El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Help Center/
Cloud Operations Center/
User Guide/
Automated O&M/
Scheduled O&M/
Scheduled Task Execution Records
View the execution records of a scheduled task.
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M. In the Routine O&M area, click Scheduled O&M.
- On the Scheduled O&M page, locate a target task, choose More > Execution Record in the Operation column.
Figure 1 Viewing task execution information
- Click the ID in the service ticket execution list to go to the corresponding script or job service ticket details page. For details about how to perform operations on the script service ticket page, see Job Tickets or Script Tickets.
Figure 2 Job execution details
Parent topic: Scheduled O&M
