Issue Management Process
The issue management process focuses on issue lifecycle management and control, covering three key modules: issue levels, issue categories, and issue approval tasks.
- You can modify an issue level based on the issue impact scope, urgency, and other dimensions. The issue level must be updated only after being reviewed by the corresponding permission owner to ensure the mechanism of issue handling priority.
- You can create or modify an issue type based on the business attribute and issue nature. Through a standard process, a scientific and practical classification system can be ensured.
- You can create or modify an issue approval task throughout the whole process. De-escalation or suspension can be performed only after the adjustment reasons are provided and the requests are approved. The approval mechanism and division of privileges can ensure orderly, accurate, and traceable issue management.
After modifying a specified name (for example, issue level or type), the name used in historical tickets will be updated with a delay, typically at 00:10 and 12:10 every day. New tickets use the latest name immediately.
Modifying an Issue Level
If the issue levels in your service are different from the default enumerated values or processes, you can modify the issue levels.
- Log in to COC.
- In the navigation pane, choose Basic Configurations > Process Management.
- On the Issue Process tab page, and click Issue Level.
- In the issue level list, locate the issue level you want to modify and click Modify in the Operation column.
- Change the issue level based on service requirements.
Table 1 Parameters for modifying an issue level Parameter
Issue Level - Chinese
Enter the name of the issue level in the Chinese environment.
Issue Level - English
Enter the name of the issue level in the English environment.
Level Color
Select the color corresponding to the current issue level.
Description - Chinese
Enter the description of the issue level in the Chinese environment.
Description - English
Enter the description of the issue level in the English environment.
- Click OK.
- Locate the issue level you want to enable or disable and click the feature flag to enable or disable the feature.
Enable or disable an issue level. Once the issue level is disabled, it will become unavailable.
Creating an Issue Type
- Log in to COC.
- On the Issue Process tab page, click Type of Issue.
- Click New Issue Type. In the drawer that is displayed on the right, set issue type parameters by referring to Table 2.
Table 2 Parameters for creating an issue type Parameter
Issue Type - Chinese
Enter the name of the issue type in the Chinese environment.
Issue Type - English
Enter the name of the issue type in the English environment.
Enter the description of the issue type for the Chinese environment.
Enter the description of the issue type in the English environment.
- Click OK.
You can also perform the following operations.
Table 3 More operations Function
Operation
Changing an Issue Type
A preset issue type cannot be changed.
After modifying a custom name for an issue type, the name used in historical tickets will be updated with a delay, typically at 00:10 and 12:10 every day. New tickets use the latest name immediately.
- In the navigation pane, choose Basic Configurations > Process Management. Click Issue Process and click Type of Issue. Locate the issue type to be modified and click Modify in the Operation column.
- Modify the issue type based on the service scenario.
- Click OK. In the displayed dialog box, click OK.
Deleting an Issue Type
A preset issue type cannot be deleted.
Deleted issue types cannot be restored. Exercise caution when performing this operation.
- In the navigation pane, choose Basic Configurations > Process Management. Click Issue Process and click Type of Issue. Locate the issue type to be deleted and click Delete in the Operation column.
Enabling/Disabling an Issue Type
Adjust the enabling or disabling status of the issue type.
After the issue type is disabled, it cannot be used globally. Confirm the operation impacts before performing this operation.
In the navigation pane, choose Basic Configurations > Process Management. Click Issue Process and click Type of Issue. Locate the issue type to be enabled or disabled and toggle on or off the type flag in the Enable column.
Creating an Issue Approval Task
Only one approval scenario can be available. If there is already a similar approval scenario, the approval scenario cannot be created.
- Log in to COC.
- On the Issue Process tab page, click Problem approval.
- Click New Issue Approval. The New Issue Approval page is displayed on the right.
- Set issue approval parameters by referring to Table 4.
Table 4 Parameters for creating an issue approval task Parameter
Approval Scenario
The options are Issue Downgrades and Issue suspended.
Select the target issue approval scenario.
Issue Level
This parameter needs to be set only when the approval scenario is issue de-escalation.
The options are Critical, Major, Minor, and Warning. Multiple options can be selected.
Approver
The options are Issue creator, Individual, and Shift.
- Shift: Select a shift scenario and corresponding roles from the drop-down lists based on the configured values. For details about how to configure a shift, see Shift Schedule Management.
- Individual: Select a reviewer. For details about how to configure a reviewer, see Personnel Management.
Review Rule
The options are One-member Approval and All-member Approval.
- Click OK.
Table 5 More operations Function
Operation
Modifying an issue approval task
An issue approval task can only be modified by its creator.
- In the navigation pane, choose Basic Configurations > Process Management. Click Issue Process and click Problem approval. Locate the issue approval task to be modified and click Modify in the Operation column.
- Modify the issue approval task based on the service scenario.
Deleting an issue approval task
An issue approval task can only be deleted by its creator.
- In the navigation pane, choose Basic Configurations > Process Management. Click Issue Process and click Problem approval. Locate the issue approval task to be deleted and click Delete in the Operation column.
Enabling or disabling an issue approval task
To enable or disable an issue approval task, toggle on or off the feature flag in the Enabled or Not column.
Enable or disable the issue approval task. If the task is disabled, it will be unavailable.
In the navigation pane, choose Basic Configurations > Process Management. Click Issue Process and click Problem approval. Locate the issue approval task to be enabled or disabled and toggle on or off the feature flag in the Enabled or Not column.
Viewing the details of an issue approval task
You can view the details about the created issue approval task.
In the navigation pane, choose Basic Configurations > Process Management. On the Issue Process tab page, click Problem approval. Locate the target issue approval task and click View Details in the Operation column.
