Updated on 2025-07-01 GMT+08:00
Server-Side Encryption
You can use server-side encryption to encrypt data uploaded to OBS to improve storage security and compliance. With server-side encryption, the OBS server encrypts the objects uploaded from the client before storing them. When the objects are accessed, the OBS server decrypts the objects and then returns them to the client.
OBS supports three encryption methods: server-side encryption with KMS-managed keys (SSE-KMS), server-side encryption with OBS-managed keys (SSE-OBS), and server-side encryption with customer-provided keys (SSE-C).
Table 1 Three server-side encryption methods
Comparison Dimension
SSE-KMS
SSE-OBS
SSE-C
Scenarios that require high compliance and security. Keys are generated by third-party validated Hardware Secure Modules (HSMs). Access to keys is controlled and all operations involving keys are traceable by logs.
Scenarios that require basic encryption and batch processing. OBS does not need to interact with KMS. SSE-OBS features lower access latency and better performance than SSE-KMS.
Scenarios that users need to store and manage keys by themselves
Key management
KMS generates and keeps keys, and OBS uses the keys to encrypt objects.
OBS generates and keeps keys, and uses the keys to encrypt objects.
A user generates and keeps keys, and OBS uses the keys to encrypt objects.
Encryption algorithm
AES256 and SM4
AES256
AES256
Encryption scope
Bucket level and object level
Object level
Details
SSE-KMS
SSE-OBS
SSE-C
  • You can refer to the regions that support SSE-KMS on the console. If you want to use the SM4 encryption algorithm when enabling SSE-KMS, choose the CN North-Ulanqab1 region.
  • SSE-OBS is available on the entire Huawei Cloud Chinese Mainland website.
  • SSE-C is available in the regions where the SSE-C API is supported.
Bucket-Level and Object-Level Server-Side Encryption
The following table compares bucket-level and object-level server-side encryption.
Table 2 Comparison between bucket-level and object-level server-side encryption
Item
Bucket-Level Encryption
Object-Level Encryption
You need to encrypt all objects when they are uploaded to a bucket.
You need to encrypt only some objects or select an encryption method and key each time you upload an object.
Encryption methods
SSE-KMS and SSE-OBS
SSE-KMS, SSE-OBS, and SSE-C
Configuration
You can change your encryption configuration at any time.
You can configure encryption during object upload and the configuration cannot be changed after the upload.
Impacts
  • If encryption is not enabled for a bucket, you can separately configure encryption when uploading objects to the bucket.
  • If encryption is enabled for a bucket, OBS only encrypts the objects uploaded after encryption is enabled, and does not encrypt those uploaded before. When you upload objects to this bucket, they will inherit the bucket's encryption by default, but you can change the configuration if needed.
  • If you change the encryption configuration for a bucket, only the objects uploaded after the change will inherit the new configuration. Objects uploaded before the change will retain the original configuration.
  • Disabling encryption for a bucket does not change the encryption status of existing objects in the bucket. However, objects uploaded later will not be forcibly encrypted. If necessary, you can manually encrypt subsequent objects when you upload them to the bucket.
  • Only one encryption method can be used each time an object is uploaded. The encryption configuration of an uploaded object cannot be changed.
  • To use SSE-KMS to encrypt a bucket or the objects in it, you must have kms:cmk:get, kms:cmk:list, kms:cmk:create, kms:dek:create, and kms:dek:crypto permissions granted by using IAM, so that you can upload objects to or download objects from this bucket.
  • If server-side encryption is disabled for a bucket, the encrypted objects can only be accessed over HTTPS.
  • A key in use cannot be deleted, or the object encrypted with this key cannot be downloaded.
SSE-KMS
Figure 1 SSE-KMS encryption process
During the encryption in Figure 1, SSE-KMS supports envelope encryption. Customer master keys hosted by KMS are not directly used to encrypt data. Instead, data keys derived from them are used to encrypt data in OBS. OBS stores the encrypted objects and data keys.
Figure 2 SSE-KMS decryption process
During the decryption in Figure 2, KMS decrypts the data keys, and OBS uses them to decrypt the objects, and returns the objects to users.
KMS uses HSMs to ensure key security, enabling users to easily create and manage encryption keys. Keys are not displayed in plaintext outside HSMs, which prevents key disclosure. All operations performed on keys are controlled and logged, and usage of all keys is recorded, meeting regulatory compliance requirements.
DEW APIs have traffic control limits. For details, see DEW API Overview. After SSE-KMS is enabled, your service access may be affected by traffic control.
Table 3 APIs that support SSE-KMS encryption
Resource
API
Header
Bucket
Creating a Bucket
  • x-obs-server-side-encryption: Encryption method of a bucket
  • x-obs-server-side-data-encryption: Encryption algorithm for server-side encryption
  • x-obs-server-side-encryption-kms-key-id: KMS master key. If this header is not provided, the default master key will be used.
  • x-obs-sse-kms-key-project-id: ID of the project that the KMS master key belongs to
Configuring Bucket Encryption
The encryption configuration is in the body. For details, see Configuring Bucket Encryption.
Object
Uploading an Object - PUT
Uploading an Object - POST
Initiating a Multipart Upload
Copying an Object
You can configure a bucket policy to limit the server-side encryption for a specific bucket to a specified method. For example, if you want people to use PUT to upload objects to bucket ExampleBucket and encrypt them with SSE-KMS, you can use the following bucket policy to deny any upload requests that do not contain the x-obs-server-side-encryption:"kms" header:
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
    "Statement": [
            "Sid": "DenyUnEncryptedObjectUploads",
            "Effect": "Deny",
            "Principal": "*",
            "Action": "PutObject",
            "Resource": "ExampleBucket/*",
            "Condition": {
                "StringNotEquals": {
                    "x-obs-server-side-encryption": "kms"
SSE-OBS
SSE-OBS uses a data key derived from the OBS root key to encrypt and decrypt data. The following lists the APIs related to SSE-OBS encryption.
Table 4 APIs related to SSE-OBS encryption
Resource
API
Header
Bucket
Creating a Bucket
Object
Copying an Object
You can configure a bucket policy to restrict the request headers for a specified bucket. For example, if you require that object upload requests do not contain header x-obs-server-side-encryption:"AES256", you can use the following bucket policy:
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
    "Statement": [
            "Effect": "Deny",
            "Principal": "*",
            "Resource": "YourBucket/*",
            "Condition": {
                    "x-obs-server-side-encryption": "AES256"
SSE-C
With SSE-C, OBS uses the keys and MD5 values provided by customers for server-side encryption.
APIs that support SSE-C encryption:
Table 5 APIs that support SSE-C encryption
Resource
API
Header
Object level
  • x-obs-server-side-encryption-customer-algorithm: Algorithm used to encrypt an object
  • x-obs-server-side-encryption-customer-key: Key used to encrypt an object. The header value is a 256-bit, base64-encoded key.
  • x-obs-server-side-encryption-customer-key-MD5: MD5 value of the key used for encrypting an object
Uploading Parts
Querying Object Metadata
Downloading an Object
Copying Parts
  • If the source part or object is not encrypted but you want to encrypt their copy, use the following three headers:
If the source part or object has been encrypted and their copy also requires encryption, use the following headers to decrypt the source:
  • x-obs-copy-source-server-side-encryption-customer-algorithm: Algorithm used to decrypt the source object
  • x-obs-copy-source-server-side-encryption-customer-key: Key used to decrypt the source object. The header value is a 256-bit, base64-encoded key.
  • x-obs-copy-source-server-side-encryption-customer-key-MD5: MD5 value of the key used for decrypting the source object
Copying an Object
Enabling and Configuring Server-Side Encryption for a Bucket
You can use OBS Console, APIs, or SDKs to configure Server-Side Encryption for a bucket.
Configuring Object-Level Server-Side Encryption
You can use OBS Console, APIs, or SDKs to encrypt objects to be uploaded.
