Viewing a Quick Configuration Ticket
Choose Overview in the navigation pane. In the Quick Configuration Center area, click the Cloud Service Configurations tab, and click Cloud Eye. After a cloud service configuration task is added, a quick configuration ticket record is generated for you to record the new configuration result. If you want to monitor and learn about the target objects and configuration results of quick configuration tasks, you can use the quick configuration ticket feature.
Viewing the Execution Records of a Quick Configuration Ticket
- Log in to COC.
- In the navigation pane, choose Task Management > Execution Records.
- Click the Quick Configuration Tickets tab.
- Locate the target ticket, and click the ticket ID.
- Perform the following operations based on the service ticket status:
- Abnormal: Click Forcibly End in the upper right corner to terminate the service ticket.
- Executing: Click Pause or Forcibly End in the upper right corner to pause or terminate the service ticket.
- Paused: Click Continue or Forcibly End in the upper right corner to continue or terminate the service ticket.
- Completed: Click Compliance Report in the upper right corner to view the patch service ticket result.
