El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Show all
Executing a Common Job
A list of public jobs are provided for you to execute common jobs on target instances.
Execute a common job on COC.
Precautions
Before executing a common job, ensure that you have the resource permissions of target instances.
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M. In the Routine O&M area, click Jobs.
Figure 1 Clicking Jobs
- Click the Common Jobs tab, click All Jobs, locate the common job to be executed, and click Execute in the Operation column.
Figure 2 Selecting and executing a common job
- Enter basic execution information, including the execution description and tag. You can create tags by following the instructions provided in Tag Management.
Figure 3 Entering basic execution information
- Select Target Instance Mode. The options include Consistent for all steps and Unique for each step.
Table 1 Target instance mode description Mode
All steps are performed on the selected target instances.
Custom configuration. A specified step is executed only on a specified instance.
Figure 4 Consistent for all stepsFigure 5 Unique for each step - Click + Add instances. In the displayed dialog box, select the target region, search for the target instances by name or UniAgent status and select them, click OK.
Figure 6 Selecting target instances
- Select Batch Policy.
- Automatic: The selected instances are divided into multiple batches based on the default rule.
- Manual: You can manually divide instances into multiple batches as required.
- No batch: All target instances are in the same batch.
Figure 7 Selecting a batch policy - Click Submit to execute the common job. The Job Ticket Details page is displayed. View the execution status of jobs and each batch on the details page.
- Click Forcibly End to end all tasks of the job.
- Click End all batches to end the tasks of all batches in the current step.
Figure 8 Job ticket details
