Updated on 2025-08-08 GMT+08:00
Managing Issue Types
Creating an Issue Type
  1. Log in to COC.
  2. In the navigation pane, choose Basic Configurations > Process Management.
  3. Access the Issue Process tab page and click the Type of Issue tab.
  4. Click Create Issue Type.
    Table 1 Parameters for creating an issue type
    Issue Type - Chinese Name
    Enter the name of the issue type in the Chinese environment.
    Issue Type - English Name
    Enter the name of the issue type in the English environment.
    Description - Chinese
    Enter the detailed description of the issue type for the Chinese environment.
    Description - English
    Enter the detailed description of the issue type for the English environment.
  5. Click OK.
    The issue type is created.
Changing an Issue Type
A preset issue type cannot be changed.
  1. Log in to COC.
  4. Locate the issue type you want to change and click Change in the Operation column.
  5. Set parameters for changing the incident type.
    Table 2 Parameters for changing the issue type
    Issue Type (Chinese)
    Issue Type (English)
  6. Click OK.
    The issue type is changed.
  7. Locate the issue type you want to enable or disable and click the feature flag to enable or disable feature.
    Adjust the enabling/disabling status of the issue type. After the issue type is disabled, it cannot be used.
Deleting an Issue Type
A preset issue type cannot be deleted.
  1. Log in to COC.
  4. Locate the issue type you want to delete and click Delete in the Operation column.
  5. Click OK.
    The issue type is deleted.
