Updated on 2026-08-13 GMT+08:00
Role/Policy-based Authorization (Old IAM Version)
Role/Policy-based authorization provided by Identity and Access Management (IAM) lets you control access to CCE. With IAM, you can:
  • Create IAM users for personnel based on your enterprise's organizational structure. Each IAM user has their own identity credentials for accessing CCE resources.
  • Grant users only the permissions required to perform a given task based on their job responsibilities.
  • Entrust an account or a cloud service to perform efficient O&M on your CCE resources.
If your account meets your permissions requirements, you can skip this section.
Figure 1 shows the process flow of role/policy-based authorization.
Cluster permissions are granted to users for operating cluster-related resources only (such as clusters and nodes). To operate Kubernetes resources like workloads and Services, you must be granted the namespace permissions as well.
  • Before granting permissions to user groups, get familiar with the system policies listed in Permissions for CCE. To grant permissions for other services, learn about all system-defined permissions supported by IAM.
  • A user with the Security Administrator role (for example, your account) has all IAM permissions except role switching. Only these users can view user groups and their permissions on the Permissions page on the CCE console.
Process Flow
Figure 1 Process of granting CCE permissions using role/policy-based authorization
  1. Create a user group and assign permissions to it.
    On the IAM console, create a user group and grant it CCE read-only permissions (CCE ReadOnlyAccess as an example).
    CCE is deployed by region. On the IAM console, select Region-specific projects when assigning CCE permissions.
  2. Create an IAM user and add it to the user group.
    Create a user on the IAM console and add the user to the group created in 1.
    IAM users need programmatic and management console access to use CCE.
  3. Log in as an IAM user and verify permissions.
    Log in to the management console as the user you created, and verify that the user has the assigned permissions.
    • Choose Service List > Cloud Container Engine. Then click Buy Cluster on the CCE console. If the operation failed, CCE ReadOnlyAccess is in effect.
    • Choose another service from Service List. If a message appears indicating that you have insufficient permissions to perform the operation, the CCE ReadOnlyAccess policy is in effect.
System Roles Supported by CCE
Roles are a type of coarse-grained authorization mechanism that defines service-level permissions based on user responsibilities. Only a limited number of service-level roles are available for authorization. Roles are not ideal for fine-grained authorization and least privilege access.
The preset system role for CCE in IAM is CCE Administrator. When assigning this role to a user group, you must also assign its dependency roles, such as Tenant Guest, Server Administrator, ELB Administrator, OBS Administrator, SFS Administrator, SWR Admin, and APM FullAccess. For more information about dependencies, see System-defined Permissions.
System Policies Supported by CCE
The system policies preset for CCE in IAM are CCE FullAccess and CCE ReadOnlyAccess.
  • CCE FullAccess: common operation permissions on CCE cluster resources, excluding the namespace permissions for the clusters (with Kubernetes RBAC enabled) and the privileged administrator operations, such as agency configuration and cluster certificate generation
  • CCE ReadOnlyAccess: permissions to view CCE cluster resources, excluding the namespace permissions of the clusters (with Kubernetes RBAC enabled)
When purchasing a cluster or node that is billed on a yearly/monthly basis, add custom policies and configure payment permissions such as bss:*:* for the Billing Center.
Table 1 Permissions granted by CCE FullAccess
Action
Specific Action
cce:*:*
cce:cluster:create
Create a cluster.
cce:cluster:delete
Delete a cluster.
cce:cluster:update
Update a cluster. For example, update cluster node scheduling parameters and provide RBAC support to clusters.
cce:cluster:upgrade
Upgrade a cluster.
cce:cluster:start
Wake up a cluster.
cce:cluster:stop
Hibernate a cluster.
cce:cluster:list
List all clusters.
cce:cluster:get
Obtain cluster details.
cce:node:create
Add a node.
cce:node:delete
Delete one or more nodes.
cce:node:update
Update a node. For example, update the node name.
cce:node:get
Obtain node details.
cce:node:list
List all nodes.
cce:nodepool:create
Create a node pool.
cce:nodepool:delete
Delete a node pool.
cce:nodepool:update
Update a node pool.
cce:nodepool:get
Obtain a node pool.
cce:nodepool:list
List all node pools in a cluster.
cce:release:create
Create a release.
cce:release:delete
Delete a release.
cce:release:update
Update a release.
cce:job:list
List all cluster jobs.
cce:job:delete
Delete one or more cluster jobs.
cce:job:get
Obtain a specific cluster job.
cce:storage:create
Create a storage volume.
cce:storage:delete
Delete a storage volume.
cce:storage:list
List all volumes.
cce:addonInstance:create
Create an add-on pod.
cce:addonInstance:delete
Delete an add-on pod.
cce:addonInstance:update
Update an add-on pod.
cce:addonInstance:get
Obtain an add-on pod.
cce:addonTemplate:get
Obtain an add-on template.
cce:addonInstance:list
List all add-on pods.
cce:addonTemplate:list
List all add-on templates.
cce:chart:list
List all charts.
cce:chart:delete
Delete a chart.
cce:chart:update
Update a chart.
cce:chart:upload
Upload a chart.
cce:chart:get
Obtain a chart.
cce:release:get
Obtain a release.
cce:release:list
List all releases.
cce:userAuthorization:get
Obtain CCE user authorization.
cce:userAuthorization:create
Create CCE user authorization.
ecs:*:*
None
Perform all operations on ECSs.
evs:*:*
None
Perform all operations on EVS disks.
EVS disks can be attached to cloud servers and expanded to a higher capacity whenever needed.
vpc:*:*
None
Perform all operations on VPC, including enhanced ELB load balancers.
A cluster must run in a VPC. Create or associate a VPC when creating a namespace. All containers in the namespace will then run within that VPC.
bms:*:get*
None
View BMS resource details.
bms:*:list*
None
List all BMS resources.
ims:*:get*
None
View IMS resource details.
ims:*:list*
None
List all IMS resources.
elb:*:get
None
View ELB resource details.
elb:*:list
None
List all ELB resources.
nat:*:get
None
View NAT Gateway resource details.
nat:*:list
None
List all NAT Gateway resources.
sfs:*:get*
None
View SFS resource details.
sfs:shares:ShareAction
None
Share SFS resources for scaling.
sfsturbo:*:get*
None
View SFS Turbo resource details.
sfsturbo:shares:ShareAction
None
Share SFS Turbo resources for scaling.
tms:resourceTags:list
None
List TMS resources.
kps:domainKeypairs:list
None
List DEW SSH keys.
kps:domainKeypairs:get
None
View DEW SSH keys.
kms:cmk:get
None
View DEW key information.
kms:cmk:list
None
View DEW key list.
aom:*:get
None
View Application Operations Management (AOM) resource details.
aom:*:list
None
List AOM resources.
aom:autoScalingRule:*
None
Perform all operations on AOM auto scaling rules.
apm:icmgr:*
None
Perform operations on the ICAgent in APM.
lts:*:*
None
Perform all operations on LTS.
smn:*:*
None
Perform all operations on SMN.
Table 2 Permissions granted by CCE ReadOnlyAccess
Action
Specific Action
cce:*:get
cce:cluster:get
cce:node:get
cce:job:get
cce:chart:get
Obtain a chart.
cce:nodepool:get
Obtain a node pool.
cce:release:get
Obtain a release.
cce:*:list
cce:cluster:list
List all clusters.
cce:node:list
List all nodes.
cce:job:list
cce:chart:list
List all charts.
cce:nodepool:list
cce:release:list
List all releases.
cce:storage:list
List all volumes.
cce:kubernetes:*
None
Perform operations on all Kubernetes resources. For details, see Namespace Permissions.
ecs:*:get
None
View details about all ECS resources.
An ECS with multiple EVS disks is a cluster node in CCE.
ecs:*:list
None
List all ECS resources.
bms:*:get*
None
bms:*:list
None
ims:*:get*
None
ims:*:list*
None
evs:*:get
None
View EVS resource details. EVS disks can be attached to cloud servers and expanded to a higher capacity whenever needed.
evs:*:list
None
List all EVS resources.
evs:*:count
None
None
vpc:*:get
None
View VPC resource details.
vpc:*:list
None
List all VPC resources.
elb:*:get
None
elb:*:list
None
nat:*:get
None
nat:*:list
None
sfs:*:get*
None
None
sfsturbo:*:get*
None
None
None
List TMS resources.
None
List DEW SSH keys.
None
View DEW SSH keys.
kms:cmk:get
None
kms:cmk:list
None
View DEW key list.
aom:*:get
None
View AOM resource details.
aom:*:list
None
List all AOM resources.
None
lts:*:get
None
View details about all LTS resources.
lts:*:list
None
List all LTS resources.
smn:*:get
None
View SMN resource details.
smn:*:list
None
List SMN resources.
Example Custom Policies
Custom policies can be created as a supplement to the system-defined policies of CCE. For details about actions supported in custom policies, see Permissions and Supported Actions.
You can create custom policies in either of the following ways:
  • Visual editor: Select cloud services, actions, resources, and request conditions. No knowledge of policy syntax is required.
  • JSON: Create a JSON policy or edit an existing one.
For details, see Creating a Custom Policy. This section provides examples of common custom FunctionGraph policies.
Examples
  • Example 1: Creating a cluster
        "Version": "1.1",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                    "cce:cluster:create"
  • Example 2: Denying node deletion
    A policy with only "Deny" permissions must be used with other policies. If the permissions assigned to a user contain both "Allow" and "Deny", the "Deny" permissions take precedence over the "Allow" permissions.
    If you want to grant the CCEFullAccess permission to a user but prevent them from deleting nodes (cce:node:delete), you can create a custom policy that denies node deletion. Then, attach this policy with the CCEFullAccess policy to the user. Since an explicit denial in any policy takes precedence over any allowances, the user will have permission to perform all operations on nodes except for deleting them. The following is an example of a deny policy:
        "Version": "1.1",
        "Statement": [
                "Effect": "Deny",
                "Action": [
                    "cce:node:delete"
  • Example 3: Creating a custom policy containing multiple actions
    A custom policy can contain actions from multiple services. Ensure these services are of the same scope, either project-level or global. The following is an example policy containing multiple actions:
        "Version": "1.1",
        "Statement": [
                "Action": [
                    "ecs:cloudServers:resize",
                    "ecs:cloudServers:delete",
                    "ims:images:list",
                    "ims:serverImages:create"
                "Effect": "Allow"
CCE Cluster Permissions and Enterprise Projects
CCE supports resource management and permission allocation by cluster and enterprise project.
Note that:
  • IAM projects are based on physical isolation of resources, whereas enterprise projects provide global logical groups of resources, which better meet the actual requirements of enterprises. In addition, IAM policies can be managed based on enterprise projects. Therefore, use enterprise projects for permissions management. For details, see Creating an Enterprise Project.
  • When there are both IAM projects and enterprise projects, IAM preferentially matches the IAM project policies.
  • When creating a cluster or node using purchased cloud resources, ensure that IAM users have been granted the required permissions in the enterprise project to use these resources. Otherwise, the cluster or node may fail to be created.
  • If a resource does not support enterprise projects, the permissions granted to the resource will not take effect.
    Resource Type
    Resource
    Supporting enterprise projects
    cluster
    Cluster
    node
    Node
    nodepool
    Node pool
    job
    Job
    tag
    Cluster label
    addonInstance
    Add-on pod
    release
    Helm release
    storage
    Not supporting enterprise projects
    quota
    Cluster quota
    chart
    Chart
    addonTemplate
    Add-on template
CCE Resources
A resource is an object managed by a service. CCE supports cluster-scoped authorization. When creating a policy, specify a resource path to restrict access to specific resources.
Table 3 CCE resources and their paths
Resource Type
Resource Name
Path
cluster
Cluster
Format:
CCE:*:*:cluster:cluster_name
The first * is the region ID, and the second * is the domain ID.
Note:
For cluster resources, IAM automatically generates the prefix CCE:*:*:cluster: for resource paths.
Use a cluster name to specify a resource path. The wildcard (*) is supported. Example:
CCE:*:*:cluster:*: any cluster
CCE:*:*:cluster:test: a cluster named test
Example: Forbid users from deleting cluster nodes that match a specific naming pattern, for example, nodes in clusters whose names start with test.
    "Version": "1.1",
    "Statement": [
            "Effect": "Deny",
            "Action": [
                "cce:node:delete"
            "Resource": [
                "CCE:*:*:cluster:test*"
