Help Center/
Cloud Operations Center/
User Guide/
Task Management/
Execution Records/
Viewing a Script Service Ticket
Updated on 2025-08-08 GMT+08:00
After a script is executed, a script service ticket record is generated to record the script execution results. To trace and record the execution objects and results of the script, you can use the script service ticket function.
Viewing the Execution Records of a Script Service Ticket
- Log in to COC.
- In the navigation pane, choose Task Management > Execution Records.
- Click the Script Tickets tab.
- Click a script name.
- Perform the following operations based on the service ticket status:
- Abnormal: Click Forcibly End in the upper right corner to end the service ticket.
- Executing: Click Pause or Forcibly End in the upper right corner to pause or stop the script ticket.
- Paused: Click Continue or Forcibly End in the upper right corner to continue or stop the service ticket.
