Updated on 2025-08-08 GMT+08:00
Restarting an Incident
After an incident ticket is rejected, the incident applicant can edit and resubmit it.
  1. Log in to COC.
  2. In the navigation pane, choose Fault Management > Incidents.
  3. On the Pending tab page, select the target incident ticket and click its title.
  4. Click Re-opening in the upper right corner.
  5. Set parameters for changing the incident ticket.
    Table 1 Parameters for changing the incident ticket
    Incident
    Customize the incident name according to the naming rules.
    Describe the incident.
    Click Add File to upload incident-related attachments.
    A maximum of 10 files can be uploaded. The supported file types are JPG, PNG, DOCX, TXT, and PDF. The size of a single file cannot exceed 10 MB.
    Incident Level
    The options are P1, P2, P3, P4, and P5.
    The incident levels are defined as follows:
    P1: Core service functions are unavailable, affecting all customers.
    P2: Core service functions are affected, affecting the core services of some customers.
    P3: An error is reported for non-core service functions, affecting some customer services.
    P4: Non-core service functions are faulty. The service latency increases, the performance deteriorates, and user experience decrease.
    P5: Non-core service exception occurs, which is customer consultation or request issue.
    Incident Category
    (Optional) Select an incident category from the drop-down list.
    Incident Ownership
    (Optional) Select the incident to which the ticket belongs from the drop-down list.
    • Alarm detection
    • Customer fault reporting
    • Proactive O&M
    • Other
    Region
    (Optional) The default value is N/A. Select the region where the event occurs from the drop-down list.
    Enterprise Project
    Select an enterprise project from the drop-down list.
    Fault Occurrence Time
    Enter the time when the fault occurs.
    Application
    Select the application affected by the incident from the drop-down list.
    Service Interrupted
    The options are Yes and No.
    Owner
    Select Shift or Individual.
    • Shift: Select a scenario and role from the drop-down lists based on the configured values. For details about how to configure a shift, see Shift Schedule Management.
    • Individual: Select an owner. For details about how to configure an owner, see O&M Engineer Management.
  6. Click OK.
    The incident ticket is restarted. The incident status changes to unaccepted.
