Updated on 2025-09-30 GMT+08:00
Enabling Spark Native Operator Optimization
Spark Native is a core component of Apache Spark designed to enhance the performance of Spark SQL computations. By utilizing vectorized C++ acceleration libraries, it accelerates the performance of Spark operators. Enabling Spark Native can improve the performance of Spark SQL jobs, reducing CPU and memory consumption.
After enabling Spark Native in a queue, it currently supports optimization for Scan and Filter operators.
  • Scan: The Scan operator is typically triggered by query statements, such as select * from test_table.
    The following conditions support enabling Native:
    • Hive tables and datasource tables in Parquet format
    • Datasource tables in ORC format
  • Filter: The Filter operator is typically triggered by WHERE clauses, such as select * from test_table where id = xxx.
Using the EXPLAIN statement, you can view the types of operators triggered by SQL commands, for example, Explain select * from test_table.
This section describes how to enable Spark Native operator optimization.
Notes and Constraints
  • To enable the Spark Native engine for a queue in an elastic resource pool, the following conditions must be met simultaneously:
    • Type of an elastic resource pool: Standard
    • Type of a queue: For SQL
    • Spark version: Spark 3.3.1 or later
  • For the default queue, when Spark 3.3.1 or later is used, Spark Native is disabled by default.
  • To disable Spark Native for a job, configure spark.gluten.enabled=false in the job parameters to disable Spark Native at the job level.
  • For SQL queues in an existing elastic resource pool, you can enable Spark Native by setting queue properties.
    1. In the navigation pane on the left of the DLI management console, choose Resources > Queue Management.
    2. Locate the queue for which you want to set properties, click More in the Operation column, and select Set Property.
    3. Go to the queue property setting page and set property parameters. Table 1 describes the property parameters.
      For created queues, if you change the Spark Native setting (enabled/disabled) through the DLI management console or API, you need to restart the queue for the modification to take effect.
      Table 1 Queue properties
      Property
      Example Value
      DLI Spark Native Acceleration
      Enabled
    4. Click OK.
Disabling Spark Native Operator Optimization
  • Disable Spark Native for SQL queues in an elastic resource pool.
    3. Go to the queue property setting page and set property parameters. Table 2 describes the property parameters.
      Table 2 Queue properties
      Property
      Example Value
      Disabled
    4. Click OK.
  • Disable Spark Native for a specified job when a queue has Spark Native enabled.
    After Spark Native is enabled for a SQL queue, if you want to disable Spark Native for a particular job running in the queue,
    add spark.gluten.enabled=false to the parameter settings of the SQL job to disable Spark Native.
