Updated on 2026-08-13 GMT+08:00
Configuring SNI for an Nginx Ingress
An SNI certificate is an extended server certificate that allows the same IP address and port number to provide multiple access domain names for external systems. Different security certificates can be used based on the domain names requested by clients to ensure HTTPS communication security.
Configure SNI by setting both the default server certificate and the SNI certificate associated with the specific domain name. In the SSL handshake, the client provides the requested domain name. The load balancer then checks for the matching SNI certificate based on the domain name. It returns this certificate if available. Otherwise, it uses the default server certificate.
  • An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
  • The workload uses a ClusterIP or NodePort Service for external access.
  • You have obtained a trusted server certificate and an SNI certificate from your certificate provider. For details, see Purchasing an SSL Certificate.
  • An IngressTLS or kubernetes.io/tls secret is available for storing each certificate. For details, see Creating a Secret.
    In this example, the secret name of the server certificate is test, and that of the SNI certificate is example-test.
Configuring SNI
You can configure SNI using either the console or kubectl.
  • The SNI option is available only when HTTPS is used.
  • Only one domain name can be specified for each SNI certificate. Wildcard-domain certificates are supported.
  2. Choose Services and Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
  3. Configure ingress parameters.
    This example explains only key parameters for configuring SNI certificates. You can configure other parameters as needed. For details, see Creating an Nginx Ingress on the Console.
    Table 1 Key parameters
    Example Value
    Name
    Your custom ingress name.
    ingress-test
    Interconnect with Nginx
    If enabled, created ingresses will interconnect with the NGINX Ingress controller.
    Enabled
    Controller Name
    The name of the NGINX Ingress controller installed in the cluster. The default value is nginx. You can deploy multiple Nginx Ingress controllers and customize their names as needed.
    nginx
    TLS
    • Frontend Protocol: The options are HTTP and HTTPS. By default, NGINX Ingress Controller listens on ports 80 for HTTP and 443 for HTTPS. In this use case, select HTTPS.
    • Certificate Source: the source of a certificate for encrypting and authenticating HTTPS data transmission.
      • If you select TLS secret, you need to further specify the Server Certificate. Create an IngressTLS or kubernetes.io/tls secret for storing each certificate. For details, see Creating a Secret.
      • If you select Default certificate, NGINX Ingress Controller will use its default certificate for encryption and authentication. You can override this default while installing NGINX Ingress Controller. Otherwise, the controller's built-in certificate will be used.
    • SNI: an extended protocol of TLS. SNI enables several TLS domain names to share one IP:port pair while using different security certificates for each domain name. With SNI enabled, the client can send the requested domain name during the TLS handshake. The load balancer uses the domain name from the TLS request to find the matching certificate. If found, it returns that certificate. Otherwise, it returns the default server certificate.
    • Frontend Protocol: HTTPS
    • Certificate Source: TLS secret
    • Server Certificate: test
    • SNI:
      • Domain Name: example.com
      • Certificate: example-test
    Forwarding Policy
    • Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through an IP address. The domain name must be registered and filed. Once a domain name is used by a forwarding policy, only that domain name will be accepted for access.
    • Path Matching: If Default is selected, Prefix match will be used. You can also select Exact match as needed.
    • Path: comes from a backend application for external access. It must work in the backend application. Otherwise, forwarding will not take effect.
    • Destination Service: Select an existing Service. Only Services that meet the requirements are automatically displayed in the Service list. If no Service meets the requirements, create one by following the operations provided in Services Supported by Ingresses.
    • Destination Service Port: Select the access port of the destination Service.
    • Path Matching: Default
    • Path: /
    • Destination Service: nginx
    • Destination Service Port: 80
    Figure 1 Configuring SNI
  4. Click OK.
The SNI certificate example-test is used as an example. The domain name must match the certificate exactly.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    An example YAML file of an ingress associated with an automatically created load balancer is as follows:
    For clusters v1.23 or later:
    kind: Ingress
      namespace: default
      tls:
      - secretName: test  # The server certificate must be specified. If it is not specified, the default certificate in NGINX Ingress Controller will be used.
      - hosts:
        - example.com  # The domain name specified in the SNI certificate
        secretName: example-test  # Replace it with your SNI certificate.
      rules:
        - host: example.com
          http:
            paths:
              - path: /
                backend:
                  service:
                    name: <your_service_name>  # Replace it with your target Service name.
                    port:
                      number: <your_service_port>  # Replace it with your target Service port.
                property:
      ingressClassName: nginx
    For clusters v1.21 or earlier:
    apiVersion: networking.k8s.io/v1beta1
    kind: Ingress
      annotations:
        kubernetes.io/ingress.class: nginx
      tls:
      - hosts:
      rules:
      - host: example.com
        http:
          paths:
          - path: '/'
            backend:
              serviceName: <your_service_name>  # Replace it with your target Service name.
              servicePort: <your_service_port>  # Replace it with your target Service port.
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress.networking.k8s.io/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME           CLASS  HOSTS          ADDRESS          PORTS   AGE
    ingress-test   cce    example.com    121.**.**.**     80,443  10s
  5. Use HTTPS to access the ingress. ${ELB_IP} is the IP address accessed by the target ingress.
    curl -H "Host:example.com" -k https://${ELB_IP}:443
    If the ingress can be accessed, the certificate is configured.
