Updated on 2026-09-21 GMT+08:00
Identity Policy-based Authorization (New IAM Version)
Identity policy-based authorization is a capability provided by the new IAM console for more refined, flexible permissions control. For details about the differences between the old and new IAM versions, see Differences Between the Old and New IAM Consoles. To continue to use the old IAM console, see Role/Policy-based Authorization (Old IAM Version).
Identity-based authorization provided by Identity and Access Management (IAM) lets you control access to CCE. With IAM, you can:
  • Create IAM users for personnel based on your enterprise's organizational structure. Each IAM user has their own identity credentials for accessing CCE resources.
  • Grant users only the permissions required to perform a given task based on their job responsibilities.
  • Entrust an account or a cloud service to perform efficient O&M on your CCE resources.
If your account meets your permissions requirements, you can skip this section.
Figure 1 shows the process flow of identity policy-based authorization.
  • Cluster permissions are granted to users for operating cluster-related resources only (such as clusters and nodes). To operate Kubernetes resources like workloads and Services, you must be granted the namespace permissions as well.
  • When using IAM identity policy-based authorization, you need to configure the Tenant Guest system role for IAM users.
  • When using IAM identity policy-based authorization, you need to additionally configure the following roles/policies for IAM users (Example Custom Policies):
    • For Alarm Center and Monitoring Center, the cce:cluster:get and cce:cluster:update cluster permissions are required.
    • For the nodes or node pools created using a key pair, the ecs:serverKeypairs:list key read permission is required.
    • For OBS and general purpose file system (SFS 3.0 Capacity-Oriented) storage, the cce:storage:list storage read permission is required.
  • Before granting permissions, learn about system-defined identity policies in Permissions for CCE. To grant permissions for other services, learn about all system-defined permissions supported by IAM.
  • A user with the Security Administrator role (for example, your account) has all IAM permissions except role switching. Only these users can view user groups and their permissions on the Permissions page on the CCE console.
  • If a service control policy in an organization is used for permission control, the request for creating yearly/monthly resources cannot be intercepted. For example, if an SCP policy for intercepting ECS creation is configured, yearly/monthly ECSs can still be created on CCE.
Configuration
On the CCE console, when you choose Permissions > Cluster-Level Permissions to create a user group, you will be directed to the IAM console to complete the process. After the user group is created and its permissions are configured, you can view the information on the Cluster-Level Permissions tab. This section describes the operations in IAM.
Process Flow
Figure 1 Process of granting CCE permissions using identity policy-based authorization
  1. Log in to the IAM console and create a user or user group.
  2. Attach a system-defined identity policy to the user or user group.
    Attach the system-defined identity policy CCEReadOnlyPolicy to the user or user group.
  3. Log in as an IAM user and verify permissions.
    In the authorized region, perform the following operations:
    • Choose Service List > Cloud Container Engine. Then click Buy Cluster on the CCE console. If the operation failed, CCEReadOnlyPolicy is in effect.
    • Choose another service from Service List. If a message appears indicating that you have insufficient permissions to access the service, CCEReadOnlyPolicy takes effect.
Example Custom Identity Policies
You can create custom identity policies to supplement the system-defined identity policies of CCE.
To create a custom identity policy, choose either of the following ways:
  • Visual editor: Select cloud services, actions, resources, and request conditions. No knowledge of policy syntax is required.
  • JSON: Create a JSON policy or edit an existing one.
For details, see Creating a Custom Identity Policy and Attaching It to a Principal.
When creating a custom identity policy, use the Resource element to specify the resources the identity policy applies to and use the Condition element (service-specific condition keys) to control when the identity policy is in effect. The following lists examples of common CCE custom identity policies.
  • Example 1: Grant permission to create and delete a cluster.
        "Version": "5.0",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                    "cce:cluster:createCluster",
                    "cce:cluster:delete"
  • Example 2: Create a custom identity policy containing multiple actions.
    A custom identity policy can contain the actions from one or more services. The following is an example policy containing multiple actions:
        "Version": "5.0",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                "Effect": "Allow",
                "Action": [
                    "evs:volumes:create",
                    "evs:volumes:list"
                "Effect": "Allow",
                "Action": [
                    "ecs:cloudServers:createServers",
                    "ecs:cloudServers:listServersDetails"
CCE Resources
A resource is an object managed by a service. CCE supports cluster-scoped authorization. When creating a policy, specify a resource path to restrict access to specific resources.
Table 1 CCE resources and their paths
Resource
Resource Name
Path
cluster
Cluster
Format:
CCE:*:*:cluster:cluster_name
The first * is the region ID, and the second * is the domain ID.
Note:
For cluster resources, IAM automatically generates the prefix CCE:*:*:cluster: for resource paths.
Use a cluster name to specify a resource path. The wildcard (*) is supported. Example:
CCE:*:*:cluster:*: any cluster
CCE:*:*:cluster:test: a cluster named test
Example: Forbid users from deleting cluster nodes that match a specific naming pattern, for example, nodes in clusters whose names start with test.
    "Version": "5.0",
    "Statement": [
            "Effect": "Deny",
            "Action": [
                "cce:node:delete"
            "Resource": [
                "CCE:*:*:cluster:test*"
