Updated on 2025-07-29 GMT+08:00
Managing Issue Levels
Changing an Issue Level
  1. Log in to COC.
  2. In the navigation pane, choose Basic Configurations > Process Management.
  3. Access the Issue Process tab page and click the Issue Level tab.
  4. Locate the issue level you want to change and click Change in the Operation column.
  5. Set parameters for changing the incident level.
    Table 1 Parameters for changing an issue level
    Issue Level - Chinese Name
    Enter the name of the issue level in the Chinese environment.
    Issue Level - English Name
    Enter the name of the issue level in the English environment.
    Level Color
    Select the color corresponding to the current issue level.
    Description - Chinese
    Enter the detailed description of the issue level for the Chinese environment.
    Description - English
    Enter the detailed description of the issue level for the English environment.
  6. Click OK.
    The issue level is changed.
  7. Locate the issue level you want to enable or disable and click the feature flag to enable or disable feature.
    Enable or disable the issue level. After the issue level is disabled, it will become unavailable.
