre-Deletion Notification and set the notification time.
Figure 4 Adding pre-deletion notifications
- Determine whether to set unmodified notifications. If you do not want to set such notifications, skip this step. If you want to set such notifications, click Add Unmodified Notification and set the notification time.
Figure 5 Adding unmodified notifications
- If there are pre-deletion or unmodified notification policies, set Notification Mode and Notify the user.
Figure 6 Setting Notification Mode and Notify the user
- Click Adding a Tag to add tags to the parameter. If you do not want to add tags, skip this step.
Figure 7 Adding parameter tags
- Click Submit. After the creation request is submitted, the parameter list is displayed.
Parent topic: Parameter Center
