El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Monitoring System Integration Management
This document describes how to integrate monitoring systems, which is also called monitoring data sources.
Each monitoring system is independent integrated into COC. For details, see the integration process description.
- This part describes how to integrate Huawei Cloud and open-source monitoring systems to COC.
- Log in to COC.
- In the navigation tree on the left, choose Fault Management > Data Sources.
- On the displayed page, locate the monitoring system you want to integrate into COC based on service requirements and click Access integration.
Figure 1 Monitoring system integration
- On the integration page, you can view the data source integration introduction and integration procedure. After the integration is complete, click Integrate.
- After the integration is confirmed, the status of the data source changes to Enabled in the Integrated area on the Data Source Integration page.
- This part describes how to integrate monitoring systems except those mentioned in the above part into COC.
- Log in to COC.
- On the Data Sources page, in the To Be Integrated area, locate the Other Monitoring Systems card and click Access Integration. On the displayed page, enter the short name and full name of the monitoring system you want to integrate into COC and access your monitoring system as prompted. The system can be renamed.
Figure 2 Procedure for integrating a monitoring system
NOTICE:
A maximum of five monitoring systems can be integrated for customized integration. If the integration is incorrect, disable it and then delete it.
Enabling and Disabling a Monitoring System
- Log in to COC.
- On the Data Sources page, locate the card of a monitoring system and click the Enable or Disable button to enable or disable the monitoring system. You can also click a monitoring system card to go to the details page and click Enable or Disable at the bottom.
Updating an Integration Sign
- Log in to COC.
- On the Data Sources page, click a monitoring system card. On the monitoring system details page that is displayed, in the Integration Sign area, click
to update the integration sign.
Figure 3 Updating an integration sign
