Help Center/ Cloud Container Engine/ User Guide/ Scheduling/ NPU Scheduling/ DynamicNPU Virtualization/ Using FlexNPU to Virtualize and Isolate NPU Resources
Updated on 2026-08-13 GMT+08:00
FlexNPU is a compute virtualization and elastic management system designed for the Huawei Ascend hardware ecosystem. It enables fine-grained partitioning, multi-pod sharing, and strongly isolated scheduling of physical NPUs in Kubernetes clusters. It integrates Volcano Scheduler and device plugins for declarative management and on-demand allocation of NPU resources. This section describes how to use the NPU virtualization capability to isolate the computing power from the NPU memory and efficiently use NPU device resources.
If containers in the cluster are using virtual NPU resources, do not uninstall the NPU add-on or disable FlexNPU. Otherwise, running pods may fail to access NPU resources, causing service exceptions or task interruption.
Core Architecture
In traditional AI architectures, applications are directly bound to underlying drivers and exclusively occupy physical accelerator resources, resulting in rigid resource allocation and inefficient scheduling. FlexNPU breaks this paradigm through a client-server distributed architecture that completely decouples API calls from physical execution. It consists of the following core components:
  • flexnpu-device-plugin and flexnpu-runtime: serve as the bridge between the Kubernetes control plane and the physical hardware layer.
    • Device Plugin: dynamically partitions physical NPU resources and reports them to Kubernetes, enabling accurate scheduling and fine-grained compute allocation.
    • Runtime: As the underlying OCI interception engine, it transparently and securely injects virtualized device nodes and communication configurations into the service sandbox during container startup, ensuring strict inter-service isolation.
  • flexnpu-daemon: a resident daemon process deployed on the host. It receives FlexNPU registration requests from the upper layer (for example, the Kubernetes scheduling system), and dynamically starts and manages the underlying aclserver process group (the actual physical execution endpoint). It serves as the core control plane for single-node virtualized compute scheduling.
  • flexnpu-client: deployed in the service container as a dynamic link library (DLL), it enables zero-intrusion integration for upper-layer AI applications (for example, PyTorch and vLLM). It transparently intercepts underlying hardware API calls initiated by applications at the frontend, and forwards compute requests to the aclserver on the host with minimal latency through high-speed shared memory or lightweight network protocols for actual physical execution.
FlexNPU Advantages
  • Zero-intrusion API interception
    Users can run native AI frameworks directly without recompiling code or modifying environment variables. aclrt intercepts all core instructions such as aclInit and aclrtMalloc at the lowest layer of the stack, converting locally executed function calls into network or shared memory requests. This significantly reduces service access costs.
  • High-throughput dual-link RPC communication
    To address high-frequency AI operator dispatch and large-volume data transmission, FlexNPU implements a dual-link communication architecture:
    • TAP (TCP/IP-based): transmits control flows and lightweight state instructions, ensuring connectivity and reliability across isolated environments.
    • Shared memory: For frequent tensor data interaction, the system dynamically establishes memory mapping via /dev/shm. The client writes data directly to shared memory, and the server reads it directly, achieving zero-copy data transfer and significantly reducing communication latency.
  • Cloud native-oriented containerized orchestration
    FlexNPU is designed for cloud-native environments. In OCI-compliant container runtimes such as Docker or containerd, physical devices (for example, /dev/davinciX) are exclusively managed by ACLServer within the host's security sandbox. Only virtualized communication configurations (for example, client.conf) and shared memory directories are mounted into the service container. This design achieves complete resource isolation while eliminating the risk of unauthorized physical hardware access from containers. It integrates seamlessly with custom runtimes for resource injection.
You have created a CCE standard or Turbo cluster v1.29 or later.
Configuration
Chip model
Only Snt9B chips are supported.
Container image OS
Ubuntu 22.04
  • Only private images based on specific Huawei Cloud EulerOS 2.0 server types are supported. The images must include NPU driver HDK 25.2.0 and CANN 8.5.0.
  • The CANN version in the node image must match that in the container image.
  • The glibc version of the inference and training service container image must be 2.34 or later. Ubuntu 22.04 is recommended as the base OS. You can build service container images using the CANN community edition.
Inference engine
Only vLLM Ascend v0.18.0 and CANN 8.5.0 are supported.
Model support
DeepSeek-R1-Distill-Llama-8B, Qwen/QwQ-32B, Qwen3 (1.7B/0.6B/8B/32B), Qwen3-Embedding-0.6B, Qwen3.5-9B, Qwen3.5-27B, and Qwen3-VL (2B/4B/8B) series models are supported.
AI Core allocation
  • The minimum value is 1%, the step is 1%, and the maximum value is 100%.
  • Pods mounted with multiple vNPUs (volcano.sh/flexnpu-num > 1) do not support compute partitioning. AI core compute must be allocated per card. For example, if volcano.sh/flexnpu-num is set to 2, volcano.sh/flexnpu-core.percentage must be set to 200%.
Memory allocation
The memory must be an integral multiple of 128.
Number of FlexNPU instances
  • A single card supports up to 32 FlexNPU instances.
  • A single node supports up to 128 FlexNPU instances.
  • When FlexNPU instances are created in batches, pods may restart briefly due to the time required for resource initialization. This is expected behavior. Wait until the instances are ready.
Maximum number of pod containers
Only one container in a pod can use virtual NPU resources. If a pod has more than one container, NPU virtualization is not supported.
Container runtime
Only containerd is supported.
Restrictions on privileged containers
If workloads that use virtual NPU resources run as privileged containers, the isolation between virtual NPU resources cannot be guaranteed.
Precautions
  • Do not uninstall the NPU add-on when containers in the cluster are using virtual NPU resources. Otherwise, workloads will become unavailable.
  • Do not forcibly delete containers that use virtual NPU resources. Otherwise, there may be residual resources, affecting subsequent resource scheduling and provisioning. If you have forcibly deleted the containers, take the following steps:
    1. Check all nodes where NPU virtualization is enabled. Run the flexnpu-smi info command on each node and compare all entity-id values with the UIDs of all workload pods that use virtual NPU resources on the current node.
    2. If an entity-id exists but the pod UID does not exist, the NPU virtualization device is a residual device. In this case, run the following command to clear the device:
      flexnpu-smi unregister -u <FlexNPU-ID-of-the-residual-device>
  • After a node is restarted unexpectedly, a pod that uses virtual NPU resources may be in the Execution failed state due to the delay in reporting virtual NPU resources. This is normal and can be ignored.
  • After installing the CCE AI Suite (Ascend NPU) add-on, you can upgrade the add-on version if needed.
    If NPU virtualization is enabled for CCE AI Suite (Ascend NPU), ensure that there are no workloads that are using virtual NPU resources on the nodes before performing a version upgrade. If workloads are using virtual NPU resources on NPU nodes, drain those nodes before upgrading the add-on. For details, see How Do I Drain NPU Nodes After Upgrading the CCE AI Suite (Ascend NPU) Add-on?
Step 1: Install CCE AI Suite (Ascend NPU) and Enable FlexNPU
  2. In the navigation pane, choose Add-ons. In the right pane, find the CCE AI Suite (Ascend NPU) add-on and click Install.
  3. On the add-on installation page, select version 2.8.11 or later.
  4. Click Install Using YAML. In the spec.values.custom area, add enable_flexnpu and set its value to true. Then, click Submit.
  5. On the Add-ons page, view details about the installed add-on. Ensure that the add-on pods are in the running state.
Step 2: Install and Configure the Volcano Scheduler
  1. In the navigation pane, choose Add-ons. On the right, find the Volcano Scheduler add-on, select v1.22.21 or later, and click Install. On the Add-ons page, check the status of Volcano Scheduler and ensure that it is running.
  2. In the navigation pane, choose Settings. Switch to the Scheduling tab and set the default scheduler to Volcano.
  3. Click Try Now on the right of Expert mode. On the Expert Mode (Volcano Scheduler) panel, add the following content to enable the FlexNPU capability, and click Save.
     - arguments:
         scheduleMode: binpack
    Table 1 Parameters
    scheduleMode
    Scheduling mode, which determines how tasks are allocated to NPU nodes. Options:
    • binpack: fully utilizes existing NPUs and avoids scheduling pods to idle NPUs. It scores nodes based on resource usage. Higher usage results in higher scores and priority. This kind of algorithm aims to fully utilize NPUs and schedule application loads on some NPUs.
    • spread: distributes application loads across different NPUs or nodes to the maximum extent, avoiding scheduling multiple pods to the same NPU. The scheduler scores nodes based on resource usage. Higher usage results in higher scores and priority. This kind of algorithm maximizes the use of idle resources in the cluster and evenly distributes application loads across the cluster.
    name
    Name of the scheduling add-on. The value is fixed at flexnpuaffinity.
  4. On the tab for scheduling configuration, click Confirm for the configuration to take effect.
Step 3: Prepare an Image for Containers That Use Virtual NPU Resources
Image Selection
Core requirements for selecting images are as follows:
  • Officially-verified images must be used to ensure compatibility with the Ascend NPU virtualization function.
    The recommended image is quay.io/ascend/vllm-ascend:v0.18.0. This image is optimized for Ascend NPUs, with vLLM-Ascend v0.18.0 and compatible CANN 8.5.0 pre-installed.
  • Do not change the base image randomly. Otherwise, the NPU devices may fail to be mounted or there may be model inference errors.
  • If you need to manually build a vLLM image, build the inference service container image based on the vLLM Ascend image.
Image Migration Process in an Offline Environment
Before performing the migration, ensure that:
  • A Linux ARM64 server that can access the public network is available (to avoid multi-architecture conversion issues).
  • You have installed the Docker client and logged in to the target SWR repository.
If your Kubernetes cluster nodes cannot directly access the public network (so the image cannot be directly pulled from quay.io), take the following steps to pull the image to a server that has access to the public network, and then push the tagged image to your SWR repository:
  1. Pull the ARM64 single-platform image.
    quay.io may provide a multi-architecture manifest by default. To ensure that the ARM64 architecture is pulled, you are advised to use the --platform parameter to specify the architecture.
    docker pull --platform linux/arm64 quay.io/ascend/vllm-ascend:v0.18.0
  2. Push the image to the image repository. For details, see Pushing an Image.
Step 4: Create a Workload That Uses Virtual NPU Resources
  1. In the navigation pane, choose Workloads. On the displayed page, click Create Workload.
    In this example, a workload will be created. To modify an existing workload, click the workload name and switch to the Containers tab.
  2. In the container configuration, select the image created in Step 3 and set NPU Quota to NPU virtualization > Dynamic. This lets you partition physical NPU compute and memory and allocate them to service containers.
    • Equal NPU distribution disabled
      Application scenario: single-card splitting, where the resources of a physical NPU are split and allocated to the container
      NPU Memory
      The memory allocated to the container. The value must be an integer multiple of 128 MiB.
      In FlexNPU scenarios, this parameter is specified by volcano.sh/flexnpu-memory.128mi and indicates the guaranteed memory allocated to a job on a single physical NPU. The system enforces hard isolation for NPU memory. Regardless of compute contention on the same card, the system ensures that jobs do not exceed their allocated memory, preventing OOM risks.
      NPU Compute
      The maximum compute that can be used by a container, expressed as a percentage (%) of the total compute of a single physical NPU.
      In FlexNPU scenarios, this parameter is specified by volcano.sh/flexnpu-core.percentage and indicates the minimum guaranteed percentage (lower limit) of AI Core compute, not a hard upper limit. On the same NPU:
      • If there are no other active tasks in the same compute partition or neighboring tasks are idle, the current task can use up to 100% of AI Core compute when under heavy load.
      • If neighboring tasks compete with the current task for compute, the system ensures the current task receives at least the configured percentage of AI Core compute within a given time window.
      This mechanism effectively improves overall NPU utilization in CCE's physical multi-tenant environment.
      For example, inference pods 1 and 2 are running on the same NPU, with 30% and 70% compute allocated respectively:
      • When Pod-2 has no inference requests, Pod-1 can use the full NPU compute when under heavy load.
      • When Pod-2's inference load increases and competes for compute with Pod-1, Pod-1 still reliably receives at least 30% of AI Core compute.
    • Equal NPU distribution enabled
      Application scenario: multi-NPU splitting, where the resources of one or more physical NPUs are evenly allocated to multiple FlexNPU instances, which will be used by the container.
      NPUs
      The number of FlexNPU instances that the total resources (compute and memory) are evenly distributed to. For example, if this parameter is set to 2, the container will have two FlexNPU instances.
      Total NPU Memory
      Total Compute
  3. Click Create Workload and check the status of each pod until they are running normally.
  4. Check the UID of the pod, and then run the command highlighted in the following figure on the node to view the information about the virtual NPUs allocated to the pod.
    flexnpu-smi info
    Expected result: The virtual NPU resource usage of each pod is the same as configured, and the pods are independent of each other without interference.
