Updated on 2026-09-21 GMT+08:00
Deploying Inference Workloads
Introduction
Inference workloads (ServingGroups) are used to deploy large language model (LLM) inference services in CCE clusters. This capability is built on Kthena ModelServing. It uses the vLLM inference engine to support single-node or multi-Role (Entry + Worker) distributed inference. It also uses gang scheduling and topology-aware policies to implement flexible compute allocation and stable service scheduling.
Before deployment, ensure the following requirements are met:
  • A CCE standard or Turbo cluster v1.29 or later is available.
  • Volcano v1.21.7 or later is installed in the cluster.
  1. Switch to the deployment page.
    1. Log in to the CCE console.
    2. In the navigation pane, choose AI Containers. Then, click the Inference Workloads tab.
    3. Click Deploy Application.
  2. Configure basic information and click Next: Configure Roles.
    Table 1 Basic settings
    Application Name
    Name of the inference application to be deployed
    AI Application Templates
    Predefined application templates
    When using a third-party image, ensure the pod can access the Internet. For details, see Using Third-Party Images.
    Cluster Name
    The target CCE cluster
    Namespace
    Namespace to which the inference workload will belong
    Pods
    Number of pods of the inference workload
  3. Configure the Role.
    Inference workloads use Roles to organize containers for distributed inference. Each Role contains one entry node and multiple worker nodes.
    Table 2 Role settings
    Role Name
    Custom identifier, which cannot be modified after the Role is created.
    Replicas
    Number of instances to create for the Role during deployment.
    Entry Container
    The entry container is the entry node of a Role. Each Role contains exactly one entry instance, which receives inference requests and coordinates computing tasks for the Role.
    • Container Name: defaults to container-entry, identifying the container's responsibilities.
    • Resource Quota: If the default configuration does not meet your requirements, click to adjust CPU, memory, and NPU resources.
    • Boot Command: defines the main process of the container and executed when the container starts. The main process status determines the container lifecycle. For details, see Startup Command.
    • Port: port used by the container to provide services.
    Worker Container
    The worker container is the worker node of a Role. Each Role can contain multiple worker instances, which respond to entry scheduling and execute inference tasks.
    • Replicas: number of instances for this Role in the same inference service group. Adjust replicas per Role to optimize compute allocation.
    • Container Name: defaults to container-worker.
    • Container Configuration: Select Same as entry container to reuse all configurations except the container name from the entry container. Select Custom to configure resources, startup commands, and ports independently.
  4. (Optional) Configure advanced settings.
    Table 3 Advanced settings
    Custom Inference Metrics
    When enabled, Cloud Native Cluster Monitoring automatically collects metrics from inference pods. Required annotations are automatically added to the pod to facilitate metric collection. For details, see Monitoring Custom Metrics Using Cloud Native Cluster Monitoring.
    Upgrade Policy
    Upgrade mode for the workload:
    • Not configured: The upgrade policy is not used.
    • Configured:
      • Partition: used for grayscale release to control which ServingGroup is upgraded.
        If set to 0, all ServingGroups are upgraded. If set to N (N > 0), only ServingGroups with ordinals greater than or equal to N are upgraded.
      • Max unavailable pods: maximum number of pods that can be unavailable during the upgrade. It is used to control service availability.
    Scheduling Policies
    Supported policies:
    • Gang scheduling: ensures that a group of pods (for example, multiple Roles of a distributed job) are scheduled together or not at all.
      • Not configured: Gang scheduling is not used.
      • Min Role replicas: defines the minimum number of Role replicas. The scheduler schedules pods only when sufficient resources are available.
    • Topology-aware Scheduling
      • Not configured: Topology-aware scheduling is not used.
      • Configured: Select inference pod affinity or Role affinity.
        • Pod Affinity Tier: affinity tier for ServingGroup pod scheduling. For example, deploy a PD disaggregation group within the same network domain.
        • Role Affinity Tier: affinity tier for Role pod scheduling. For example, deploy distributed inference pods (entry and workers) within the same network domain.
    Tolerance Policies
    Using both taints and tolerations allows (but does not force) the pod to be scheduled to a node with matching taints, and controls pod eviction policies after the node is tainted. For details, see Configuring Tolerance Policies.
    Labels and Annotations
    Add labels or annotations to workload pods as key-value pairs. For details, see Configuring Labels and Annotations.
    Description of the inference workload.
  5. Confirm the configurations and click Submit.
    On the Inference Workloads page, view the new inference workload in the Deploying state.
Helpful Links
