FlexNPU Fault Handling
Fault Locating Procedure
vLLM Inference Service Response Timeout
If the vLLM inference service is unresponsive for more than 3 minutes, it enters a suspended state, interrupting the ongoing inference task and preventing token generation. This issue is typically caused by residual connection states in FlexNPU hardware or blocked service processes. You need to log in to the corresponding pod as the root user and perform the following operations:
- Terminates the vLLM server process.
- Check whether the vllm and python processes related to inference exist.
ps aux | grep python ps aux | grep vllm
If the processes exist, wait for 3 minutes. The program will automatically clear the processes. Then, run the preceding commands again to check the processes. If no command output is displayed, no vllm or python process related to inference is running.
- Manually clear FlexNPU connection state files.
The vLLM service depends on the FlexNPU module for hardware acceleration. If the service exits abnormally, status files such as *_connect and *_disconnect may remain. As a result, the subsequent startup fails or the connection is abnormal.
- Check the current entity_id.
ls /etc/flexnpu/shm/
- Go to the corresponding entity_id directory and clear the status files.
cd /etc/flexnpu/shm/${entity_id}/ rm -f *_connect rm -f *_disconnectReplace ${entity_id} with the entity_id value obtained in the previous step.
- Run the ls command once to ensure that no residual file exists.
- Run the vLLM inference service again. The inference task output is restored.
Manually Clearing Residual flexnpu-server Pods and Node Resources
During the use of FlexNPU, if a workload has been created or deleted, some resources may remain due to the current resource clearing mechanism. To prevent resource leakage and ensure environment consistency, you are advised to manually check and clear the following residual resources after completing related operations.
- Delete all client pods.
- Access the flexnpu-server pod.
- Search for pods whose names start with flexnpu-server.
kubectl get pods -A
- Access the pod.
kubectl exec -it ${flexnpu-server} -n kube-system -- bashReplace ${flexnpu-server} with the pod name obtained in the previous step.
- Manually clear the residual key directories on the node.
rm -rf /etc/supervisor/conf.d/* rm -rf /etc/flexnpu/persistent/* rm -rf /etc/flexnpu/server/tmp/* rm -rf /etc/flexnpu/shm/*
After the clearing is complete, verify that the directories are cleared.
ls /etc/supervisor/conf.d/ ls /etc/flexnpu/persistent/ ls /etc/flexnpu/server/tmp/ ls /etc/flexnpu/shm/
- Restart and update the flexnpud service.
After the clearing is complete, run the following commands to restart and update the flexnpud service so that the new configuration file can be loaded and the status can be updated:
supervisorctl -c /config.conf restart flexnpud supervisorctl -c /config.conf update
