Updated on 2026-09-21 GMT+08:00
Kthena ModelServing
As the parameter scale of LLMs grows exponentially, the memory and compute bottlenecks of a single compute node become increasingly prominent. To break through the limits of physical resources, the industry is rapidly evolving towards innovative architectures such as prefill-decode disaggregation and hybrid deployment of large and small models. This transformation shifts the execution of inference tasks from a mode where only a single pod is used to a mode where multiple distributed pods collaborate.
Core positioning of multi-pod collaboration in inference tasks: Regardless of the traditional single-node homogeneous deployment or a complex prefill-decode disaggregation architecture, multi-pod collaboration has become an inevitable choice for improving compute utilization, ensuring end-to-end latency, and supporting ultra-large-scale parallelism (such as tensor parallelism or pipeline parallelism).
Kthena ModelServing is designed specifically for LLM inference in cloud native environments and provides declarative lifecycle management. Its core objective is to overcome the limitations of Kubernetes native workloads (such as Deployments and StatefulSets) in topology awareness, atomic scheduling, and complex inference workflow orchestration, thereby laying a solid foundation for advanced modes such as prefill-decode disaggregation.
Architecture Design
To overcome the limitations of Kubernetes native resources (such as Deployments or StatefulSets) in multi-Role collaboration scenarios, Kthena adopts a three-layer architecture: ModelServing -> ServingGroup -> Role. Each layer serves a distinct function, and they collaborate to deliver high-performance, scalable inference services.
Table 1 Architecture layers and functions
Layer
Managed Object
Function
ModelServing
A set of ServingGroups
As a control plane throughout the lifecycle, it maintains global configuration consistency, implements revision control, and provides the capability to query the status of inference clusters. It provides a unified interface to manage global replicas and revisions.
ServingGroup
A set of Roles
As an independent functional unit of the inference services, it is a logical group that connects the top-level control and bottom-level execution. It contains all roles required to complete an end-to-end inference, ensuring the integrity and independence of the inference logic.
Role
A set of pods
As the smallest functional execution unit, it handles specific computing tasks and consists of a group of pods with deterministic IDs. It executes specific computing or distribution tasks, such as the execution of prefill and decode roles.
At the Role layer, Kthena uses a dual-pod template design to support responsibility decoupling in distributed inference scenarios and to implement refined control and collaboration of pods through the definition of specific environment variables.
  • Entry pod: acts as the traffic ingress and task coordinator. It receives external requests and distributes computing tasks.
  • Worker pod: serves as a compute execution unit. It executes actual tensor computation and inference tasks.
    To help you identify the roles of pods in your services, the controller automatically injects the following key environment variables into entry and worker pods:
    Table 2 Key environment variables
    Environment Variable
    GROUP_SIZE
    The total number of pods in the current Role instance, used for coordinating collaboration logic across pods.
    ENTRY_ADDRESS
    Internal address (in the format of a headless service) of the entry pod. This address is used for communication with worker pods.
    WORKER_INDEX
    Unique index of each worker pod in the current role instance, which is used for identity identification and task assignment
  • A CCE standard or Turbo cluster v1.29 or later is available.
  • Volcano v1.21.7 or later has been installed in the cluster. If it is not installed, go to the CCE console and search for and install it on the Add-ons page.
    To use auto scaling, ensure Volcano v1.22.5 or later is installed.
If Volcano is used as the scheduler, you are advised to use Volcano to schedule all workloads in the cluster to avoid scheduling conflicts.
  • ModelServing depends on the Volcano Scheduler add-on. If this add-on is not installed in the cluster, related functions will not work.
  • ModelServing workloads cannot be created using the console. They must be deployed using kubectl or YAML.
  • When minRoleReplicas is specified, the cluster must provide enough resources. Otherwise, jobs may remain pending for extended periods.
Key Features
Example: a ModelServing Workload (Nginx)
In this example, there are two roles: prefill and decode. The prefill role has two replicas, each containing two pods: one entry and one worker. The decode role has three replicas, each containing three pods: one entry and two workers. For details about other scheduling features, see Key Features.
apiVersion: workload.serving.volcano.sh/v1alpha1
kind: ModelServing
  namespace: default
  schedulerName: volcano
  replicas: 1  # servingGroup replicas
  recoveryPolicy: RoleRecreate # Recovery policy
  template:
    restartGracePeriodSeconds: 60
    gangPolicy: # Gang scheduling policy
      minRoleReplicas:
        prefill: 2
        decode: 1
    roles:
      - name: prefill
        replicas: 2       # role replicas
        entryTemplate:
            containers:
              - name: worker
                image: nginx:latest
                resources:
                  limits:
                    cpu: 250m
                    memory: 512Mi
                  requests:
                    cpu: 250m
                    memory: 512Mi
            imagePullSecrets:
            - name: default-secret
        workerReplicas: 1
        workerTemplate:
            containers:
              - name: worker
                image: nginx:latest
                resources:
                  limits:
                    cpu: 250m
                    memory: 512Mi
                  requests:
                    cpu: 250m
                    memory: 512Mi
            imagePullSecrets:
      - name: decode
        replicas: 3  # role replicas
        entryTemplate:
            containers:
              - name: worker
                image: nginx:latest
                resources:
                  limits:
                    cpu: 250m
                    memory: 512Mi
                  requests:
                    cpu: 250m
                    memory: 512Mi
            imagePullSecrets:
        workerReplicas: 2
        workerTemplate:
            containers:
              - name: worker
                image: nginx:latest
                resources:
                  limits:
                    cpu: 250m
                    memory: 512Mi
                  requests:
                    cpu: 250m
                    memory: 512Mi
            imagePullSecrets:
Example: Automatic Scaling (Using vLLM)
Kthena decouples policies from targets through two core custom resources (CRDs), enabling flexible autoscaling configurations:
  • AutoscalingPolicy: defines scaling policies, including monitoring metrics, target values, stable/emergency mode thresholds, and observation windows.
  • AutoscalingPolicyBinding: defines the scaling target, binds a policy to a specific ModelServing or Role, and configures constraints such as replica limits and the metrics scrape endpoint.
Pods must expose service metrics in a Prometheus-compatible format (for example, vLLM's built-in /metrics endpoint). The Autoscaler periodically scrapes these metrics to drive scaling decisions.
Example AutoscalingPolicy
The following example uses vllm:num_requests_waiting as the metric to configure autoscaling for vLLM ModelServing workloads at the ServingGroup or Role level.
kind: AutoscalingPolicy
  metrics:
  - metricName: vllm:num_requests_waiting
    targetValue: 100
  tolerancePercent: 10
  behavior:
    scaleUp:
      panicPolicy:
        panicThresholdPercent: 150
        panicModeHold: 5m
      stablePolicy:
        stabilizationWindow: 1m
        period: 30s
    scaleDown:
      stabilizationWindow: 5m
      period: 1m
Field
metricName
Name of the metric scraped from the pod's /metrics endpoint.
targetValue
Target average value per replica. Scale-out is triggered when the observed value continuously exceeds this threshold.
tolerancePercent
Tolerance percentage. For example, 10% means scaling is suppressed when the metric is within [90, 110] to avoid jitter.
scaleUp.panicPolicy
Emergency scale-out policy for rapid response to traffic surges.
Threshold for triggering emergency mode, as a percentage of targetValue. For example, 150% triggers emergency mode when the metric reaches 150 (100 x 1.5).
panicModeHold
Duration to maintain emergency mode, preventing premature exit and unexpected scale-in.
scaleUp.stablePolicy
Standard scale-out policy based on sustained trends.
stabilizationWindow
Stabilization window. For example, 1m means scale-out occurs only when the metric exceeds the target for 1 minute, preventing false triggers.
period
Period over which the Autoscaler calculates metrics and makes decisions.
scaleDown
Scale-in configuration. A long stabilization window is typically used to prevent frequent pod churn.
Example AutoscalingPolicyBinding
  • Binding an AutoscalingPolicy to a ModelServing (ServingGroup level)
    kind: AutoscalingPolicyBinding
      policyRef:
      homogeneousTarget:
        target:
          targetRef:
            kind: ModelServing
            namespace: default
          metricEndpoint:
            uri: "/metrics"
            port: 8000
        minReplicas: 2
        maxReplicas: 8
    Field
    policyRef
    Reference an AutoscalingPolicy that defines the scaling logic, including metrics and thresholds.
    homogeneousTarget
    Used when scaling a single target workload with homogeneous replicas. It contains the target reference and scaling constraints.
    targetRef
    Top-level resource to be scaled.
    minReplicas
    Minimum number of replicas for the ServingGroup.
    maxReplicas
    Maximum number of replicas for the ServingGroup.
  • Binding an AutoscalingPolicy to a Role (Role level)
      policyRef:
      homogeneousTarget:
        target:
          subTargets:
            kind: Role
          targetRef:
            kind: ModelServing
            namespace: default
          metricEndpoint:
            uri: "/metrics"
            port: 8000
        minReplicas: 2
        maxReplicas: 8
    Field
    subTargets
    (Optional) Refined scaling of specific components within the target workload.
    subTargets.kind
    Sub-target type. Its value is fixed to Role.
    subTargets.name
    Name of the Role as defined in ModelServing (for example, decode).
    minReplicas
    Minimum number of replicas for the specific Role.
    maxReplicas
    Maximum number of replicas for the specific Role.
