Viewing the Patch Compliance Report Details
After the patch compliance scan or repair, you can click Compliance Report Details Summary to view the details of the patch on the instance.
View the patch compliance scanning and patch repairing results on Cloud Operations Center.
Precautions
The patch compliance report retains only the scan or repair record at the latest time.
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M. On the displayed page, click Patch management.
Figure 1 Patch management
- Select the patch compliance report to be viewed and click Summary in the Operation column.
Status description:
- Installed: The patch complies with the patch baseline, has been installed on an ECS instance, and no update is available.
- Non-baseline patches have been installed: The patch is not compliant with the patch baseline but has been installed on an ECS instance.
- Installed-to be restarted: The patch has been repaired, and can take effect only after the ECS instance is restarted.
- InstalledRejected: The rejected patch defined in the exceptional patches of a patch baseline. This patch will not be repaired even if it is compliant with the patch baseline.
- To be repaired: The patch complies with the baseline, but the patch version is earlier than the baseline version.
- Repair failed: The patch is failed to be repaired.
Figure 2 Patch compliance report summary
